When removing auto climate control
Old Feb 14, 2007 | 01:03 PM
TurTLe*'s Avatar
When removing the auto climate control there is a tube for the inside amb temp. on the right side along with a little white connector. i got the white connector off but that tube... is there a tab or is it just a pull off type thing. Noticed that tube doesn't go anywhere but i rather not risk pulling it right now. Just wondering how if there is a connection tab or just pull.
Old Feb 14, 2007 | 05:30 PM
ChrisD's Avatar
When I disconnected the tube there was no white connector. It just pulled off.
Old Feb 14, 2007 | 05:33 PM
JeEvE's Avatar
From what I remember, the hose just slide/pop off the nipple. I think I had a hard time at first thinking that it has some type of tab or something but you should be able to just yank it off.
Old Feb 15, 2007 | 08:53 PM
TurTLe*'s Avatar
Kool thanks. there is a white connector in foam that i saw the connector is away from the unit tho.
aleast now i know i can apply a little more force cause i was extrmely careful.
Old Feb 16, 2007 | 05:39 AM
maxprivate's Avatar
Black Lion
that white connector with the foam i believe is what powers the climate control. and the black plastic tube should pop right off.
Old Feb 16, 2007 | 07:21 AM
t65k3's Avatar
Still Learning
Are you referring to the black tube and white connector on the left hand side of the last picture in this first post? http://forums.maxima.org/showthread.php?t=508629
White connector powers the unit. As for the tube, I kind of just pulled it off. It was not too hard to do so when I took it apart. But when I put it in, I pushed it in all the way.
Old Feb 16, 2007 | 09:38 AM
TurTLe*'s Avatar
^ that will the one. with the white connector. i figured my 98 might be diffrent but looks pretty much the same. its just my button layout is slightly diffrent
Starrider
Dec 18, 2015 04:43 AM
mikeg75
Nov 30, 2015 05:12 PM
trailer54
Nitrous
Nov 18, 2015 07:44 PM
EdRomo86
Sep 12, 2015 07:49 PM
