Problem With Screws On Fog Lamp Brackets
Old Mar 5, 2007 | 06:39 PM
4thgenlewis07's Avatar
Ok, I have to replace the fog lamps and the brackets, and I have the two new lamps and the brackets. While looking at the situation the other day, I am seeing that the screws that are currently holding the old brackets to the car are extremely rusted and look like they will possibly break off when I go to take them off tomarrow. Any ideas on how I should go about doing this? Any input would be greatly appreciated, thanks!!!
Old Mar 5, 2007 | 06:43 PM
SNOMAX's Avatar
PM me for LCA's!
Mine broke on me when I changed out my fog light. I just had to re-drill a new hole in the bracket. You will want to tap the holes or use a bolt, cause the metal of the bumper will strip the bolts.
Other wise, soak them in PB blaster and heat them up. Good luck.
Old Mar 5, 2007 | 06:46 PM
Thanks alot, will be doing this tomarrow mini project tomarrow, Thanks Again
Old Mar 6, 2007 | 12:45 AM
TurTLe*'s Avatar
how did you fit a drill in there?
I got 2 that snaped when i put them in. and well i cant fit my drill in there cause its the rear 2. I was looking for some screw extractors but i haven't had time yet to go do it by hand.
Old Mar 6, 2007 | 05:05 AM
maxprivate's Avatar
Black Lion
it looks like there are three 3/8 bolts that hold the bracket in place. they are located on the top of the bracket. If you have a drill with an Angle bit you should be able to get it in there and a little WD40 might help.. one of my brackets are broken, how much did you guys buy the brackets? and where?
Old Mar 6, 2007 | 05:18 AM
willard00's Avatar
yea thats what i was going to suggest. go for it and if they break off grab some screw extractors and try those. if not than youll have to drill a new hole.
Old Mar 6, 2007 | 06:19 AM
maxprivate...you have pm
Old Mar 6, 2007 | 08:22 AM
Rick James's Avatar
Same thing happened to me when I replaced the brackets on my fogs. I snapped off the bolts and went to a muffler shop and they welded the brackets on for free.
Old Mar 6, 2007 | 09:00 AM
maxprivate's Avatar
Black Lion
nice man you got a good deal.well i'll be attempting mine when ita a little warmer out right now its freezing here!
Old Mar 7, 2007 | 06:07 AM
TurTLe*'s Avatar
thats good and bad, at one point it might just rust to death where u might need to change it out and then u can't but that is " maybe" but good deal overall.
Old Mar 9, 2007 | 05:56 AM
Thanks Again Everyone
BkGreen97
Apr 2, 2016 05:47 AM
03VQMAX
Nov 10, 2015 03:39 PM
followthadollar
Sep 13, 2015 09:55 AM
thenewguyy
Sep 12, 2015 11:12 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
