cleaned aicv and now car wont start? HELP
Old 01-14-2007 | 12:18 PM
maxspeed96CT's Avatar
The original VQ...
cleaned iacv and now car wont start? HELP
ok so the car didnt runn for long but it used to start
Now i cleaned the iacv and it wont even start.
I think i may have taken it to far apart. I took off the outter part that the 4 prong plug goes into and cleaned that to, after i noticed it was electronc, i think that was a no-no ??
Could this be possible cause of the aicv or did the car just finally decide to die?
Old 01-14-2007 | 12:29 PM
2da mizzax's Avatar
Is that the IAC Valve you mean? and which plug are you referring to?
Old 01-14-2007 | 12:32 PM
The original VQ...
ya the iacv There a thing on the outside part that is help in with 3 phillips screws.
I took that off to see if it might be dirty .... its a plactic peice and the big grey connecter goes into it
Old 01-14-2007 | 12:55 PM
matrix11229's Avatar
There is a plastic screw on top of the IACV, make sure it's not snug all the way in. Try to loosen it to raise your idle.
Also , when you try to start the car after iacv cleaning, press on the accelerator pedal.
Old 01-14-2007 | 03:40 PM
The original VQ...
Bump
messed with the screw, even took it apart agian just to check everything.
No start.
I think i broke it when i cleaned the electronic inside part with throttle body cleaner....
Old 01-14-2007 | 04:04 PM
MDeezy's Avatar
even with a malfunctioning IACV your car should still start, your idle might be high or low, but the car should still start.
When you state the car wont start, do you turn the key and nothing?
does it keep cranking with no fire?
Old 01-15-2007 | 03:37 AM
The original VQ...
cranks but no fire
Old 01-15-2007 | 05:00 AM
njmaxseltd's Avatar
Go over your work, make sure you didn't unplug any other wires.
Check the ECU for stored error codes.
Old 01-15-2007 | 12:26 PM
Bump
No start.
What year is your max ? what exactly did you brake ? (The golden inside cap with 3 screws is not electronic) .
Take pics and post them up so may be we can figure it out.
Old 01-15-2007 | 06:27 PM
The original VQ...
Ok guys heres a update
The car runs now but you gotta keep reving it.
If the rpm fall under 2k the car sounds bad, misfires, sounds like its about to stall and then stalls if you just let off the throttle.
If i hold the rpms up tho it stays on..
btw i checked the MAF with a extra one i have on hand, but no change
Iacv or throttle position sensor??
Old 01-15-2007 | 07:01 PM
MOHFpro90's Avatar
Id say IACV. Makes mroe sense. But I might be wrong. Stalling sounds like no air, and well, no air means IACV. I think, right? GL
Old 01-16-2007 | 07:26 PM
The original VQ...
The car is running awsome !
First off im not not sure what fixed the original problem of the car stalling seconds after start up. It was either the crankshaft posistion sensor or a bad fuel pump .
The misfire problem was very dumb , i cant beleive i missed it, the gasket between the iacv and the IM, it was on totaly wrong, was only hold by one screw ...lol
but its what happens when your working at night with poor lighting and etc
Thanks everyone for their sopport and help with this!
Lakersallday24
06-16-2019 01:35 AM
MAXSE5SPD
08-23-2015 12:06 PM
Balkins
08-12-2015 06:39 AM
Maxboy23
08-11-2015 11:59 AM
halfpol
08-05-2015 08:24 PM
Quick Reply: cleaned aicv and now car wont start? HELP
