how often do you guys get a tune up?
Old Feb 28, 2007 | 09:01 AM
bkmax98's Avatar
My last tune up was 30,000 miles ago and my gas mileage is horrible, so im considering getting a full tune up.
Old Feb 28, 2007 | 09:13 AM
sky jumper
the word "tune up" is a misnomer on modern cars. don't go to a shop and ask for one, they will find every conceivable way to rape you.
just follow the maintenance schedule in your owner's manual and you'll be fine. and take care of problems (such as coil packs and O2 sensors) as they occur.
if you are truly having substandard fuel economy (<17mpg in winter w/ city driving) I'd start by checking the condition of your plugs. black carbon fouling = running rich or leaky injector. folks here will help you troubleshoot from there.
Old Feb 28, 2007 | 11:54 AM
99BlackMaxMS's Avatar
Just change the plugs and filters. If you do not notice a considerable increase then you may want to look into geting new coils/injectors.
Also you may want to change the fluids if you already haven't. Tranny and coolant are probably the most important and if you went all out you could change the power steering and brake fluid as well. This will not help your car get better mpg but it should be done if you haven't in the last 30K.
Old Feb 28, 2007 | 12:10 PM
i30krab's Avatar
Yep, they might even suggest a hi colonic while you're still bending over.
This procedure will be listed as a complete lube job at most dealerships
Old Feb 28, 2007 | 12:39 PM
bkmax98's Avatar
Thanks 99BlackMaxMS.
I think i'm gonna start with the plugs and filters and see how the car runs from there.
Old Feb 28, 2007 | 01:20 PM
metal_god98SE's Avatar
http://web.archive.org/web/200111091...k_service.html
Perform a 60K service and see how it runs from there.... do the simple and most obvious first. If that doesnt make the car improve, then take it a step further into the next most likely variable.
Old Feb 28, 2007 | 03:45 PM
No problem. Keep us updated...
Old Feb 28, 2007 | 07:48 PM
24K on da way's Avatar
I get my tune-up every couple of months mostly 3 or if my car iz runnin sluggish
Old Feb 28, 2007 | 08:31 PM
JwaxMax99's Avatar
Man, that's alot of tune-ups. Every 3 months!!?
Old Feb 28, 2007 | 11:26 PM
esdsix's Avatar
Well if your even due for a tune, use the ngk platinums or iridiums. Mechanic says they last very long time i.e. 80k before next tune-up, could be wrong.
Anyhow, its been 2 yrs of constant driving and mine runs great MAXED OUT!
Old Mar 1, 2007 | 03:12 PM
soseihin's Avatar
Well... as far as spark plugs, the OE plugs were the NGK Double platinums, I believe, but they're $12 a peice anyway, so you may as well go for the Iridiums.
Old Mar 1, 2007 | 03:31 PM
killerVQ30DE's Avatar
I gained a masive 80-120kms per tank by cleaning my air filter, I have a extreme air KN filter which was filthy and I was only getting 420kms to the tanks, I now get 500+kms easily
Starrider
Dec 18, 2015 04:43 AM
dcam0326
Sep 8, 2015 11:02 PM
Maxboy23
Sep 4, 2015 06:04 PM
nbstriker10
Sep 4, 2015 04:26 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
