NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
Old Aug 16, 2009 | 08:09 AM
  #4481
JoeyMax96's Avatar
Originally Posted by pmohr
Again, if you're not making a thread, let's not use the title for any relevant or important information.
What brake sensor? You mean for ABS?
What do you mean by 'brake system'? That could mean anything with the brakes.
Could you point it out on a diagram? Better yet, take a picture?
The brake pedal is hooked up to a sensor and it has a rubber stopper connected to it but it dry rotted.. so I need to get a new one but dont know where to get it.
Old Aug 16, 2009 | 08:12 AM
  #4482
pmohr's Avatar
No more Maximas...
The rubber stopper for the brake light switch?
46584-S0100, $2.11 each at Courtesy
Shouldn't be much more at your local dealer, or you could just go to a junkyard and pull one.
Old Aug 16, 2009 | 08:17 AM
  #4483
JoeyMax96's Avatar
Once again pmohr you are the man!! thats it!
Old Aug 16, 2009 | 08:35 AM
  #4484
JoeyMax96's Avatar
Pmohr if youre ever in Miami Let me know im buying you some drinks.
Old Aug 16, 2009 | 09:56 AM
  #4485
maxima 21's Avatar
How did it just disappear?
Are you sure it's the water pump drain plug? Is it gushing coolant?
I believe it's a 12mm head, so that would make the threads (assuming it's standard) 8x1.25.
Or you could just get the part from a junkyard car, the classifieds here, or Nissan:
11051-31U02, $3.70 each at Courtesy
Seriously?
First, why would you buy the engine before you knew how to do the swap?
Second, have you searched at all? Even a little bit? The complete step by step instructions are openly available. Hell, there are several stickies about this sole subject.
And many people have done the VQ35 swap.
Are you looking for a full swap, or hybrid? A 'jumper wire' for the ECU? What does that mean? Get a new ECU...which ECU? You don't plan on this being plug and play at all, do you? If so, you're going to be very disappointed.
i knew it was possible... i just didnt know how much money i would be spending to make it happen. thats why i bought it, and non the less, considering what i paid for a motor and trans, i can turn it over for a lot of proffit. i have done some research but not much. i have a full time job a part time job and i am a full time engineering student, i dont spend day in and day out on the computer lookin at "how to's". im 18. i dont know the ins and outs of cars. i know enough to keep my car running and i know enough people who can help me with what i dont know. just lookin for advice. and to be honest, you are no help what so ever. there is a way to say the same thing that you did without being an @$$ about it. think befor you speak. you are plain rude and a worthless excuse for a person... but it really does show the kind of charactor you have. pathetic.
Old Aug 16, 2009 | 09:58 AM
  #4486
maxima 21's Avatar
Seriously?
if anyone other than this guy can help me im still looking for some info.
Old Aug 16, 2009 | 10:02 AM
  #4487
pmohr's Avatar
No more Maximas...
Do you need to spend 'day in day out'? No, if you actually look for the information, it will take less than 30 minutes to find it and read all the way through, as well as reading the rest of the thread for all of the related questions that have been posted.
Think before I speak? If I didn't think, then my posts would come out unintelligible, with spelling and grammatical mistakes as yours have.
Worthless excuse for a person? Sure.
What is a 'charactor'?
Evading the profanity filter isn't looked well upon around here. No reason to be all childish using symbols instead of letters.
Originally Posted by irish44j
This is not elementary school and evading the profanity filter in open forums is neither funny nor permitted here. Take a week off and think about that.
Anyway, just another douche to add to the ignore list; if you're looking for help, you don't insult those that can help you. Had you been civil, yes, I could've given you all of the links you need to find out what you asked.
If you actually do some research, the information is quite easily available.
This guy can help you - http://tinyurl.com/km2f44
If you don't learn how to search, you won't make it very long around here.
Old Aug 16, 2009 | 12:00 PM
  #4488
strocket's Avatar
Is there any way of checking to see if the water pump is bad? I think I found the source of the water gushing. The black inner o-ring was broken. I don't want to replace the water pump if I don't have to. How can I check to make sure its still working?
Old Aug 16, 2009 | 12:04 PM
  #4489
pmohr's Avatar
No more Maximas...
You can check for play in the impeller shaft, but other than that there's no good way. Generally it is just the seals that fail.
You could throw new seals on it and hope that it doesn't leak, which it probably won't. Most opt to replace the entire pump due to it's location and relative inaccessibility.
Oil o-ring:
21049-31U04, $4.21 each at Courtesy
Coolant o-ring:
21049-31U03, $4.21 each at Courtesy
Old Aug 16, 2009 | 12:15 PM
  #4490
99sidude's Avatar
Hey everyone I've been lurking on this site for many years. I own a 96 se 5mt. My brother has a 93 se 4at. I'm having a missfire problem with the 93.
