NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
Old Feb 3, 2010 | 06:07 AM
  #5361
sgtboehn's Avatar
Clutch alignment tool
Got a 95 Max 5 spd. and I need to transfer the clutch and flywheel over to the replacement motor as it came out of an auto. Anyone know where I can get the alignment tool? Or is there another way of getting around it? tks, Mike
Old Feb 3, 2010 | 06:45 AM
  #5362
helplessdad's Avatar
Need help in Ottawa, Canada
My son slammed his '99 Max (220K with 8 new Toyo tires and many new parts)) into a curb in parking lot at 30 km/hr. Airbags deployed and rad slammed off rail. Insurance co. says its a write-off, but it is such a beauty we want to keep it and buy another Max. to mix and match parts and drive. Would love to find a friend in Ottawa for advise and help with some work, or maybe to help part it out. Anybody in West Ottawa, Ont. listening, please reply. Thanks,
Old Feb 3, 2010 | 10:34 AM
  #5363
Lbyers's Avatar
How can I tell?
Ok I have a 96 GLE
I need A new Half shaft installed on the driver's side.
Everyplace I called asked if it is limited slip differential. I gave them the vin # and they can't tell by that. Even the dealer can't tell from the Vin #. Where can I check to get the right Half Shaft for my Maxima?
Old Feb 3, 2010 | 10:45 AM
  #5364
Originally Posted by Lbyers
Ok I have a 96 GLE
Unless you live in Canada, there's absolutely no chance your Max has limited slip. Just tell them you don't have it, problem solved.
Old Feb 3, 2010 | 10:46 AM
  #5365
Try your respective regional forum here on the org. You'll have much better luck finding what you seek.
Old Feb 3, 2010 | 10:47 AM
  #5366
Any reputable auto parts store will have the alignment tool.
Old Feb 3, 2010 | 10:52 AM
  #5367
Originally Posted by glitterati
Hello. I drive a 1995 Maxima and recently had a bunch of work done at my local Kelly Nissan dealer in Chicago. I'm talking knock sensor, o2 sensor, fuel injectors, etc. I was reading the paperwork and was floored when there was a comment saying that I was using 87 octane gas instead of 93 octane gas which is causing my car to misfire. For as long as I have been driving, I have been using what I thought was premium 93 gas from Shell. I've also been recommended this from a tech at Orland Park Nissan. When I told him that I've been using 93 premium, he looked at me like I was crazy.
Is it really my gas from Shell that is causing issues with my car? I always make sure to use premium gas as suggested by my manual and by the gas cap. All these years I've been thinking that I was using 93 while the techs at Nissan are telling me that it's 87? Thanks for all future replies if any.
Nope, it's not the gas. You're using good gas.
Exactly how did they determine you were using "87" gas??
BTW, find a new mechanic.
Old Feb 3, 2010 | 10:55 AM
  #5368
Rob_0126's Avatar
Originally Posted by Rob_0126
UPDATE on TPS adjustment:
I got a #3 code from the on board AT diagnostics,
tested the TPS with the revised method(NTB99-053a) using the Closed Throttle Position Switch(CTPS)(right side) instead of the TPS variable output measurement(left side),
Turns out I had continuity on both feeler gauge thicknesses (.012 & .016 in),
So I adjusted the TPS so I had no continuity on .016 in thickness,
Now the tranny shifts smoother and picks a better rpm, to shift at.
I haven't checked to see if it's still getting the #3 code for TPS trouble, but for now, it's a lot better running....
Update to this Info, and a question about it:
When I set the TPS thru the revised method, using the other TS(for the AT), I checked the variable, and it's 610 ohms fully closed to 4300 ohms WOT. Does that harm anything?
It also lowered the idle to 600 rpms, in gear.
Old Feb 3, 2010 | 02:19 PM
  #5369
sgtboehn's Avatar
Mark off advance as being reputable, they were the reason for my post!!
Will give carquest or Napa a shot!
Old Feb 3, 2010 | 03:11 PM
  #5370
Mike-95SE's Avatar
can anyone tell me what would make the 95 SE Maxima run like poop?
