CAMs for a 4th gen...
When I was at dark nights in canada waiting in line for tickets the guy behind me was talking about his maxima and how he just ordered cams from some place in CA. I told him that I didn't think they existed for the maxima. Are there any, do they help?
Well when you told him that you didn't think they existed what did he say? Did he shut up or did he say what place it was he was ordering them from or who the manufacturer was, or was he just spouting BS?
Originally posted by GTRBlkMax97
I would love to get some cams for my ride, I think they would make a big difference in accel.
I'm skeptical about performance cams for the 4Gen Maxima. I believe there are none because the cam grinder companies have been unable to improve on the factory design.
I was doubtful that they existed, but he was an older guy (30ish) and what do I know about cams?? anyway, he didn't even know about maxima.org so who knows if he is just talking. I agree with Daniel!
Originally posted by yohann
If the cams can't be improved on does that also mean the exaust, intake and ecu can't be improved? ...
Some factory parts seem to be already optimized. One example is the exhaust manifolds. Don Cooper ("Don in Texas" of Valve Body Modification fame) tested a pair of beautifully ported and polished exhaust manifolds and discovered the gain was almost zero. On the one hand, that is a disappointment. On the other hand, it is evidence that the Nissan engineers did a good job on that component. For all the details, go to http://forums.maxima.org/showthread....&postid=293547
Originally posted by Daniel B. Martin
Can you explain why? How would you want aftermarket cams to differ from the factory units? Higher lift? Longer duration? Increased overlap? Different lobe profile? Something else?
No, it does not mean that.
mmm, maybe they were custom cams? i have custom cams done on my turbo motor, but turbo cams are different then NA cams. I belive the stock cams can be improved on in terms of power, someone has to play around with different setups to find what might be best for the VQ. I dont think Nissan put the most aggressive cam profile in the VQ. Simply because other things besides power must be done in cam design. Emmissions, Idle smoothness, and powerband to name a few. Some Drawbacks of more aggressive cams, They may create bad idling, more emmissions, and less low end power.
I have to agree, especially with the purpose the VQ was originally designed for...
Turbo95Max
Dan. The Sentra SER is a good example on how stock cams can be improved on. There's a euro spec cam that works well and JWT developed a set of cams for the ser that are really nice. The difficult thing w/ cam developement now is that they must be able to pass strict emissions, idle well and people demand hp from 2000 up to redline. It's very expensive to develope cams and it's very expensive to get cams ground on new Nissan blanks(the only right way IMHO) From what I hear, Nissan uses conserative grinds on the VQ. This would partly explain the nice torque curve down low and the tendency for the VQ to run out of breath by 5,500 rpm or so. IMHO, the VQ could use alot more duration and a little more lift. This would keep the valves outa the piston's way and the VQ would get the breathing it needs up high. Of course some of the low end torque goes away but it already has massive torque down low.
Anyone can get cams
ISKY or crower will regrind any cam to the specs the buyer specify. The thing is that regrinding an already worn cam, isn't worth the trouble most of the time. So you would have to buy some new core cams from nissan. This means buying both intake and exhaust cams. The cams probably cost around $150-200 each, then its $150 to regrind them. Basically your spending close to $1k if not alittle more to do some cams. Now ISKY does have several grinds that have good results in the VG30 engines. With alittle R&D there is no doubt a good set of cams can be made. Don't forget to install these cams the intake manifold will have to be removed. So if you don't do the labor yourself, it would probably cost around $2k for the R&D + install labor. So do some research.
(Yeah people, NOS helps too but it's not always available)
Well, you can get cams if you are willing on paying the price. JWT has done a few sets of re-welded stock cams. They were made for some racers. The cost is $2-3K a set, but I did not get a final price. Plus, you have to get a complete set of heavier valve springs. The stock valve springs float with the higher lift. They have done a couple different grinds, but are trying to lock into a set for production billets and that can pass emissions. They are planning to sell the billet versions when they come out for $1-2K a set.
mitch33x,
they cost me $600 for all 4. I dunno what they regularly charge people tho. We are planning for 420-450hp when the new motor goes in. Havent run the 1/4 yet. The world of racing is not based on 1/4 times.
I had talked to Webcam about this, this is who DPR uses for cams. The said it would cost 250 per cam to make the blanks and 150 to grind them. So thats ~800 for the set. That leaves the question of the profile...
CAN-Toronto 97 SE BLACK w/ BLACK. PART OUT.
worldwiderecognized
Sep 24, 2015 06:56 PM
ik95
Sep 16, 2015 08:11 PM
