Last time: PRCAI?
Old Mar 26, 2007 | 07:17 PM
semaj3708's Avatar
FEELS GOOD TO BE GANGSTA
Last time: PRCAI?
Okay here's the problem, I just bought a PRCAI from someone here on the org. I know how to hook it up, but I don't know EXACTLY where to drill the hole. I've searched and searched, found several pics of installed PRCAI, even read how to install. But none depict exactly where to drill. I know to remove battery, wire harness, etc... but my problem once again is where EXACTLY to drill. If someone (and I know there are several of you out there) could give me a close-up picture(s) It would be helpful thanks. PLEASE I don't need round about directions I'm looking for a picture of the hole drilled into the fender.
Old Mar 26, 2007 | 07:28 PM
Wassup2114's Avatar
Your best bet would be to get the midpipe hooked up and figure out exactly where your filter is going to end up and mark it. Where someone else drilled might not work exactly for where your filter will need to go.
Old Mar 26, 2007 | 07:40 PM
TurTLe*'s Avatar
i remember seeing a temp plate. that you should be able to print and lay out and of course drill =P
Old Mar 26, 2007 | 07:51 PM
Gismo-T's Avatar
B!tch We Got a Problem
If you'd like, I could trace mine & send it to you.
Btw: It's a 3 1/4 hole saw that you use.
Let me know I have all the paper work too.
Old Mar 26, 2007 | 08:12 PM
Neo Raven456's Avatar
Yeah I have a template for it too
Old Mar 26, 2007 | 10:09 PM
Apparition's Avatar
Ichiban King
Dude, some guy had it on his website.. Dammit can't remember.
Old Mar 26, 2007 | 10:12 PM
NmexMAX's Avatar
dot dot dot ...
I got it from Cattman himself, PDF file.
Try emailing him.
Old Mar 27, 2007 | 05:11 AM
maximized98's Avatar
Addicted to the Org
i also need a template
Old Mar 27, 2007 | 09:30 AM
loverholic's Avatar
iAMIXAM!
i didn't use a template..... my cuz who is also a fellow orger did it for me.... there is a lil hole right where the pipe is suppose to go down.... about a 1/2 inch hole.... we just used that lil hole to align the 3' hole cutter and cut through... don't know if that was right but it worked for both of our cars
Old Mar 27, 2007 | 09:39 AM
phenryiv1's Avatar
Mod her. Ate her.
Remember, this is held together by flexible couplers. It is best to keep things linear, but a little off in one direction or the other won't kill you.
Also, the really flexible rubber door edge protectors can be used to go around the hole that you have cut to help hold the pipe in place and to reduce rattling.
Old Mar 28, 2007 | 02:53 AM
semaj3708's Avatar
Thanks for the input, I'll try to email Brian. If that falls thru Gismo-T or Neo Raven I might have to solict your help, once again thanks.
Old Mar 28, 2007 | 03:11 AM
TurTLe*'s Avatar
someone should be able to host up the .pdf somewhere.... for future people
Old Mar 28, 2007 | 06:50 AM
phenryiv1's Avatar
Mod her. Ate her.
I'll host it if someone gets it.
Old Mar 28, 2007 | 07:27 AM
loverholic's Avatar
iAMIXAM!
thats what we did, but we used a rubber with a smaller diameter though.... we used one that was about the size of the overflow hose for the radiator.
Old Mar 28, 2007 | 11:13 AM
semaj3708's Avatar
phenrtyiv1- I got the info from Brian. Sent a PM to get this hosted.
Old Mar 28, 2007 | 11:20 AM
phenryiv1's Avatar
Mod her. Ate her.
Originally Posted by semaj3708
phenryiv1- I got the info from Brian. Sent a PM to get this hosted.
Sent. tenchar
Old Mar 28, 2007 | 03:55 PM
If there are any more questions on where it is located, I was changing my air filter today and just took the whole system out to give it a once over (Forgive my dirty bay):
Old Mar 28, 2007 | 08:11 PM
buzpuck11's Avatar
Do any of you with a CAI worry about hydrolock? Do you have any troubles driving in the rain or do you avoid wet weather all together? Using bypass valves? I am thinking about a CAI, but am a little worried about the possibility of hydrolock.
Old Mar 29, 2007 | 01:41 AM
loverholic's Avatar
iAMIXAM!
driving in the rain is no big deal... the filter it to high to get wet unless u driving on flooded streets like me... last week i drove right into this huge puddle of water, it was more like a pond in the street, about a foot deep and water splashed onto the filter and the car shut down... but thats only because i tried to use a flooded street and i didnt see how high the water was..
Snoop
Mar 4, 2002 05:00 PM
Y2KevSE
62
Mar 3, 2002 05:04 PM
sleepermax
Feb 11, 2002 02:36 PM
jayc5627
Mar 31, 2001 08:43 AM
