Never replaced brake pads before - should I attempt it?
I've never even done a brake pad job, but I've got my Chilton manual and you guys...lol.
With basic Crafstman tools, should I be able to pull this off on my own?
On a scale of 1-10 with 1 being a 3rd grader can do it and 10 being "take it to a mechanic"...what would you rate it?
Also, time involved? Do I have to bleed the brakes?
You will need a large c clamp to push the front calipers back in, not a basic crafstman set. And a special tool or large needle nose to turn the rears back in.
Front breaks = 1
1st time doing it should take you about 1 1/2 hrs. 2nd time will take you 30-45 minutes. They are that easy. Make sure you follow the chilton step by step.
No you don't hvae to bleed the brakes.
Front breaks = 1
Front breaks = 1
Front breaks = 1
thanks...I'm only doing the fronts myself and I'll have my father-in-law with his Snap-On set help with the backs...
I'm going for it...
I'll either report back all is good or it'll make for a heck of a crash!
When I first started working on cars it took me a little bit of time to do it but now that I've got bunch of experience under my belt, it only takes me about 20 mins from wheel off to wheel on. That includes replacing rotors and pads and cleaning off the hub surface.
i just replaced my front pads and rotors 2 days ago!! i got Ceramix pads and wagner rotors cleaned calipers up nice, Bed'd the breaks and wow what a difference you'll need a 12 mm socket and ratchet for the 2 bolts on the caliper if i recall correctly.. and check to see if your rotors are ribbed or if they are smooth... if ribbed take to local break shop and see if they can turn them and make em smooth. if not spend 160 CDN and get a set of rotors... not regular cheapy's tho
easy to do, but have some one with experience look over your shoulder. it's better to correct the problem before it is really a problem. brakes can save alife or cost one, better safe than..... oh save the beers til later.
Yea man, it is really easy but if you said your father in law knows how than you should have him with you.
You dont want to mess up on brakes. But once you do learn, you will save yourself some serious money.
very easy to do but my suggestion is go to a place where they sell the repair manual like the haynes or chilton and buy it it is a good investment anyway specially for the ones that don't know a lot of mechanic
I just did the front brakes on my 3rd gen and i did not know how to do it but however i did it and i got it working. I am know doing the rear calipers and i know there nothing to play with there very different then the front ones right.?
I also wanted to know if the 4th gens are the same as the 3rd gen comparing the rear calipers if there the same process.
ide say go for it. gotta start someplace right? and pads are pretty easy. just make sure you note where the clips are and everything. youll be fine!
and incase you didnt know, dont put ANYTHING on the front of the pad (where it contacts the rotors)....not sayin youre stupid...just tryin to keep ya safe! haha
EDIT: oh yea, pump the brake pedal back up when youre done BEFORE you drive.
Originally Posted by nearthisbridge
Very easy to do yourself. Pick up a Haynes and the caliper piston tool from Autozone and go to town!
Did it!
The fronts were a snap, and the backs were giving me crap trying to compress the pistons with needle nose pliers. I went and got the loaner caliper piston tool and now I know to ALWAYS get that sucker...what a difference the tool makes.
Rears also had to deal with unhooking the parking brake to move the calipers around, but that was pretty easy.
Fronts = 1 hour total (and this was my first time)
Rears = 3 hours (but include a 45 minute trip to Autozone)
Thanks all!
Hopefully you'll get it down to like. ..hopefully. a 30 min or less job o_o. If you have a car lift like myself. and way better tools. alot less than that.. o_O
Originally Posted by 1Phat Max
You guys say dont push the rear's in? Is this true? I had loadned a tool from autozone and was trying to push the rear's in and it wasnt working. How do i turn them for it to go in?
There should be a slot on the piston that you turn (the whole piston turns).
just make sure u have all the tools b4 u start the job... or else u'll be bussing to part stores...
i'll rate it a 5... i dont think a third grader can do it... but i've seen 3rd graders smoking up these days... so anything is possible...
i got my rears done at a garage... first squeaky noises... and than the e-brake cable seized... i dont think he pushed it back properly... because he was trying all sorts of tools and finally got it in right... i'm pretty sure he fked up b4 it pushed back...
oh, changing the brakes is easy...just don't forget to take break them in. Go up to 20mph, hit the brakes, don't fully stop. then go up n blah blah blah...i forget the exact numbers....but you should be able to find it online. Also, just take it easy on the brakes for about 100 miles or so....still need to get the brake pads properly against the rotor 100%...
Did mine in a papa gino's parking lot in VA. We took are time with the C-clamp went slow. Did it in under 1 hour . Going to attempt rotors next month with a total brake job. We tossed the anti rattle springs which was on the 1999. Do not know if other models have them. I was told just forget them when I do the real job next month. Brembo Rotors /Akebono pads. from tirerack.com was a good deal. good luck
it is real easy. 14mm bolts, two per side. And if you want to replace rotors as well, simple too. Just two 19mm bolts. I did my front rotors and pads last weekend. Took about 45 minutes total. No reason to pay someone big bucks to do something so simple. If you can change your own oil, then there is no reason why you cant change brakes
One thing about the rear brake calipers. They seize up very easy. I learned the hard way. I could not turn the caliper back in for s*** on the drivers side, it was definitely siezed. The passenger side I brute forced it until it started to turn. I thought it was ok I put that side back together with new pads, replaced the caliper on the other side went on my merry way. Well the pass. side seized up and ripped through the pads and rotors. I was too busy to fix it myself and had to take it to the garage ( My wrenching time is limited, due to wife and kids), cost $300 dollars ouch!
So if the caliper pistons in the rear do not turn without brute force or one side is worn more than the other do yourself a favor and replace the calipers, in fact if it's been a long time you may want to replace both anyway to save yourself a headache. Then go have that beer!
break job
you guys are building up my confidence. i have two rear calipers to replace,and i want to upgrade rotors as well.any of you guys know if the autozone calipers are any good? nissan oem way expensive.
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
RealityCheck
Aug 5, 2015 06:18 AM
Definately a DIY job. It makes me mad when I think about how much shops charge for a simple brake job.
. I guess I'll get a bigger one and try again this weekend.
