fuel filter pita - HELP trying to replace
Old Mar 24, 2007 | 12:33 PM
  #41
buzpuck11's Avatar
Originally Posted by andrei3333
can some one help please, i cant get the hose off the top of the filter
it seems to have seized on it, and even if i do get it off it seems impossible to get to the bottom hose cause its probly seized too
i took off the evap hose and the iacv hose and got more room but my car has ABS and the metal lines are blocking my way
i can put one hand on the filter and another on the top hose, but its not coming off, it streches and looks like i can rip it, but its not coming off the nose of the filter
what should i do ? i dotn wanna cut anything away
Removing the air intake/MAF provided me much necessary room when I changed my filter. Use a flathead screwdriver to pry the hose off. You just need to be patient and use the screwdriver to break the seal. Then twist and pull once the seal is broken. The bottom hose is easier.
Or you could get a pair of pliers and crush where the hose connects to the filter, or just cut the hose.
Old Mar 24, 2007 | 01:05 PM
  #42
2da mizzax's Avatar
take a small flathead. pry it at the tip of the hose. twist it to break the seal (you will hear/feel/see the seal rbeak). then pull like no tomorrow. Put some lube on the new one so this doesnt happen again.
Old Mar 24, 2007 | 01:28 PM
  #43
Cdg2125's Avatar
wow everyone has some many problems with the fuel filter. It's not that hard to change. It is a weird grip but you should really have that many problems.
to 2da mizzax, Small flathead is the best because its easier to get between the filter and the line to let that pressure out. Just stay with it and put some strength into it.
Old Mar 24, 2007 | 02:23 PM
  #44
andrei3333's Avatar
ok i just took a big break cause i was about to rip the hoses into another dimension cause i got angry, i just read all ur great comments and will try to use a flat head screw driver next, its getting kinda cold in the garage so i might leave it tyll tomorro
here is a shot of the new fuel filter (its a 1996 300z Twin turbo filter part # 16400-N7605) still not opened cause if i cant get the hoses off im gona return it to the dealer, i never thougt it would be this big, but if i do change it im never doing this again myself
Old Mar 24, 2007 | 03:29 PM
  #45
andrei3333's Avatar
ok great, the flat head screw driver method works, i got the top hose off, now i already unscrewed the bottom screw almost all the way , slid the clam down all the way but did the same screw driver method on the bottom hose, it came off HALF way, i can see the shiny metal that was under the hose, but i still cant get it fully off
thig bugger is trying the limits of my patience
Old Mar 24, 2007 | 03:33 PM
  #46
buzpuck11's Avatar
Twist and pull......HARD
Use one hand to hold the hose while you yank on the filter.
Old Mar 24, 2007 | 03:53 PM
  #47
Cdg2125's Avatar
just got the hose if you need
Old Mar 24, 2007 | 04:04 PM
  #48
andrei3333's Avatar
im exhausted, the more i try the less power i have left, its almost half way off the bottom, i can barely get my hands in there and my lower back starts to kill me now
i really dont want to cut the inch of that hose
Old Mar 24, 2007 | 04:05 PM
  #49
buzpuck11's Avatar
Get pliers and crush the metal part of the filter that is still stuck in the hose.
Old Mar 24, 2007 | 04:19 PM
  #50
Cdg2125's Avatar
why dont you want to cut it? Take cutters and cut right at the bottom of the metal. Takes two seconds. Not like you'll run out of hose or something.
Old Mar 24, 2007 | 04:20 PM
  #51
2da mizzax's Avatar
that will cut the hose. just twist pull and remember to lube the new one. once it starts moving it is simple from there.
Old Mar 24, 2007 | 05:57 PM
  #52
andrei3333's Avatar
I GOT IT , I FINALLY GOT IT , OMG
You guys would have laughed ur ***** off if u saw what i was doing at one point, i was sitting on the engine itself yanking the darn thing out.
THANK U GUYS i owe u a case of beer EACH, thanks for the help i could not have done this without the great and mighty .org
the deposits on the bottom of the bottle are unbelievable, this came out the IN side of the filter when i shook it, there seem to be some kind of particles that are on the bottom of the bottle, did this come from the tank or the gas ? it seems impossible that this came from the gas, most likely its some pieces of the inner tank or something like that
here are some shots :
Old Mar 24, 2007 | 08:13 PM
  #53
PLUMMAXSE's Avatar
Glad you got that bugger out!! I'm surprised you have any fuel pressure with that gunk in the filter. You should be good for a while with the ZX filter!
BTW, I replaced mine with the 300ZX filter, thanks for this thread!!
Old Mar 25, 2007 | 10:51 AM
  #54
JPMax's Avatar
What's next!?..
dANG..How long has that filter been on there??! Never seen one that rusted and filled w gunk.
Old Mar 25, 2007 | 11:04 AM
  #55
andrei3333's Avatar
car got 211.000 KM on her now, so i think its safe to assume its never been changed ? !!!!
here are some shots of the gunk that sat overnight, the deposits on the bottom are of a sandy nature, but they are very very fine particles, i am curious what they might be...
00MAXI
Sep 2, 2015 10:23 AM
305head
Aug 26, 2015 09:03 PM
homewrecker
Aug 24, 2015 08:56 PM
kirkhilles
Aug 8, 2015 10:53 AM
maxima297
Aug 3, 2015 12:50 PM
