engine goes cold after I start driving!!! and its -40 outside :(
I was driving for about an hour, heater was fine and all was good, then I notice its getting chilly in the car! My car temperature dropped to COLD.. and needless to say, cold air blasted from the heater. Coolant recently flushed, all fluids are good.. car has been well maintained...
Today in the mornind, car was idling, everything was perfect; nice hot air flowing in. I start driving, then 5 min later engine temperature gage goes from WARM to COLD and of course cold air start flowing from my heater!
I assume its the thermostat that is stuck... but how come it is fine when idleing??? any info will be appreciated
take care
take care
air pockets in the cooling system.. have it flushed again.. they probably didnt remove the coolant from the heater core.. u have to press a button on the climate control to dump all the water from it... or ur thermostat is bad
Thermostat is stuck open. When you drive, you are pushing way more air through the radiator, and as well, what is the wind chill there? Here its -20, so that is the temp of the air passing through the radiator. Just think of it for a moment.
Also, when idling, the somewhat hot air is let linger around the engine and cooling system, at least until the fan turns on. Thats why it is not so bad sitting at an idle.
could also be air pockets, but has the system been opened at all for repair? if it hasn't, the there should be no air pockets present.
T-stat, for the reasons stated above. air in the system will usually make it run hot with cold heat (poor thermal conduction) so you wouldn't have heat at idle either.
I've noticed a lot of people with T-stat problems shortly after cooling system work has been performed. I wonder if there's a connection?
The thermostat is stuck open. Since it may not be FULLY open, what it'll do is let the car warm up till it is normal. As you all know, the engine does cool down a bit when you are driving especially in cold weather like this. That is why when you start driving the needle will go down to cold. The cold air is cooling your car, and obviously the faster you move, the colder you're engine will be. Hence the moving back and forth of the needle from normal to cold and back to normal when you stop.
Note: I had to stop on the side of the road for about 30 sec to get my car back to normal because it was so cold and the heat was blowing out cold air.
Originally Posted by HarrisH
Your temp. needle SHOULD NOT MOVE. It should always be in the middle. If it is moving while you are driving you have a bad ECTS or something else is wrong.
I had the SAME exact problem, changed out the thermostat and it has been fine ever since. so i'm really still not sure what you're talking about or unless you stating the fact that cold moving air WILL NOT cool your engine down which is untrue.
I agree with the guy that said it's the thermostat stuck open. I just replaced mine 2 days ago. A new thermostat costs $16 original and installation is $45 in shop. Or you can just take your shoe box and cut it open, stick it between the 2 fans which are located in the front center under your hood and the thing which looks like the back of the air conditioner. It's a small space, maybe 2 inches wide.
Listen, I am just recommending this because the engine should not be running cold and your a/c is not working so you are cold.
Hint- Try to put in the carton to cover as much space as possible between the fans and that thing (radiator i think?).
Thanks Dima, I think I will go with a thermostat instead!!!
I just called the stealership and they are selling the thermostat at 43$ canadian and the gasket for 10$!!!!!!!!!! what a scam... and for some reason my mechanic told me to only install the original thermostat and he wownt put a clone in!
the reason is probably he doesn't want to do it twice in case the aftermarket part fails. What happens is that from not buying factory parts from the dealership, parts can be defective a lot of times and meaning he will do the work twice. But let me tell you, you can replace it yourself. Its VERY easy. You dont even have to drain your coolant. Just take that hose off connecting your radiator to the thermostat, loosening up i believe it's 3 bolts? n you're done. Pro one of the easiest things i've fixed on my car.....
Didn't except clone
I used my old gasket. It was in good condition. The thermostat he wants original is because many clones fail. Alteast our model (1998) is real picky with them.
But until you do all that, I would personally use the method I told you about before. It will keep your engine running in normal temperature and your heating will work too.
-It will just do the work of the thermostat. See it's stuck at one position right now where it constantly sends cold. By blocking this with the shoe box you are basically doing the thermostat's job.
BTW, You are lucky that it is stuck in this position because it could have also been that the engine is getting overheated. -That's a much worse problem
So good luck
So good luck
tsi6001
10-03-2022 10:23 PM
MaximaDrvr
08-19-2015 08:20 PM
