View Poll Results: What engine would you get if you had around $2k to spend
97-99 VQ30
4.26%
00-01 VQ30
19.15%
3.5 L
36
76.60%
Voters: 47. You may not vote on this poll
What engine should I get?
So I got a 99 maxima 5spd with around 215,000 miles (not sure exactly because the odometer doesn't work). The engine seems like it's life is coming to an end and so I decided to swap in a new engine in a few months. Just not sure what to get - 97-99 vq30, 00-01, or really open up my wallet and get the 3.5 I would like to know how much it would cost to do each one so I can see the price difference and to see if the performace difference is worth it. I would like to spend around $2000 but the less the better obviously.
If anyone has the 00-01 or the 3.5 engine please share your experience with the whole process and any recomendations. Thanks
All your answers can be found here. Search is also your friend. Use it.
http://forums.maxima.org/forumdispla...sprune=30&f=79
open up your wallet? you'll pay another $300-450 for a 3.5l compared to a run-of-the-mill vq30de, it will be much newer, and have less miles as well, If you're doing all the work yourself you should be able to handle the swap for well under $2000, including motor........ Recomendations, car-part.com, and DON'T buy any motor from any junkyard until they give you a VIN for it and then you take the vin and run a carfax on it to verify mileage.
If changing engine to 3.5 would it require changing engine management computer (EMC) to accommodate newer engine?
I would love the extra power but not sure if I could go all the way and change the computer.
check the stickie in the all motor section, to get a good feel for what will be needed of you to do.
swap
i would get the same moter the car came with yes the 3.5 has a little more stock hp but the 3.0 with a little work you can boost that power up. it is a hard one. good luck with the car im getting up there 154,000 on a 99 se-l
My friend has a 1995 maxima with a 03 3.5 liter and still retains his stock ecu from his 3.0. yeah sure he loses horsepower, fuel maps, and a couple hundred revs (cause the 3.0 redlines sooner) it will work but you may eventually want to get a new computer.
Tuning is a big help once the new motor is in
power is gained with the 3.5 swap, not lost.
a piggy back is your friend.
Originally Posted by HighMiles
3.0 = reliable ------- 3.5 = zoom zoom
what do you want more? longevity or power?
up to you man.
up to you man.
It depends on if you can find a low enough mile'd VQ30. I found one with 9k documented miles on it for a grand (that included instal too) Granted we knew the guy that sold it to us but eh. . So i bought that one over the VQ35 that had roughly 110 documented miles. (was cheaper too)
man thats a great deal, thats probebly one of the best auto deals i've heard of... couldn't go bad with that deal
Originally Posted by MDeezy
3.5 can last just as long as a 3.0 just gotta take good care of it.
I have both a 3.0 with 199K and a 3.5 with 130K and I take great care of them. but with the 3.5 I still have to listen to the timing chains slap around on a cold morning and I add about 1.75 quarts between oil changes, pulls like a beast though.
those are mild things but fact is the 3.0 has absolutely no issues at almost 200K.
a lot of 3.0 have the timing chain issue as well. I've actually never heard of the 3.5 having the timing chain issue, but if one were to do the swap, a new tension and guide would cure any/all noises derived from the timing chain.
both motors can last well into 300k pending maintenance.
don't get me wrong.... I voted 3.5 in the poll. I prefer it, but just because I like rocketships. not because the 3.5 is a much better motor.
I do agree with your last statement.
shilov
02-19-2024 09:40 PM
James92SE
142
01-02-2024 09:23 AM
