ECU, fuel, or something else problem... Please help!
Old Feb 27, 2007 | 08:20 AM
Riot^'s Avatar
Ok, had the car running fine all this time, was very low on gas last night, left it in the garage, in the evening filled it up a little.
Today in the morning, started my 98SE 5spd., both fans turned on as if the engine was hot, Check Engine light came on and the idle was jumping up and down between 900-600. When I give it gas, it looks like it take a second to think about it, then jerks off and speeds up.
When I floor it, it revs to 3000 on the dot, no more, then falls to about 2500 and up and down. It stalled on me on the road when I took it for a drive, then had a hard time starting. Seems now it starts fine, but still won't go beyond 3000rpm.
I checked all fuses, temp sensor... filled it up with best gas and gas cleaner... still doing it, can not rev passed 3000.
Tried to diagnose the issue, no ECU codes come up, and can't communicate with the ECU itself....
Any suggestions would be helpful before I take it to a dealer.
Thanks to all
Old Feb 27, 2007 | 09:11 AM
2da mizzax's Avatar
Check engine light and no codes? Cant communicate directly? no OBDII port? the rev stopping at 3000 could be a few things including the car being in safety mode (the usual cause slips my mind right now). Did you try the screw method to get the codes? Does Canadian Tire charge to scan?
Old Feb 27, 2007 | 09:16 AM
Riot^'s Avatar
hooked up a module to OBDII port, said it couldn't communicate with car.
what's a safety mode? didn't know there is one on the car.
Yeah tried the manual screw method, didn't work... nothing came up, just stayed lit as was. I'm gonna try again, maybe I did it wrong.
Would a car keep running with a faulty or not working ECU?
Old Feb 27, 2007 | 09:22 AM
2da mizzax's Avatar
Yeah there is a safety mode. I was reading one section of the FSM and I came across it. Cant remember what part though It could still run depending on how bad the ECU is, and based on what you have described, that sounds like it is the problem. Unfortunately I dont think there is any way to be sure short of taking it out and getting it tested or replacing it with a borrowed one. I could be wrong.
Old Feb 27, 2007 | 09:33 AM
2da mizzax's Avatar
Just looked it up again. It is caled "Fail-Safe Mode". It has to do with a malfunctioning MAF Sensor. I doubt highly that this is your problem though since you are experiencing a bunch of other problems with it. The fans and no communication makes me think the ECU is the problem. First thing you should try is removing and resecuring the harness.
Old Feb 27, 2007 | 11:40 AM
Riot^'s Avatar
well, found the problem after getting someone at Nissan to analyzie it for me.
the ECU is fried, how, no idea. All the wiring is good, the ECU itself is gone.
So, now I'm faced with a task of finding an ECU, dealer said it may be up to $1000 from them. Is the 5spd and auto ECU same, assuming all specs are identical?
Old Feb 27, 2007 | 12:16 PM
pmohr's Avatar
No more Maximas...
Automatic ECU will work in an 5MT, but not the other way around.
Old Feb 27, 2007 | 12:23 PM
Riot^'s Avatar
I was told there are like 16 different units for my year and make
What the hell....
Old Feb 27, 2007 | 02:34 PM
2da mizzax's Avatar
I have a friend parting out an I30. I will see if he can get out the ECU. only problem I can think of with using an auto ECU is getting tranny codes. Hopefully that is all done through the tranny computer only.
Old Feb 27, 2007 | 03:45 PM
Riot^'s Avatar
Yeah, any info would be great mizzax!
Thanks to all!
Old Feb 27, 2007 | 04:16 PM
njmaxseltd's Avatar
I call on the fried ECU. That just doesn't happen.
Check the ECTS again, if it's within spec (table in Haynes manual) then I'd look v-e-r-y closely at the MAF sensor. Make sure your looking at the correct coolant temp sensor, there are two of them.
The symptom of not going over 3000 RPMs is directly in relation to a failing MAF sensor.
Do you have auto climate control? If it's above freezing and your set to AUTO, the compressor will be running and so will your cooling fans.
Old Feb 27, 2007 | 04:30 PM
Riot^'s Avatar
on some other thread I posted, there was a trable someone posted there with the symptoms for "safe mode running" and they are 100% in line with what I have, due to a malfunctioning or failed ECU.
I don't have the ECU cover, and it's snowing as hell in Toronto last few days, maybe water got into it from my boots somehow, very well could have.
Old Feb 27, 2007 | 09:53 PM
orange914's Avatar
check for plugged fuel filter
Thanks to all
Old Feb 27, 2007 | 11:56 PM
Maxima_Joe's Avatar
4th Gen Parts King
It's probably the coolant temp sensor. Just change the part it's under $20 at any parts store.
Old Feb 28, 2007 | 03:56 AM
2da mizzax's Avatar
Now how would the ECTS cause the ECM to be unreadable? ECTS is nto the anwer to everything.
Old Feb 28, 2007 | 05:39 AM
Riot^'s Avatar
plugged fuel filter would still read the ECU.
