Ecu
Old Jul 7, 2001 | 02:54 PM
PeteGT2857's Avatar
Hey people, Need help.
This is stupid but...I've a gota engine check light on because i had the dropping resistor off to improve my auto shifting. Well that worked well and for now put it back on. However the light isn't going away. so I went to reset the light, and I can't get the panel off. One website said to twist the srecws and it's off. But my 95 won't come off. I tried unscrewing them, and That didn't work then I used my clip tool to try to pop it off, it won't work either. How the heck does it come off. HELP!!! Thanks people for any help.
Pete
Old Jul 7, 2001 | 03:05 PM
96BLUMAX's Avatar
You twist counterclockwise until the screw is out a little. Then you pop it out. If that doesn't work, use a screw driver and pop the first part then the whole thing. Don't worry you probably won't break it.
Old Jul 8, 2001 | 12:53 AM
CalsonicSE's Avatar
If you are referring to the panel that's to the right of your pedals, just pry those clips a bit and then yank off the whole panel. You won't break anything. Actually you don't even have to pry the clips. Just pull hard and it'll pop off.
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
cruce91
Sep 20, 2015 10:23 AM
QueensMAX
Sep 15, 2015 04:14 AM
