DIY Seafoam adaptor
Old Jan 10, 2007 | 04:53 AM
progun's Avatar
DIY Seafoam adaptor
I tried to post this in how to's but it seems to be closed. I went to the junkyard and got an old connector tube from the throttle body to the airbox. Harbor Freight sells a funnel set really cheap that has a small funnel in it. Drill a 3/8 hole in the connector pipe and insert the funnel. Pour the Seafoam in per directions on the bottle and blammo, it actually gets sucked into the intake rathere than drain into the bottom of the airbox. I have pictures but can't post them so e-mail me if you'd like to see them. Paul
Old Jan 10, 2007 | 05:00 AM
MaximaSE96's Avatar
Maxima Owner
Old Jan 10, 2007 | 06:49 AM
jmeister's Avatar
or you can just pull the brake booster hose & let it suck in directly into the intake and skip all that other bs
Old Jan 10, 2007 | 07:25 AM
MaximaSE96's Avatar
Maxima Owner
^^^^^^^^^ YEA......what he said...I should prolly seafoam
Old Jan 10, 2007 | 07:29 AM
onewhippedpuppy's Avatar
Brake booster hose is a very easy way to go. The difference this stuff made on my BMW 325 was amazing, much smoother idle and acceleration. I'm not under the delusion that I gained any power, but it certainly improved drivability.
Old Jan 10, 2007 | 07:32 AM
Also, consider a bottle in the oil, and one in the gas tank. I ran mine like that for a week after doing the engine treatment, then changed the oil. If you have picky neighbors, beware the initial smoke show.
Old Jan 10, 2007 | 11:20 AM
Sam o nela's Avatar
On more modern cars, Seafoam is really only good for cleaning out the intake manifold, pistons, and valves via the brake booster.
Throwing it into the gas tank doesnt make much of a difference on a fuel injected car in spite of what placebo effects you may feel...but on Carburated cars you may actually get some measurable improvement...
Putting it into the crankcase will thin out your oil if left in to long and it is kind of a harsh cleaner so if it does clean out some sludge, it will do it chunks at a time and will quickly and hopelessly clog your oil filter up...not a good thing...
I'd keep it to strictly using through the brake booster line just before an oil change....because even THEN some might leak down past the pistons and into the oil...eventually thinning it out over time...hence the needed oil change...
Old Jan 10, 2007 | 11:44 AM
kcryan's Avatar
First off, everyone be careful putting it down the brake booster (or any intake line) as going to fast could ruin your motor...
Seccond, its fine in with the gas,
BUT, BE VERY VERY VERY careful with it in the oil, i would never ever ever ever do this to a car, Auto-Rx is a much better choice, it may work, it may not, i know it will do damage
Old Jan 10, 2007 | 12:05 PM
jacobmh27's Avatar
where do you get teh seafoam from does everyone have it
Old Jan 10, 2007 | 12:19 PM
kcryan's Avatar
napa, autozone, all those places
Old Jan 10, 2007 | 12:32 PM
2da mizzax's Avatar
run away!! run away!! its a waste of money and pollutes the environment. not to mention it doesnt clean anything.
progun's Avatar
Yes, jmeister, you can put the Seafoam directly into the brake booster hose but this is post throttle body. My throttle body and throat were significantly cleaner after the application. It cost nearly nothing to do and is reuseable. As for pics, as I stated I will gladly send the two I took to anyone who is interested in them. It is a prettty self explanatory mod though. Drill hole, insert funnel, pour, smoke, enjoy the ride.
Old Jan 10, 2007 | 12:33 PM
progun's Avatar
It works really well by the way.
9aj9
Apr 5, 2020 12:11 AM
magiconthetire
Oct 26, 2015 09:03 PM
220k+ A32
Sep 23, 2015 03:38 PM
imported_Nismo_max
Sep 20, 2015 08:19 AM
thenewguyy
Sep 12, 2015 11:12 AM