Symptoms:
-Power loss and missfire apparent when in drive. As the car warms up, the missfire gets worse. NO CEL's
-Problem has gotten worse and worse as the months went by. A gradual change in performance.
-Coil packs are good. All have perfect resistance and I checked for spark.
-Coolant temp sensor, and tps were checked, all good.
-The MAF isn't outputting any voltage. That makes me think it's bad. The weird thing is that there's no CEL and the car isn't in limp mode (i can rev it as high as I want).
-I suspect the injectors, but the front 3 I know are good (hard to test rears). I inspected all of the spark plugs and cannot see any differene in condition across the board.
Ay ideas?
Old Aug 16, 2009 | 12:17 PM
  #4491
pmohr's Avatar
No more Maximas...
Symptoms:
Ay ideas?
If you're having a problem with a third gen, why are you posting in the 4th gen subforum?
The 3rd gen section has a newbie thread as well, and you'll find many more people familiar with the VE there than you will here.
Old Aug 16, 2009 | 12:22 PM
  #4492
maximized98's Avatar
Addicted to the Org
This thread should be renamed to "noobies, ask pmohr a question, he has an answer"
Old Aug 16, 2009 | 12:26 PM
  #4493
99sidude's Avatar
My bad guys. I'm always browsing this one because my car is a 4th gen.
Old Aug 16, 2009 | 03:45 PM
  #4494
Addicted to the Org
It's ok. I was not saying you are doing anything wrong. I was just saying that pmohr is the king of this thread, and his knowledge should be noted.
Old Aug 16, 2009 | 05:34 PM
  #4495
strocket's Avatar
Ok, so now im really stumped. Replaced the seals on the pump reinstalled it and its still gushing out. Even with the car off. I pour a jug of water in the radiator and as fast as I pour it in it keeps pouring right back out. What else can I do?? Anyone have any other ideas? Could the water pump itself be the problem? Please help!! Im running out of daylight
Old Aug 16, 2009 | 05:37 PM
  #4496
pmohr's Avatar
No more Maximas...
It's pouring out of the same water pump drain area?
Yes, if the bearings on the water pump are damaged enough, it could leak right through the shaft area and out of the weep hole.
If not the pump itself, it's always possible that the sealant on one of the timing covers is damaged and coolant is leaking past there.
Can you take a picture of exactly where it's leaking from, or better yet a vid?
Old Aug 16, 2009 | 05:38 PM
  #4497
strocket's Avatar
Yeah let me see what I can do... will i be able to post a pic on here even tho I dont have 15 posts?
Old Aug 16, 2009 | 05:39 PM
  #4498
pmohr's Avatar
No more Maximas...
Yes, you can post pics here regardless of post count.
Old Aug 16, 2009 | 06:22 PM
  #4499
strocket's Avatar
Old Aug 16, 2009 | 06:23 PM
  #4500
strocket's Avatar
woah!! lol feel free to resize!!
Old Aug 16, 2009 | 08:13 PM
  #4501
pmohr's Avatar
No more Maximas...
How would we resize an image you have hosted offsite? You need to resize or delete it, it's far too massive to link inline. At the least, just a link to it.
Did you have the pump fully installed at the time? It seems to be too far out in that picture. I'd pull it back out and check the o-rings again, one may have been torn during installation.
Failing that as I said it could be a very bad pump or leaking timing covers.
Old Aug 16, 2009 | 08:49 PM
  #4502
strocket's Avatar
I seated it as best I could. I felt it "click" in. Also the bolt are snugged pretty tightly. I guess ill just have to try putting in a new pump and seeing what that does. If I still get the same thing whats next? If the time cover was leaking wouldnt I have oil in the crankcase?
Old Aug 17, 2009 | 03:42 PM
  #4503
bassmann's Avatar
1997 Maxima unknown leak location.
I have a leak. I jacked up the car and was trying to locate leak. Got up for a second jack broke car fell on rotor. I'm alive and writing for help. It looked like it was coming from under the belts but higher then the oil filter. Maybe some kind of seal? Fluid running down inside of left tire. Brake fluid level looks good same for power steering and oil. I had a recall on the car for an alternator in 2006 and they also replaced crank seal maybe it is leaking again? Where is that located?
Old Aug 17, 2009 | 04:08 PM
  #4504
Jose96MAX's Avatar
I have a question on my 1996 Maxima, My check engine light came on i got it checked and came back with both o2 sensors bad, What are the bad's with driving your car besides the bad gas milage, the idle is kinda bouncy while at stop light, and i can feel the engine vibrating with a 1 second pause..and keeps going!, runs good tho!
Old Aug 17, 2009 | 06:23 PM
  #4505
JoeyMax96's Avatar
elctric radiator fan blowing wrong way; how do i correct the direction?