Old Feb 3, 2010 | 03:19 PM
  #5371
Lots of things. It would be better if you described your symptoms as clearly as possible. CEL on by chance?? Check for codes (a bad KS does not throw a code)??
Old Feb 3, 2010 | 04:14 PM
  #5372
chirp_in_third's Avatar
Originally Posted by chirp_in_third
Hello everyone. My name is Travis and i have a 96 5sp max. i decided to do the DE-K swap a few months back and STILL havent been able to get it started..
My set up:
01 DE-K Motor
96 5sp tranny
96 flywheel, timing ring clutch etc.
96 ECM
96 IACV
01 TB and TPS
96 CPS
96 CKPS POS
96 CKPS REF
no egr
Knock sensor resistor mod.
So heres the deal... when i go to start it, it cranks and kicks back.. It tries starting at 20*, and sometimes im able to get it to start up.... When the cars running, the idle is up and down( not at a consistant RPM). the scanner is telling me that the timing is around 50-60*. i have reset the ECM multiple times, and no codes have came up yet.. i wasnt sure if it was a bad scanner, so i unpluged a coil and it showed up with an ignition failure code..
i was told that the Crank position sensors were the same for 95-01, however the 01 ckps (under crank pulley) has the wiring coming in on the opposite side than the 96.
So for the past week I was thinking that maybe I didnt line up the flywheel to the crank properly. But would it make a difference in this situation since the timing rings from 95-01 dont have any marks(all teeth equally spaced and sized.) i remember see in a thread that pmohr has seen this problem a lot when people do clutch jobs. Is this only for the 3.5s?
Any help would be great.. i hope pmohr sees this post and has some ideas.
Any idea?
Old Feb 3, 2010 | 09:24 PM
  #5373
1996SEleeper's Avatar
Anybody Install a Fidanza???
I am probably going to use stainless steel washers instead of the 'center bolt-hole part of the stock flywheel' that i cut out. It gives me good clearance but is too thick and thus, puts the teeth on the sensor sprocket over the outermost edge of the crankshaft sensor magnet... Does it need to be centered over the magnet or can it be on the edge? I know that if its off far enough, the car may not run after i get it all put back together. Anybody ever deal with this before?
Originally Posted by 1996SEleeper
I am in the middle of a clutch/ flywheel swap and i am having a clearance problem with the new fidanza flywheel. I took the crankshaft position sensor's "toothed ring" off the stock flywheel and put it on the new fidanza and when i try to bolt it back on to the engine the "toothed ring" rubs against the side of the block in at least one spot. Do i need to shim the new flywheel? What should i use to shim it...(i cut out the center bolt-hole part of the stock flywheel out and it looks like it may work)? What are the tolerances that i am dealing with as far as: 1. How far can/should i shim it out? 2. How important is weight balance of the shim(s)? Any help is greatly appreciated._Matt_
Old Feb 4, 2010 | 02:16 PM
  #5374
1998MaximaGLE's Avatar
When do you know its time to change the drive belts?
When do you know its time to change the alternator?
Old Feb 5, 2010 | 10:57 AM
  #5375
Jriv815's Avatar
Originally Posted by bpk01
Sunday morning I went out to start the max and to my suprise there was a high pitch squeal. I let it warm up and it never went away. When I put it in reverse and accelerated backwards it got louder. Could it be my accessory belt or possibly the alternator? Ive got a 97 GLE with 115k miles.
I have had the same issue a couple of times. The first time it had happened to me i had to replace my Crankshaft Pulley because the rubber piece between the actual pulley and the metal hub broke and caused the pulley to walk. And as of right now my car is still doing it...but i know that the only reason its doing it is because the belt is too loose and is slipping on the pulley. However, with it now once it warms up it goes away.
Old Feb 6, 2010 | 05:15 PM
  #5376
Goomz's Avatar
name of a door trigger??
nevermind, found it.
Old Feb 6, 2010 | 05:25 PM
  #5377
96 SE JET's Avatar
Hello i have 1997 SE 5sp and as i was driving yesterday the temp gauge drop to cold and my heat wasnt blowing as warm. Has anyone experienced this. Please help?
