Car rumbles after start....
Old Feb 9, 2007 | 12:01 PM
Maximus_95's Avatar
ok, My car tends to Rumble when i start it up for about 20 seconds or so, and i'll also have some blue smoke coming from the exhaust for about 10 seconds then it stops...not sure what it is.
I also have a CEL 0111, dont know if it is the problem (Evap system/Flow)
Could this be the problem?
Anyone help....Need to smog in less than 2 months.... thanx.
Old Feb 9, 2007 | 12:14 PM
Scruit's Avatar
U wanna try me young boy?
Valve stem seals leaking oil into the cylinder(s) overnight?
Do you get more blue smoke if you leave the car overnight, versus starting the car back up after it's only been off for 5 min?
Old Feb 9, 2007 | 12:15 PM
Maximus_95's Avatar
uhmm.....almost about the same i guess....probably more smoke when i start it off in the mornings.... Is that a really bad problem? meaning Valve stem seals leaking oil into the cylinder(s) overnight....?
Old Feb 9, 2007 | 02:37 PM
Maximus_95's Avatar
bump anyone else.....?
Old Feb 9, 2007 | 03:16 PM
jltibbs's Avatar
does sound like some oil gettin in there a little. take a spark plug or 2 out and see if you have some oil on them. if so, replace valve cover grommets/tube seals, spark plugs, and you should be good. on another note, i wonder if somehow you're gettin some unused fuel in there as well. last spark plug change was when?
Old Feb 9, 2007 | 04:49 PM
Scruit's Avatar
Blue smoke is oil. Stem seals is not an unusual or uncommon job. The seals are pretty cheap but I've not replaced them on a max before so I don't know what stuff needs to be removed. Unless you have done timing belt work before you'd be better leaving it to a shop. I don't know if the VQ is an interferance engine, but if so you can destroy the engine by getting the timing belt wrong.
The leak won't kill the car, but it will get worse and will give you a bigger cloud of smoke over time. Dunno about emissions, or if they check for burned oil
Old Feb 9, 2007 | 08:39 PM
jltibbs's Avatar
i'd say its a little more than an interferance seeing as how it has three timing chains.
Old Feb 9, 2007 | 08:43 PM
risingmist's Avatar
Time To Start Saving Up For A New Engine Peter?
Old Feb 10, 2007 | 01:39 AM
Maximus_95's Avatar
damn....bad news guys....i found out the problem...
im somehow having coolant leaking into one of the cylinders....
I think i need a new motor...
anyone know a good place where i can get a 3.5 around?
Old Feb 10, 2007 | 11:03 AM
frumundacheese's Avatar
could be a headgasket. It won't be cheap to replace but its not the entire engine.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
altome15
Aug 10, 2015 07:05 PM
