NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
Old Oct 14, 2009 | 01:14 PM
  #4881
TravisCadello's Avatar
Originally Posted by B_Eaze
Wait, you have a axle from a 3 spd Maxima??? where did you get that info from? Check to see if you have the right axle for your car
No it came from same Maxima, what i said was that my last car was a 3 speed automatic.
WHAT TRANSMISSION FLUID DOES THIS 95 MAXIMA TAKE? FROM AUTOZONE? I WANNA RUN AMSOIL BUT WHAT KIND? THANKS
Old Oct 14, 2009 | 02:10 PM
  #4882
sbrown464's Avatar
I have a 97 se 5 speed. I purchased a 3.5 with 6 speed from a friend out of a 2002. I am a little confused about the timing ring, most of the forums focus on the tranny swap with a 3.o or a 3.5 swap with the 5 speed. I would just keep the 5 speed however the syncros are going and i got a deal on this combo. Will i need to get with travis and order his bolt on timing ring or can i mod one that i already have. Besides the ring i also need the the cam gear spacers which seem hard to get with one member making them. I plan to do the swap after thanksgiving and am trying to get all the hard to get parts. Can I just solder the 3.5 CPS to the 3.0 harness?
Old Oct 14, 2009 | 05:32 PM
  #4883
pmohr's Avatar
No more Maximas...
Well the first question, are you going hybrid or full swap?
Old Oct 14, 2009 | 06:46 PM
  #4884
sbrown464's Avatar
I plan to use the 3.0 ecu, so hybrid. I dont have the cluster, pedals, and all else the full requires. I do have ecu and engine harness from the 3.5 so i can use those connectors.
Old Oct 14, 2009 | 08:35 PM
  #4885
grasshoppa's Avatar
hello everyone , new to maximas . i have a 99 se . I put new axles in and had an alignment and balance of the wheels and tires. after putting the axles in i have a wobble in the steering wheel and shifter(5speed) at all speeds when coasting or accleration. Seems worst when i start to pull of from a light Im not new to forums and this one looks to be very informative. Does anybody have any suggestions i have no idea where to start.
i want to upgrade several parts of my car and this looks to be a good source of knowledge here. thanks cain
Old Oct 15, 2009 | 10:52 AM
  #4886
simleung's Avatar
Car jerks (sometimes) when accelerating
Hi everyone
I looked through this forum but didn't find anything like my problem, so I thought I'd try posting.
I have a 96 maxima (automatic), had it for about 6-7 years now. Yesterday it started jerking as I was driving home. It jerked when I was accelerating (roughly 2000 rpms). I had to take my foot off the accelerator and coast for a few seconds to make the jerking go away, then I could drive as normal (although somewhat tentatively). It happened twice last night. And a couple more times today. It doesn't always happen, ie. I can't necessarily re-create the problem at will. But I think it happened mostly when I was acceleration from a slow position, eg. just finished making a turn.
Does anyone have any ideas as to what may be causing this problem? The research I've done so far indicates anything from fuel injector to MAF to spark plugs.
Thanks !!
Old Oct 15, 2009 | 10:55 AM
  #4887
pmohr's Avatar
No more Maximas...
Did these problems occur immediately after installing the axles, or after the alignment/balance?
New or reman axles? I'd swap them out again, preferably with new units.
Originally Posted by simleung
Hi everyone
Thanks !!
Codes? Have you done any maintenance since you've had it?
Old Oct 15, 2009 | 11:17 AM
  #4888
simleung's Avatar
Hi everyone
Thanks !!
I haven't done any major maintenance, just tuneups, brakes, shocks and that kind of thing. No work has been done on the engine. Oh, a belt was replaced about 8-9 months ago, but that's about it. I'm not sure what you mean by "codes"?
One thing I should add (which I originally didn't think was relevant, but hey, you never know) is that I'm also having trouble with the A/C / heater / coolant. Coolant leaks, but always retains a minimal amount (about an inch or so stays in the reservoir). Heater takes about 10 mins to start to get warm. A/C seems to leak as well because if I fill it in the summer it's good for a month or two and then it's not cold anymore.
Old Oct 15, 2009 | 11:27 AM
  #4889
pmohr's Avatar
No more Maximas...
So in the last 7 years, you've never had the plugs changed? You say 'tuneup', but then say that nothing has been done to the engine, so I wonder what you consider to be a 'tuneup'.
Codes, meaning are you throwing any codes.
Don't look at the reservoir, coolant level in the reservoir is all but irrelevant. You need to check level in the radiator itself.
Old Oct 15, 2009 | 11:37 AM
  #4890
simleung's Avatar
Hi everyone
Thanks !!