Old Feb 6, 2010 | 05:36 PM
  #5378
pmohr's Avatar
No more Maximas...
To start, have you even checked your coolant level?
Old Feb 6, 2010 | 06:02 PM
  #5379
96 SE JET's Avatar
thanks 4 responding pmohr checked coolant its ok
Old Feb 6, 2010 | 06:13 PM
  #5380
FallenOne's Avatar
therostats probably stuck open.
Old Feb 6, 2010 | 07:59 PM
  #5381
96 SE JET's Avatar
Thanks FallenOne ill check that 2
Old Feb 7, 2010 | 10:06 PM
  #5382
jrich7720's Avatar
I'm looking into buying a daily driver for use while my '99 Altima is under the knife. I'm considering a '97-'99 Maxima SE, as I've always loved the look of this car, and I wouldn't mind owning a VQ.
My question is(and yes, I have searched), has anyone managed to swap out the rear live axle with the independent suspension out of another model(another gen Maxima, perhaps)? It is the only thing about this car that kind of bugs me.
Thanks!
P.S. Wouldn't mind picking up a '99 SE, as I hear they have LSD. Do ALL of the 99s come with LSD?
Old Feb 8, 2010 | 10:51 AM
  #5383
strocket's Avatar
Rough Idle... always wants to die under load
Hey guys, obviously new to the site. Got the car a few months ago from my dad with 74000 miles on it. Everything was fine until one morning it didnt want to start. He had told me everything was original that that no maintnence other then oil changes had been done. So first thing that came to mind was the fuel filter. So I changed that, but it didnt really do anything. it pretty much came to the point where I would have to just crank it forever and day. I ended up killing the battery, got a new one and all the problems went away. everything was fine for about a month and then it started pullin this crap where it would just randomly die. It was a once in a blue moon kinda thing so I didnt worry about it much. Finally the check engine light came on, pulled the codes and it gave me a cylinder 2 misfire. So I pulled The coil and noticed the plug cylinder was filled with oil. So I replace all seals in both valve covers and changed the spark plugs hoping that would cure my sick maxi but nope, still have the same problem. It idles at about 500RPM with a shudder. I have no where near the same amount of power as when I first got the car, and im going through gas like crazy. I managed to pull the new codes...
1008
0201
0304
The only code that I could diagnose was a bad coil. Im not sure about the others. Anyone else have this problem? Im not sure what else it could be. Im going to get a new coil this weekend. Any help would be greatly appreciated. Thanks in advance for yalls help!!
Old Feb 8, 2010 | 10:57 AM
  #5384
Bassysingh's Avatar
Have a 1995 Max with whinning noise coming from the engine. Is there a tensioner or certain pully that tends to go bad on these constantly? Havent gotten to run the CEL yet but when i do i'll be sure to let you know what it's telling me.
Old Feb 8, 2010 | 11:04 AM
  #5385
Thanks!
1. Nope. And why would you let your qualm bother you for a daily driver??
2. No 99's come with LSD. Only the Canadian models had LSD as an option.
Old Feb 8, 2010 | 11:08 AM
  #5386
1008
0201
0304
What do 1008, 0201, and 0304 stand for? I'm too lazy to look them up right now.
What year max do you have? What brand sparkplugs did you recently put in? Gapped right?
Coils could be your problem for sure.
Old Feb 8, 2010 | 11:09 AM
  #5387
Nope, no particular pulley is known to go bad on the Max. Check your belt, and the check the tension to begin with. Then start looking at the pulleys etc
Old Feb 8, 2010 | 11:53 AM
  #5388
strocket's Avatar
1008 - EVAP Canister Purge Volume Control Valve
0201 - Ignition Signal Circuit
0304 - Knock Sensor
1995, NKG Platinums, .044 Gap (what the autozone guy said it should be)
Old Feb 8, 2010 | 12:01 PM
  #5389
0304 - Knock Sensor
Spark plugs are correct, and IIRC, they're gapped right too.
None of those three items would cause your Max to shudder. A bad KS will definetely rob you of power though.
Since you say it shudders, and you're going through gas fast, I'd check the fuel injectors, maybe one is clogged/stuck open. While you have the intake manifold off, test/replace the KS if need be.