Old Aug 17, 2009 | 06:47 PM
  #4506
strocket's Avatar
OK guys, got the leak fixed, everything is back together. Went to start the ***** and I have a knock thats coming from the top of the timing chain cover?? Is that normal? Remedies?
Old Aug 17, 2009 | 06:58 PM
  #4507
pmohr's Avatar
No more Maximas...
Err, you should have oil in the oil pan. Do you mean coolant? If so, not necessarily.
The left tire is nowhere near the belts, it's at the end of the trans. Do you mean the right (passenger) tire?
If so, have you actually checked the fluid to see what it is? That'll narrow it down.
The O2s are not at all likely to cause idling issues. Your problem is most likely a coil going bad.
Have you done any modifications at all to that system? Are you sure it's going the wrong way?
It's normal for the chain to make some noise during initial startup due to the tensioner being dry, but it should go away in a few minutes.
Old Aug 17, 2009 | 08:30 PM
  #4508
nodora97's Avatar
I am upgrading my interior (97 gle) with a 96 i30. Black leather and woodgrain, and both seats are powered. Stock passenger seat is manual but i see a harness leading up under the seat. My question is if i plug that wire into my new (used) seats will they be powered? Or is it for something else? THX
Old Aug 17, 2009 | 08:32 PM
  #4509
pmohr's Avatar
No more Maximas...
Some are prewired for power seats. Try it and see.
Old Aug 17, 2009 | 08:34 PM
  #4510
strocket's Avatar
Thanks pmohr!! We have success!!
Old Aug 17, 2009 | 08:37 PM
  #4511
nodora97's Avatar
Thought so thanks!
Old Aug 17, 2009 | 10:31 PM
  #4512
JoeyMax96's Avatar
The fan is blowing towards the engine. My car only heated up on the highway on hot days but now its heating up on highway even at night. At a stop it doesnt overheat. What do you think?
Old Aug 18, 2009 | 03:20 AM
  #4513
pmohr's Avatar
No more Maximas...
You realize that if the fan blew towards the radiator, it would be going against airflow while driving?
That's the proper direction, to pull air through the condenser and radiator.
Old Aug 18, 2009 | 09:17 AM
  #4514
JoeyMax96's Avatar
Okay. Well why does it overheat on the highway and not the city? Should i get my radiator flushed?
Old Aug 18, 2009 | 07:52 PM
  #4515
nodora97's Avatar
Tire choice
Originally Posted by wcs1885
i have a 1996 nissan maxima se. i have to get all 4 of my tires changes since it's really bad (been almost 3 years since i changed them). I currently have Goodyear Integrity P205/65R15 92S on them. I just need an "every season" tire that's under $100 a piece. Does it matter if the size of the new tire is slightly different (ie: P215/600R15) or if I go with a P205/65R15 92H? Also, I've always been a fan of Goodyear. Any ideas on what other brands are good but doesnt break the bank?
First off i work at dtc, you can go with the other options because 215/55/16 is not the most common. And were dealing with mm here so not that big of difference. Goodyear is a great brand but you have their lowest quality tire. If you want to stay with gy's i would prefer the gt, its a newer style and it has awesome performance, another tire i recommend is yokohama (yk520). The part about breaking the bank remember you get wat you pay for. I have had both of these tires on my personel car.
Old Aug 19, 2009 | 06:48 PM
  #4516
ppena1076's Avatar
1999 I have question front bearing problem
I have a 1999 nissam maxima i just replaced the front bearings and it makes noise when i turn the wheel and the noise came back again what can it be
Old Aug 19, 2009 | 06:50 PM
  #4517
pmohr's Avatar
No more Maximas...
Did you bleed the system at all, or just fill it up and call it done?
Shall we assume you mean the wheel bearings?
What sort of noise does it make when you turn the wheels? Is this stationary, while driving? Any relationship to engine speed or vehicle speed? Change while accelerating or braking, or just coasting?
What other noise 'came back again'?
Old Aug 20, 2009 | 09:03 AM
  #4518
MasterS's Avatar
A small quiz: the battery light came on, and I haven't a clue what could be wrong.
The manual just say, contact service.
suggestions ?
Old Aug 20, 2009 | 09:07 AM
  #4519
suggestions ?
Have you done the obvious and checked the battery and alternator??? Your local big parts store will probably check it for free btw.
Old Aug 20, 2009 | 09:15 AM
  #4520
JoeyMax96's Avatar
[quote=pmohr;7165063]Did you bleed the system at all, or just fill it up and call it done?
I went to get my radiator flushed at a shop and since my radiator was plastic there was a possibility of breaking it during the flush which was $60 so i just put a nw one in for $130 and now the madmax is runnin like a champ!
