Testing Coils
Old Mar 15, 2007 | 06:08 AM
spadez911's Avatar
Testing Coils
hey what is the best way to test which coil on my car went bad cause its thrwoing a code for multiple cylinder misfire??
Old Mar 15, 2007 | 06:48 AM
willard00's Avatar
switch the coil in the cylinder it says and see if the code changes to the cylinder you moved that coils too. you can also buy a spark tester for $10. you just place it on the top of the coil and if it lights up then there is spark.
Old Mar 15, 2007 | 07:27 AM
heynow's Avatar
sweet i didn't know there's a tester, is it accurate?
Old Mar 15, 2007 | 07:32 AM
willard00's Avatar
ide assume so. since if it detects spark, it lights up in the middle, and if theres no spark it doesnt light up
theres also another tester that looks like a spark plug (also called a spark tester) which i prefer over the stick type. all you do is pull the coil out, put it on the tester (like a coil fitting over a plug) and then clip it to a ground. then start the car and look at the tester. if it sparking then the coil is good.
EDIT:
spark plug type tester: http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
'stick' type tester: http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
Old Mar 15, 2007 | 07:36 AM
sky jumper
does the car run rough yet? most dealers will tell you to continue driving until the car runs rough, then it will throw the code for the exact cylinder. you may want to buy a coil now and be ready to swap it out when that happens -- you don't want to drive long with a misfiring engine.
if the car runs fine, idles fine, then swapping coils around will not help isolate the bad one -- and it may not be a coil at all (many potential causes for a multiple cylinder misfire).
Old Mar 15, 2007 | 07:38 AM
heynow's Avatar
sweet, would you happen to know where we can find it? Surely it would be a useful tool for us all
Old Mar 15, 2007 | 07:43 AM
DJ420's Avatar
Bad Mother Fornicator
If you need coils, let me know soon! I only have 3 left, but they are brand new OEM Nissan in the box, unopened. 2 for 1 bank, 1 for the other. I am selling them WAY cheaper than your Nissan dealer, and they are the updated #s! I have sold QUITE a few on here, all happy customers. You cant beat OEM new and at half price! Like I said, only 3 left so let me know asap! $60 SHIPPED each, or $155 SHIPPED for all 3!! Paypal: dj4twenty@***.net
DJ
Old Mar 15, 2007 | 12:03 PM
heynow's Avatar
Thanks, willard00
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
