engine dies
Old Feb 11, 2007 | 06:58 PM
WielkiWaac's Avatar
MaximaDriver
engine dies
today i have noticed that after i rev my engine rpm drops to 300-400 rpm and than go up to 600-700 rpm. sometimes angine dies, but it happens only when engine has operating temp.
i have no issue with starting.
any ideas??
thanks
mike
Old Feb 12, 2007 | 04:34 AM
WielkiWaac's Avatar
MaximaDriver
anyone please?
Old Feb 12, 2007 | 04:59 AM
2da mizzax's Avatar
could be a bunch of things. First thing to do is clean the throttle body and IAC Valve. After that, I would inspect/change your Engine coolant temp. sensor since you say your problem only occurs at operating temperature.
Old Feb 12, 2007 | 09:28 AM
Toolrocks's Avatar
My car is doing the same thing. I plan to remove and clean the IACV as well as the TB and see after that, pretty much what 2da mizzak suggests. However, I don't think the engine coolant temp will be releated if your temp gauge appears to work properly.
Old Feb 12, 2007 | 11:39 AM
buzpuck11's Avatar
There are actually two temp sensors. One for the gauge and another one that sends a signal to the ECU. This sensor is responsible for causing stalling and hard starts.
If cleaning IACV, TB, and changing the fuel filter doesn't do the trick, I would check/replace ECTS.
Old Feb 12, 2007 | 12:44 PM
Toolrocks's Avatar
Ahh, good to know. I'm trying to confirm that though and my 95 FSM only makes note of 1 ECTS located on the battery side of the engine compartment in the metal portion of the coolant lines. Can you tell me where the other one is located? Thanks.
Old Feb 12, 2007 | 12:51 PM
buzpuck11's Avatar
They are located right next to each other.
http://autozone.com/servlet/UiBroker...3d801f4eba.jsp
Old Feb 12, 2007 | 01:46 PM
99BlackMaxMS's Avatar
You could always seafoam, that cant hurt.
Old Feb 12, 2007 | 02:07 PM
2da mizzax's Avatar
Seafoam does hurt. If you want to clean do a Redline Intank. But before anything, do the TB and IACV cleaning and make sure you take them both off to do it.
Old Feb 12, 2007 | 03:25 PM
killerVQ30DE's Avatar
Turn on your AirCon and see if that stops it stalling.. if so your IACV is probably clogged or you need turn up your base idle via the adjuster.
when you turn on your car the fast idler will keep car running but that cuts out when car hits operating temperature
Old Feb 12, 2007 | 06:53 PM
WielkiWaac's Avatar
MaximaDriver
ok thanks guys.
i will try to clean my TB and IACV, but i have to wait for better weather.
i also was told it might be vacuum leak. is it possible??
Old Feb 12, 2007 | 09:11 PM
2da mizzax's Avatar
it could be but a leak big enough to stall the engine would usually be accompanied by a noticeable hiss.
Old Feb 13, 2007 | 11:42 PM
doong2mask's Avatar
clean the TB! That's what i do for same problem.
shilov
Feb 19, 2024 09:40 PM
sctludwig
Sep 1, 2022 01:32 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
viperboy
Sep 27, 2015 07:05 PM
Socalstillen
Sep 20, 2015 11:46 PM
