belt squeal
Old Jan 24, 2007 | 06:08 PM
cpt's Avatar
cpt
belt squeal
I'm getting a belt squeal on start up. I replaced them a couple of weeks ago. A old trick we did in the 70's was run a bar of soap over it and never squealed again. Will this work here?
Old Jan 24, 2007 | 06:10 PM
JUDE's Avatar
I would just go to an auto shop and buy the spray. Only 3 or 4 bucks.
Old Jan 24, 2007 | 06:23 PM
sky jumper
forget the sprays and soaps -- tighten the belts to the proper specs and they will not squeal.
Old Jan 24, 2007 | 06:28 PM
NmexMAX's Avatar
dot dot dot ...
Try tightening the belt.
Old Jan 24, 2007 | 07:12 PM
jojo98maxima
yes i agree it happened to me i tighten the belts and it was gone
Old Jan 24, 2007 | 07:14 PM
GodFather's Avatar
Made in Taiwan
Yeah, tighten that baby up. My last belt replacement was done by myself. I didn't tighten the pulley bolt too tight, now it's slipping away and making the squealing noises. It gets worse everyday from once or twice to almost always. Then I got down there and tightend it up, it's done gone.
-Peter-
Old Jan 24, 2007 | 07:16 PM
NCSUpilot's Avatar
Belt dressing sucks...I need to take off an re-tighten to rid of my squeal. But yea, like the guys said above, screw the dressing...
Old Jan 24, 2007 | 07:44 PM
speed racer's Avatar
don't use belt dressing. Its simple. Unloosen idle pully nut adjust and retighten. And just listen to it purrr.
Old Jan 24, 2007 | 08:21 PM
cpt's Avatar
cpt
Thanks........................
Old Jan 25, 2007 | 04:27 AM
used parts's Avatar
You might want to check your harmonic balancer. Last night i was doing an oil change on my GF car....i had left my 95 SE running. I heard belt squeal so i went outside and sure enough it was my car. COme to find out the belt blows a few seconds later....i ended up finding the outer pulley ring worked its way over the inner one towards the timing cover. 245,000 miles
Old Jan 25, 2007 | 06:21 AM
NmexMAX's Avatar
dot dot dot ...
careful with that. Keep tht little wench tighten to spec.. Don't want this to happen
http://forums.maxima.org/showpost.ph...11&postcount=6
Old Jan 25, 2007 | 06:59 AM
GodFather's Avatar
Made in Taiwan
Good call, I did blow out a whole pulley from the alternator one time, from tighten up the tensioner too tight.
I then took the alternator out to Autozone for a replacement. I had to strategically blame it over to Autozone and make it sound like it was their crappy alternator's fault that this had happend. Got a whole new alternator for free.
05' MaximaMan
Oct 8, 2017 06:36 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
markevans999
Oct 25, 2015 08:27 AM
homewrecker
Sep 24, 2015 07:01 PM
2kmaximel
Sep 24, 2015 03:55 PM
