For those with an Air/Fuel Gauge...
Old Mar 26, 2007 | 12:28 PM
petemo95se's Avatar
when you are driving steadily down the road with the foot on the throttle, is the gauge sweeping, constantly from RICH to LEAN every second or so? Is this normal operation? Or should it be relatively in the STOICH range?
A friend just installed his and it really becomes annoying, but it didn't seem natural to be sweeping that much.
Thx.
Old Mar 26, 2007 | 01:00 PM
nismology's Avatar
Hooking an a/f gauge up to the stock o2 sensors is useless because they don't tell the ECU what the a/f ratio actually is, just whether it's rich or lean. Basically, they play Pong with the a/f ratio bouncing from lean to rich and back in an attempt to stay in the middle. This is where a wideband o2 sensor comes in, which is what you need to make any a/f gauge worthwhile.
Old Mar 26, 2007 | 01:04 PM
NmexMAX's Avatar
dot dot dot ...
I'll go ahead and to that before the OP asks 'Anyone else?'
Old Mar 26, 2007 | 01:28 PM
Apparition's Avatar
Ichiban King
Yeah, I mean cause you and your infinite wisdom make up for the 20 posts to follow.. lmao
Old Mar 26, 2007 | 01:31 PM
ethnic6's Avatar
how hard is it to hook up these gauges? and what would u usually want to measure (sorry for jacking the thread since the question has already been answered)
Old Mar 26, 2007 | 02:10 PM
NmexMAX's Avatar
dot dot dot ...
Signal is from the O2 sensor, main wiring harness, or spliced from the actual sensor itsefl under the hood.
but please read this again.
It's voltage translated to AFR. But using NB O2's, is not worth it unless you enjoy watching Pong tournaments.
Old Mar 26, 2007 | 03:24 PM
Apparition's Avatar
Ichiban King
I love BEER PONG.
Old Mar 26, 2007 | 03:40 PM
GoalieKeg's Avatar
But I like how it lights up!!!
Old Mar 26, 2007 | 03:53 PM
nismology's Avatar
Old Mar 26, 2007 | 03:56 PM
97PKIMVQ's Avatar
I don't even pay any attention to mine now. At first it was annoying until it slowly went away out of my vision. same with my oil psi gauge.
Old Mar 26, 2007 | 04:47 PM
Narrow Band A/F FTL. Freakin' worthless. Enjoy the light show.
Old Mar 27, 2007 | 08:14 PM
MikeSDA's Avatar
true. narrow band 02 sensors are good for nothing. Generally they will only read rich at WOT and bounce around the rest of the time
PLX makes a very nice affordable 2 1/16" gauge WB02 set up where the blinking lights will actually be of some true value with the A/F digitally displayed in the middle.
Old Mar 27, 2007 | 08:41 PM
NmexMAX's Avatar
dot dot dot ...
Gauge, yes, but you need a wb to get the actual data in order to display anything.
Old Mar 27, 2007 | 10:00 PM
willard00's Avatar
wait im a little confused....are you saying that the rich/lean switch is not normal? because if so you couldnt be more wrong. any good o2 sensor (doesnt matter if its zirconia, wideband, or whatever type of sensor) will always switch from rich to lean. if it does not it is bad and should be replaced.
anyway, those gauges are dumb anyway. waste of money IMO.
Old Mar 27, 2007 | 11:51 PM
90stanza's Avatar
Ha my brother and i invested in a a/f gauge, A pillar pods and water temp gauge back in the day when we shared a car. I guess you can say it was the most annoying pointless mod we ever did. The temp gauge stopped working three months after we got it. The gauge will bounce back and forth when driving and go to full rich when ever the car is warming up or when you are at WOT. If you want somthing to mess with your eye sight at night then get them.
Old Mar 28, 2007 | 06:39 AM
NmexMAX's Avatar
dot dot dot ...
Old Mar 28, 2007 | 06:45 AM
ethnic6's Avatar
if u were to choose, what would u use a gauge to measure, I'm thinking about putting some in my car... but not sure which one are the most useful
Old Mar 28, 2007 | 06:54 AM
nismology's Avatar
A little too eager to correct someone, eh?
The first few words i said, "Hooking an a/f gauge up to the stock sensors is useless." That sums what i'm saying up.
And anyway, a wideband o2 DOES NOT switch from rich to lean and back like narrowband o2's. Like i said earlier, stock narrowband o2's don't tell the ECU what the a/f ratio is. They only know 2 words, rich and lean. Rich is a 1V signal, lean is a 0V signal, and stoich is where the rapid jump between the two occurs. Fairly imprecise. A wideband on the other hand, is designed to output a voltage for EVERY a/f ratio accurate to .xx AFR. This is why all ULEV vehicles have WIDEBAND o2 sensors from the factory. They call them a/f sensors in this case.
Cliffs: I never said the oscillation between lean/rich was abnormal for a NB o2. Dunno where you got that from...
Old Mar 28, 2007 | 06:57 AM
NmexMAX's Avatar
dot dot dot ...
Depends on what you're doing.
What is in there now is good enough for the average driver.
A little to eager to correct someone, eh?
I was waitng for that one
& cliffs included.
Old Mar 28, 2007 | 12:44 PM
Chief Brody's Avatar
Actually it will and it does. The slight rich to lean cycle is actually happening and will be picked up by both narrow and wide band o2s. ECUs do this becuase some reactions in the catalyst perform at optimum slightly rich of stioch while others happen best slighly lean.
The larger point is valid. Get a wideband to see accurate AFRs outside of stioch.
Old Mar 28, 2007 | 12:56 PM
nismology's Avatar
I guess i have to explain my position all over again.
My point is, NB o2 sensors speak only in terms of rich, stoich, lean. WB o2 sensors speak in terms of actual AFR. The ONLY reason the AFR oscillates back and forth in closed loop is because NB o2's are relatively imprecise, period. ULEV and SULEV vehicles have WB o2's from the factory because they can dial in a specific AFR without having it bounce back and forth indefinitely. And I never said WB o2's won't pick up the switching from slighly rich to slightly lean. They pick everything up. Missing the point by a mile...
crewchief264
Jan 26, 2003 08:11 AM
MAX420
Dec 31, 2002 05:31 AM
maxperformance
Oct 15, 2002 11:23 AM
ny96max
23
Aug 1, 2002 10:41 AM
max'n out
Jan 4, 2002 09:12 PM