Yes, I've had the spark plugs changed. I guess I'm bad with my terminology, sorry about that. I meant that other than tuneups, I haven't had any major work done on the engine. I think the last tuneup and spark plug change was about 6 months ago. I think all my mechanic does when he does a tuneup is change the plugs anyway, and maybe check fluid levels.
Thanks for the info re the coolant in the radiator, I will check that out.
Re: codes, there's no warning lights or anything if that's what you mean.
Old Oct 15, 2009 | 03:12 PM
  #4891
grasshoppa's Avatar
reman axles , i think it is one of the axles now , im about to put a clutch in it so ill buy some new axles and try them. thanks for the advice.
Old Oct 15, 2009 | 04:38 PM
  #4892
watson's Avatar
I need to know what kind of tranny I have, now I know how to check using the plate near the firewall with the VIN number but I do not have the original tranny is my car. The plate says I have a VLSD but I am coming to a conclusion that it may not have one in this newer tranny. Is there any codes on the transmission itself that say if it is a VLSD or just an open diff?
Old Oct 15, 2009 | 04:40 PM
  #4893
pmohr's Avatar
No more Maximas...
Why do you believe that the new trans has an open diff?
Auto or 5MT?
Old Oct 15, 2009 | 08:22 PM
  #4894
watson's Avatar
5MT, well my brother and his friends provoked me to do a burnout the other day and they said only one wheel was spinning the whole time.
So after that I looked and there was only one tire skid mark. Hense possibly all the power was transfered to one side after the other side starting spinning.
Old Oct 16, 2009 | 08:29 AM
  #4895
Blackwind's Avatar
www.raxles.com
Old Oct 16, 2009 | 04:30 PM
  #4896
simleung's Avatar
Hi everyone
Thanks !!
Turns out the radiator is leaking pretty bad. Is it actually possible that the lack of coolant could cause my car to lurch like that?
Old Oct 17, 2009 | 02:37 PM
  #4897
haydeno's Avatar
I have been trying to change my belts however I have two problems.
The serpentine belt does not go straight on as the crankshaft pulley is towards the car more than the other pulleys(causes belt to slip and only run on 5\6 teeth) which is also blocking the path of where I need to put the power steering belt.
Old Oct 17, 2009 | 02:51 PM
  #4898
RellMaxima's Avatar
knock sensor
hey pmohr in ur how to change ur knock sensor what extesion and sockets and items u used to get under the manifold ...sounds like u were mumbling
Old Oct 17, 2009 | 04:35 PM
  #4899
pmohr's Avatar
No more Maximas...
Unlikely.
So have you actually checked for codes, or are you relying on the CEL? Are you sure the CEL even works?
Next step I'd take is testing the coils and injectors.
Have you checked the crank pulley for play? The rubber in between the two halves breaks down over time, if yours is bad it'll eventually split in two while you're driving.
You can see exactly what I'm using, just some extensions, a universal, and a socket.
Old Oct 17, 2009 | 04:39 PM
  #4900
pmohr's Avatar
No more Maximas...
Old Oct 17, 2009 | 05:18 PM
  #4901
RellMaxima's Avatar
Unlikely.
uh the name???
  #4902
pmohr's Avatar
No more Maximas...
uh the name???
The name of...what?
If you want an answer, try actually being descriptive, and asking a proper question.
Old Oct 17, 2009 | 06:20 PM
  #4903
Conrad283's Avatar
I need a truck
If it's a hard 1-2 shift and you're an auto, it's a bad line pressure solenoid valve which is located in the transmission.
As stated in previous posts, do you have a check engine light?
Old Oct 17, 2009 | 06:25 PM
  #4904
Conrad283's Avatar
I need a truck
It's a 12mm socket. You can use a 12mm wrench or a flex socket and an extension (probably at least 6 inches).
Look at the how-to thread for a good write up with nice pics.
Old Oct 17, 2009 | 07:49 PM
  #4905
B_Eaze's Avatar
Sorry, school takes a lot of time... look above for pmohr's first post on this page and check his how to vids. He has one on how to check ur engine codes
Old Oct 18, 2009 | 10:19 AM
  #4906
tweedledee's Avatar
NTB Mud Guards for a 1999 Maxima
Old Oct 18, 2009 | 06:58 PM
  #4907
NUBO06's Avatar
I have a 96 GLE auto with no upgrades and was thinking about installing an intake and exhaust. Not looking to spend and arm and a leg, and would like to install myself if possible. Was looking at an Injen cold air intake. Would like a noticeable power increase without a large sound increase. Does anyone have any suggestions?
Old Oct 18, 2009 | 07:15 PM
  #4908
Conrad283's Avatar
I need a truck
Are you looking to get the entire exhaust? Y-pipe, cat back, muffler?
Don't get the injen intake. It sits behind the radiator and is more like a hot air intake. If you want a CAI, get the place racing CAI.