Old Feb 8, 2010 | 12:44 PM
  #5390
strocket's Avatar
Are there any easy ways of testing the KS and Injectors? I know I could probably search and figure it out, but this is helping me get my 15 posts
Old Feb 8, 2010 | 01:49 PM
  #5391
One Post Wonder's Avatar
Is the 5 speed clutch release fork the same as the 6 speeds?
Old Feb 8, 2010 | 03:47 PM
  #5392
RA021526's Avatar
KS = measure for resistance. The exact value you'd have to search for, there are a bunch of write ups. Also, it's probably in the how to section.
Injectors = resistance also, if I remember correctly. You only have to take the manifold off for the rear injectors.
Old Feb 9, 2010 | 07:33 AM
  #5393
Bassysingh's Avatar
Squeaking
Thanks Wizard. I'll be checking it out tomorrow. It's been sitting for about a year and a half so maybe it needs to be run a bit.
Old Feb 9, 2010 | 08:53 AM
  #5394
eightball's Avatar
Got a P100 and P325 that happened two days after my smooth running 154k miles 1995 Maxima did a couple jolts and partial loss of power and then cruised smoothly there-after.
I was told on another thread that this is a dirty MAP sensor and I must clean it. Is the P325 a "result" of the dirty MAP/P100, and not the issue?
On my year Maxima, the P325 is the NOX sensor and it involves doing a very labor-intensive and expensive job of removing both intake manifolds to replace the NOX sensor.
Please, oh please tell me that the MAP sensor cleaning or fix would stop the P325 CEL, in addition to the MAP Sensor P100 code?
I went ahead and cleared the codes yesterday, and filled the tank with the high octane fuel. I've been using unleaded regular for years without any problems, but wonder if I got a bad batch of unleaded regular.
Is cleaning a MAP sensor fairly easy. I have changed the starter, on the Maxima and the plugs, and even the belt, and will tackle a thermostat/water pump, but is the MAP sensor cleaning or servicing very involved?
Old Feb 9, 2010 | 09:47 AM
  #5395
sgtboehn's Avatar
Maxima replacement parts
Can anyone recommend a good site to purchase some replacement parts? Such as power steering pump, radiator, clutch kit. Of course looking for some good prices and quality. Thanks.
Old Feb 9, 2010 | 10:06 AM
  #5396
Ham1's Avatar
Blown head gasket - dump or new engine?
I have a 96 Maxima GXE with 130K. I bought it with 15K miles so I have been the only driver basically.
Anyway, apparently I have a blown head gasket. One day the engine quit on the freeway and I had a leaky water pump and all my coolant was gone.
I put in the Blue Devil engine sealant and the white smoke stopped coming out of my exhaust pipe, but it only lasted 3 weeks and it is back. Mechanic says I need to replace engine.
My question is: Is there a place to buy and replace engines and if so, is that worth it?
OR is there any better/cheaper options in fixing the head gasket issue?
OR do I just dump a great car and go buy a new Maxima?
Thanks for any advice.
Markham
Old Feb 9, 2010 | 03:20 PM
  #5397
sgtboehn's Avatar
Markham
I bought my max with a blown head gasket with 158K on the clock for 400 bucks! I found a newer motor with only 42000 miles for 200 bucks! I would say if you can find a deal like that and can do it yourself, then I would say it is worth it.
Or you can just tear the motor apart and replace the head gasket. Do some searching around and see what you can find...your call!
Old Feb 10, 2010 | 11:24 AM
  #5398
Mmax99's Avatar
Exhaust questions
Ok i was wondering what parts i need to do a complete exhaust?
i know about the y pipe, headers, muffler
but what else is optional to upgrade, to add more Hp and a quality sound?
Old Feb 10, 2010 | 11:30 AM
  #5399
Cattman catback, fastcat, and a nice Supercharger to go with it. Now that's a nice sound.
Old Feb 10, 2010 | 11:44 AM
  #5400
Mmax99's Avatar
yea i know about those
I know about those upgrades. but like would i need a test pipe, resonator, where the precats are and if i would need a b- pipe. or what not.
