Steering Issue?
Old Feb 3, 2007 | 07:58 AM
Marl1979's Avatar
Steering Issue?
Hi All
when I turn the steering wheel all the way (either sides) at some point there's a loud "CLUNG" - only once. Then when I bring the steering whell back to the original position, there's the big CLUNG again at some point.
Any ideas?
Old Feb 3, 2007 | 11:15 AM
Marl1979's Avatar
Anybody...?
Old Feb 3, 2007 | 03:27 PM
njmaxseltd's Avatar
Quick, sell it, it's about to fall apart....
Old Feb 4, 2007 | 05:59 AM
Marl1979's Avatar
ok, maybe a second opinion....
Old Feb 4, 2007 | 06:07 AM
2da mizzax's Avatar
ball joint. tie rod end. possible but not probable that it is the rack. jack up the car and see if there is side to side play with the wheel. see if there is up and down play with the wheel.
Old Feb 4, 2007 | 08:18 AM
Marl1979's Avatar
I just replaced the ball joints about 3 months ago... I'll check the tie rod ends; hopefully it's not the rack! Anybody here had their rack failling?
Old Feb 4, 2007 | 09:28 AM
dgeesaman's Avatar
Maintenance Monster
Yes, these steering racks can fail. I suggest you take it to a shop that will find the bad component. Changing all sorts of parts is a huge waste of time and money, and if you listen/read enough you'll think you need to change everything in the front suspension.
Are you sure you're not simply hearing the bump stops when you go full lock?
Old Feb 4, 2007 | 10:00 AM
Marl1979's Avatar
Positive. Thanks for the suggestion - I'll probably end taking it to the shop and save time trying to diagnose... Any idea how much $$ is involved in changing the steering rack?
Old Feb 4, 2007 | 02:00 PM
dgeesaman's Avatar
Maintenance Monster
3 hours, probably more.
lowpost99
Oct 26, 2025 06:53 PM
gustavison
Oct 4, 2015 06:50 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
pktaske
Sep 4, 2015 08:40 AM