Old Oct 18, 2009 | 07:41 PM
  #4909
pmohr's Avatar
No more Maximas...
You're going to get more sound with any intake you install. If you want the best overall power and the lowest overall sound, then stay stock. Otherwise, the only CAI you should be looking at is a PRCAI, as said.
Intake/exhaust aren't going to do much at all, I hope you realize.
Old Oct 19, 2009 | 07:49 AM
  #4910
Blackwind's Avatar
then look in the classifieds.
Old Oct 19, 2009 | 10:18 AM
  #4911
simleung's Avatar
Hi everyone
Thanks !!
Unlikely.
I haven't checked for codes, I'm still not even sure what that means. Does that mean hooking up the computer?
It also took me some time to figure out what CEL meant as well, but I guess that's the Check Engine Light. For me, that light sometimes goes on and then goes off by itself without any work being done on the vehicle.
Over the weekend, I brought the car in to my mechanic. He replaced the radiator (which I kind of had a feeling needed replacing anyway). However regarding the car lurchiing, he suspected the fuel filter. He said it was really dirty, which in turn could cause a drop in fuel pressure. Does that sound plausible?
On a sort of funny note, he replaced the fuel filter as well. This morning, halfway on my trip while driving to work, the Check Engine Light came on (it hasn't been on throughout any of the car jerking problems).
EDIT: I was browsing around this forum and found the thread about checking the codes. I'll do that tonight. I gotta say this forum is great, I'm learning lots and having fun with it too !!
Old Oct 19, 2009 | 12:25 PM
  #4912
Conrad283's Avatar
I need a truck
From a stop, accelerate like you normally would and just notice if the jerk is when your transmission shifts from 1st gear to 2nd gear, but not during the shifts thereafter (unless you come to a stop again)?
Checking your engine light is easy. All you need is a screwdriver. Just follow the directions that are on this site.
WARNING: Be careful when rotating the screw, not to put too much torque on the screw or it will break.
Old Oct 19, 2009 | 04:31 PM
  #4913
aackshun's Avatar
Quick question after searching, not worth making a thread imo....
For a 5 speed maxima, clicking when I'm in reverse sometimes means that the CV Joint is on it's way out? I was told the boot was bad, and I was gonna get to it this weekend, but is it already too late?
Old Oct 19, 2009 | 05:44 PM
  #4914
pmohr's Avatar
No more Maximas...
Clicking when you're riding the clutch, when you put the shifter in reverse, only when you're moving?
If it's only in reverse, I'd be looking at worn motor mounts and something contacting the hood or another stationary part, personally. First step is to find exactly where the click is coming from.
Old Oct 20, 2009 | 01:09 PM
  #4915
aackshun's Avatar
::EDIT:: I'm making a thread, this wasn't as simple as I thought then...
Old Oct 20, 2009 | 04:59 PM
  #4916
haydeno's Avatar
Found my power steering belt tensioner bolt has broken and was wondering if anyone knew either the length and size if I can get a hardware store or the part number
Old Oct 20, 2009 | 06:43 PM
  #4917
Conrad283's Avatar
I need a truck
It should be in this exploded view:
http://www.courtesyparts.com/maxima-...1888_1893.html
I think
Old Oct 20, 2009 | 06:53 PM
  #4918
pmohr's Avatar
No more Maximas...
I think
The tensioner is in 493, not 490: http://www.courtesyparts.com/maxima-...1888_1895.html
Assuming he's talking about the long vertical bolt that adjusts the tension on the PS belt, then the part number is 11719-31U00, $4.74 @ Courtesy.
Old Oct 20, 2009 | 11:31 PM
  #4919
Casper95's Avatar
Heeellllo Everyone!
I am a noob here! (as you can tell) A couple of my buddies are on this forum and told me about this.
I just recently purchased a 1995 Maxima Se from my good friend thats on this Forum.
It has 163k and I just put in a new clutch and replaced the left axle.
here is a picture of my new car Casper.
Old Oct 21, 2009 | 05:02 PM
  #4920
simleung's Avatar
Hi everyone
Thanks !!
Unlikely.
I checked the codes, and I got 1106 (Automatic Transmission 4th gear malfunction) and 0304 (Knock Sensor). I can't say I've noticed any malfunction shifting into 4th, but then again this car is mostly for city driving and I rarely get to higher speeds anyhow.
Question: are these codes always right, or do they sometimes give false readings? The reason I ask is because I wonder the CEL sometimes goes on and then off, etc.
I tried that, but the problem isn't happening anymore. I don't know if the fuel filter thing fixed the problem, but it seems ok now regarding the lurching.
But even when it was happening, I do believe it may have coincided with shifting from 1st to 2nd. However it didn't happen all the time, only a few times.
