buget Ypipe.
Old Jan 7, 2007 | 09:29 PM
95turbo gxe's Avatar
buget Ypipe.
im wondering what size piping is a buget yipe and what type of gain I should see on the dek with it. And what size cat back should i get and whats a good one?
Old Jan 7, 2007 | 10:53 PM
SF2fan's Avatar
I would like to know this as well. Anyone?
Old Jan 7, 2007 | 11:01 PM
96blkonblkse's Avatar
are you using the 4th gen manifolds or 5th gen manifolds? the 5th gen manifold has the pre cats built into it, so the gains wont be as good compared with the 4th gen manifold. The 4th gens pre cats are built into the y-pipe so replacing the y-pipe with an aftermarket gives gains similar to headers on a 5/5.5gen. I believe on my y-pipe(CP) it was 2.5" but then again i never really measured it. A 2.5" catback is more then sufficient for a N/A engine, anything larger will result in a loss of low/mid end power.
as for power gains, if your using the 4th gen manifolds id expect similar gains, maybe a little more, if your using the 5th gen manifold id expect less maybe 8-10WHP?
Old Jan 7, 2007 | 11:14 PM
StrangeMAX
u donated...why dont u use "search"
Old Jan 8, 2007 | 05:25 AM
maxprivate's Avatar
Black Lion
wish i could answer all the question hear. but i have the budget y pipe and the gains are noticeable and a nice sound as well. i will be selling mine once i get my Cattman headers.
Old Jan 8, 2007 | 06:05 AM
I know for a fact im using 4th gen manifold for the front bank, but im not sure about the rear bank manifold was the same. but I did not know about the pre cats in the manifold? are they in the rear manifold on the dek? And how bad does that hurt me
Old Jan 8, 2007 | 06:29 AM
dmBK's Avatar
How 'bout them cliffs?
Budget y-pipe is 2.5" OD, and you will experience a noticeable power gain (~15 whp), mostly due to elimination of two small cat. converters, not the .25" increase in OD size.
Old Jan 8, 2007 | 11:51 AM
ethnic6's Avatar
I've got a budget, love it... when ur buying a y-pipe, they all give u the same gains, its just the name that ur buying, much like a front strut bar
Old Jan 8, 2007 | 12:12 PM
is their any cats in the rear dek manifold?
Old Jan 8, 2007 | 12:33 PM
MaximaSE96's Avatar
Maxima Owner
Unless u have a 1st gen equal length Stillen.....but yes it all depends on the manifolds u are running....as also stated in earlier posts.....as far as size....after the merge the y-pipe is 2.5" and u should also run 2.5" cat-back......although 2.25" could be acceptable if NEEDED..........the primarys on the y-pipe before the merge I THINK are 1.75" or 2" ill measure when i get home
Old Jan 8, 2007 | 03:36 PM
any one know about this.I got a dek rear on my dek and a de on the front.
Old Jan 8, 2007 | 04:06 PM
ewuzh's Avatar
2.5" Y-pipe. 2.5" Catback. I have a Cattman B-pipe and Dynomax super turbo axleback. Sounds good and gave me a small boost in performance, getting rid of the horrible crimped section behind the stock resonator.
Old Jan 8, 2007 | 04:23 PM
Black Maxima
I don't know.
Old Jan 8, 2007 | 04:33 PM
Gismo-T's Avatar
B!tch We Got a Problem
Originally Posted by Black Maxima
I don't know.
Old Jan 8, 2007 | 10:34 PM
venompwr2's Avatar
I found this a little odd, but you did a dek swap and arent sure which manifolds you used?
Old Jan 9, 2007 | 02:57 AM
I used a the de for the front and the dek for the rear as it was already pluged off for no egr valve
Old Jan 9, 2007 | 06:40 AM
MaximaSE96's Avatar
Maxima Owner
i am pretty sure the rear still has a cat attached to it...because it wouldnt make any sense to have a precat in one and not the other.....
Old Jan 9, 2007 | 06:59 AM
MaximaSE96's Avatar
Maxima Owner
Old Jan 9, 2007 | 04:06 PM
Originally Posted by MaximaSE96
oh ok yeah im cool I did not use the lower sections of the pipe just the manifold
Old Jan 9, 2007 | 04:50 PM
RA030726's Avatar
I'm nutty for Nissans
The rear manifolds are the same, only difference is the EGR. Some 5th gens have EGR some dont.
Old Jan 10, 2007 | 01:08 PM
ethnic6's Avatar
does anyone know the measurement of Budget's b pipe?
Old Jan 10, 2007 | 04:53 PM
Dooley's Avatar
- Budget SS Y
- Greddy SP2 Catback
Ceasars Chariot
50
Mar 2, 2005 01:10 PM
cmist11
Sep 30, 2004 04:49 PM
jimkim2004
Apr 24, 2004 07:13 PM
BigDogJonx
Jan 9, 2003 09:10 AM
