AC compressor
Old Mar 24, 2007 | 08:24 AM
LeVeL's Avatar
AC compressor
Apparently its not as simple as it may seem to find an AC compressor for a 97. This is what I am asked:
thru 11/96
from 12/96 thru 4/97
5/97 only
Grr. 1) I am assuming that it does matter which one of those three I get? 2) How do I check when exactly my car was made? Thanks
Old Mar 24, 2007 | 08:34 AM
LeVeL's Avatar
My second question (on checking the manufacture date)...
Originally Posted by Wills98MaxSE
You should also check the manufacture date on the driver door jamb
Im getting there...
Old Mar 24, 2007 | 12:53 PM
99BlackMaxMS's Avatar
To answer the question....open up the drivers door and look on the body of the car right above the door latch. Sticker is right there...tells you the manufacture date, VIN #, and a bunch of other stuff.
Old Mar 25, 2007 | 07:30 AM
LeVeL's Avatar
Thanks 99BlackMaxMS. Anyone got an aswer for my first question?
Old Mar 25, 2007 | 07:38 AM
sky jumper
first -- what is wrong with your compressor? is it seized, or just noisy? if it's just noisy you can probably fix it without replacing the whole thing -- pulley bearing. see the maintenance sticky.
second -- you can get down under there and write down the info off the compressor to make sure you get the right one -- but in terms of replacement units, I don't think it matters, but I can't say for sure.
Old Mar 25, 2007 | 08:35 AM
LeVeL's Avatar
Compressor is dead and has to be replaced
Old Mar 25, 2007 | 08:38 AM
loverholic's Avatar
iAMIXAM!
are yall saying that that loud clicking that my compressor makes every time it goes on and off can be fixed?.........carry on fellas..... to the stickys i go
05' MaximaMan
Oct 8, 2017 06:36 PM
mclasser
Sep 24, 2015 11:57 PM
homewrecker
Sep 24, 2015 07:01 PM
pears
Sep 18, 2015 05:25 AM