When module was attached to the ECU, it was unreadable, but all the connectors and harnesses to ECU were good when tested.
What are some good aftermarket ECUs I can look into?
Old Feb 28, 2007 | 06:33 AM
Riot^'s Avatar
what do you guys think is better to run, a 97MT or a 98Auto on a 98MT
Old Feb 28, 2007 | 12:10 PM
Maxima_Joe's Avatar
4th Gen Parts King
How do we know the ecu was readable prior to the car having problems?
Or
What would make the ecu fry from being parked over night?
He parked the car and it was fine the next time he started it there was a problem.
The ects makes a lot more sense. The cold from sitting overnight killed it. The ecu is in safe mode not allowing the car to rev becasue it thinks the car is overheating and thats why the fans are turning on right away.
Also has the coolant level been checked?
Old Feb 28, 2007 | 12:30 PM
2da mizzax's Avatar
An unreadable ECU IS a problem!
Old Feb 28, 2007 | 12:38 PM
Maxima_Joe's Avatar
4th Gen Parts King
It sure is. That doesn't mean the ecu is fried. It could be the wiring or the ects.
What i would do is replace the ects and make sure the coolant is full. Then check to see if it would rev and check for codes or to see if it's readable. If it's not then unhook the battery to reset the ecu then check to see if it's readable yet.
nismology's Avatar
First off, per the FSM, the failed MAF fuel cut is at 2400 RPM.
Secondly, I'll post this again like i did in his other thread.
According to this the IACV is controlled under certain limitations. That would explain the screwy idle bouncing up and down.
BTW, this also happened to meximax. It's not common, but it's possible. Hence this entry in the fail-safe chart.
Not to mention not being able to communicate with the ECU manually or VIA the Consult II. The ECU is dead.
Old Feb 28, 2007 | 02:23 PM
Riot^'s Avatar
Thanks to all for posting.
the wiring is good, it was checked and seems to be working.
What I'm gonna do is unhook the ECU, see maybe somehow the connection is lose, if that fails, I think I'm going to try to hook up a 97 ECU on a 98, same models cars. Don't see how it may be a huge problem.
Old Feb 28, 2007 | 07:39 PM
2da mizzax's Avatar
same model but very different. I know the tranny computer and BCM are different so I would assume the ECU is too. Doesnt hurt to try.
Old Feb 28, 2007 | 08:52 PM
Riot^'s Avatar
that ECU is a pain in the A$$ to take out.
Never got to it, screws way too far down there, couldn't reach them.
Unhooked the cables, unhooked the battery, reattached, still dead...
I think I'm going for the 97ECU on my 98.
Old Feb 28, 2007 | 09:13 PM
Maxima_Joe's Avatar
4th Gen Parts King
You don't have to remove the ecu to try another one.Just remove the wiring harness and leave the ecu in the car.There will be enough wiring to hook the other ecu up.
Also i forgot how long the battery had to be disconected to reset the ecu. Anybody else know?
Old Feb 28, 2007 | 10:13 PM
Riot^'s Avatar
mine was disconnected for about 20min I think.
Old Feb 28, 2007 | 11:11 PM
esdsix's Avatar
No communication with ECU doesnt look good. You may need to check into replacement of the ECU.
Old Mar 1, 2007 | 03:34 AM
nismology's Avatar
For serial? We had no idea...
Old Mar 1, 2007 | 03:56 AM
ObsidianIce69's Avatar
Hey if you need an ecu, i actually happen to have a 98 auto ecu that is laying around it's a US model so don't know if that will throw a check engine light for you or not. If interested let me know.
edit oops just saw you have a 5 speed so it won't matter, no nevermind!
Old Mar 1, 2007 | 07:04 AM
HowlerMonkey's Avatar
A sensor on the car that is sent reference voltage is shorted to ground affecting the ECU globally.
This is why it is running on a limp algorithm and why you cannot communicate with the ecu.
Eventually the power circuit will give up trying to push more current than it was designed for.
Old Mar 1, 2007 | 09:27 AM
nismology's Avatar
IF this is true, how/why exactly does it affect the ECU?
Old Mar 1, 2007 | 09:40 AM
NmexMAX's Avatar
dot dot dot ...
Isn't that why the ECU is nice and grounded with it's beautiful bracket?
Old Mar 1, 2007 | 08:37 PM
Riot^'s Avatar
so you think it's not the ECU that's fried?
what's your suggestion?
Old Mar 7, 2007 | 12:07 AM
Maxima_Joe's Avatar
4th Gen Parts King
Have you gotten it fixed?
Old Jun 5, 2007 | 12:35 PM
goldtooth's Avatar
bump for awaiting update
Old Jun 5, 2007 | 03:29 PM
schreiber117's Avatar
fail safe mode definitely sucks, I agree with above though ecu fried seems fishy, dont mess around too much though, theres a good reason the car is protecting itself, keep us informed, Im curious what happens
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
gigabyte
Jan 6, 2017 06:05 PM
Forge277
Jun 13, 2016 09:26 PM
