Clutch issue
Old Jan 10, 2007 | 10:02 AM
lanky2882's Avatar
Clutch issue
Recently while driving the last couple shifts have felt weird. The peddle felt noticably different and then eventually stopped working and lost all its resistance and sticks to the floor or comes back up but with no resistance. All the parts including the hoses and the slave were replaced about a year ago when the similar thing happened but it never stayed on the floor just lost its resistance. I looked at everything and there was still fluid in the resivoir but it was very low. I looked at the two spots where you could bleed and tried and followed the hoses didnt see any leaks or signs of leaks. It did look like it was leaking a bit near the bottom bleed spot but it wasnt comming out of hole. Is there a spot around there it commonly leaks? Is there an easy way to tell if its hydraulic pressure related or if its my release fork?
Old Jan 10, 2007 | 02:00 PM
lanky2882's Avatar
bump bump please help if you have knowledge on the subject
Old Jan 10, 2007 | 02:21 PM
Olezhka's Avatar
something like this happened to my old car when I was driving on the freeway. I was shifting and then the clutch pedal lost all of its resistance because the cable that goes from the pedal to the tranny came out of the tranny somehow.
Old Jan 10, 2007 | 02:41 PM
madisonmxma's Avatar
You have a leak somewhere. If you can't see a leak under the hood, try looking at where the piston goes into the master cylinder on the inside of the car. Also look around the master cylinder on the firewall too.
Old Jan 10, 2007 | 02:43 PM
There is no cable that goes from the pedal to the transmission.
Old Jan 10, 2007 | 06:24 PM
lanky2882's Avatar
there is a leak near the piston thats what i was trying to explain. Its like on the tranny near where you bleed the system. What exactly leaks there?
Old Jan 11, 2007 | 12:23 AM
lanky2882's Avatar
if any1 knows more about this issue help would be apreciated
Old Jan 11, 2007 | 02:59 AM
dgeesaman's Avatar
Maintenance Monster
Your clutch hydraulics have gone bad. It's either the clutch slave cylinder or master cylinder.
Dave
Old Jan 11, 2007 | 08:58 AM
lanky2882's Avatar
would that cause it to completely do nothing not even move the piston near the transmission though? plus there was still fluid in the system when it all failed. Just trying to find a way to eliminate the release fork since i already replaced most of the hydraulic system about a year ago.
Old Jan 11, 2007 | 09:33 AM
dgeesaman's Avatar
Maintenance Monster
The piston near the tranny never retracts away from the fork. If the slave cylinder lacks the force to push in the clutch springs, you won't see any movement in the piston.
Dave
Old Jan 11, 2007 | 09:07 PM
lanky2882's Avatar
thank you for your help
Old Jan 16, 2007 | 10:47 AM
lanky2882's Avatar
I replaced the slave cylinder where the leak was still feels like the pedal does absolutely nothing. The fork feels flimsy too so im almost certain the fork is broke or disconected. Has anyone here replaced their fork and how hard is it to do?
Old Jan 16, 2007 | 11:12 AM
jac121479's Avatar
to replace the fork you have to drop the tranny. if the retainer clip on the fork broke, you have to drop the tranny. if the frok for some strange reason just came unseated and the retainer clip is still in place, you may be able to reposition and reseat the fork without dropping the tranny, but it's highly unlikely that thats the case.
Old Jan 16, 2007 | 12:27 PM
lanky2882's Avatar
Would u consider it a job that can be done myself or will i need to pay a mechanic. I do a lot of work on my car but never anything as advanced as dropping the tranny.
Old Jan 16, 2007 | 01:22 PM
jac121479's Avatar
i've removed and reinstalled my tranny 3 times, twice in my own garage with no air tools. it can be done with some mechanical know how.
Old Jan 16, 2007 | 02:53 PM
dgeesaman's Avatar
Maintenance Monster
It's time consuming to do it without air tools or a tranny jack, but it can be done DIY and alone.
IME it helps a lot to have long extensions or low-profile ratcheting wrenches to reach some of the bolts that face toward the engine.
Dave
Old Jan 16, 2007 | 06:04 PM
lanky2882's Avatar
got all the tools including air tools and tranny jacks so it should make it even easier. Looks like i have some fun mechanical work ahead of me
Old Jan 16, 2007 | 09:49 PM
timmyp34's Avatar
i had the same kinda prob...the clutch was ****ed competly
Old Jan 17, 2007 | 11:19 AM
jac121479's Avatar
how did your clutch get ****ed?
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
conansriver
Nov 18, 2015 02:46 PM
gustavison
Oct 4, 2015 06:50 PM
wingnut2006
Sep 19, 2015 06:13 AM
