NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
Old Nov 5, 2007 | 03:24 PM
  #1041
JDigital's Avatar
Failed inspection: check engine light does not turn on!
I failed my safety inspection the other day because they said my check engine light does not even turn on at all.
Does anyone know of a way to change the bulb or has had a similar problem where the light would not turned on?
Can anyone direct me to a site that has a how to on taking out the dash where the speedometer and the other lights are so I can change the bulb?
Thank you guys so much!
Old Nov 5, 2007 | 04:17 PM
  #1042
bigpulve+'s Avatar
Stickies on top of 4th gen forum....
Or searching using
THE AVY!!!!!!111one
Edit...im in a good mood
http://www.geocities.com/amixam69/nissan/dash/
Old Nov 6, 2007 | 09:29 AM
  #1043
JDigital's Avatar
Or searching using
THE AVY!!!!!!111one
You are a life saver! Thank you!
Old Nov 6, 2007 | 12:14 PM
  #1044
bigpulve+'s Avatar
Your welcome...
Old Nov 6, 2007 | 12:15 PM
  #1045
97MaximaSE97's Avatar
Do the 99 ecu's give different codes then other years? I hooked up my obd-ll scanner to my dad's max and his knock sensor code was P0305, but when I looked here all I see is P0304 for the KS code.
Also what does pending mean on the scanner? He threw two codes for the KS one was there and the other said pending.
Old Nov 6, 2007 | 12:22 PM
  #1046
NmexMAX's Avatar
dot dot dot ...
The coding is different PO is an OBDII standard, the 0304 is counting how many blinks, and doesn't relate to the PO code.
http://forums.maxima.org/showpost.ph...67&postcount=7
Old Nov 6, 2007 | 03:15 PM
  #1047
nessad's Avatar
new aussie chick posting this cause no other choice!
Hi I joined because I have problems with my maxima and because Nissan, a host of mechanics and auto electricians have so far only cost me huge $ without fixing anything.
So... because I have to post the ridiculous 15 replies before I obtain ANY useful information by asking the question I need to I have to bore others with useless chatter. Enjoy.
Old Nov 6, 2007 | 03:24 PM
  #1048
ROCKART's Avatar
wants an I35
or you could ask the question here in the form of a reply.
Old Nov 6, 2007 | 03:25 PM
  #1049
Ummmm. It's not rediculous. The 15 posts rule keeps spammers away.
So, this thread is for newbs just like you that can't start there own thread just yet. What's your question?? Maybe we can help.
Old Nov 6, 2007 | 03:32 PM
  #1050
nessad's Avatar
True, but the original post said not to do that so being the good girl I am I was trying to be nice! But.. seeing as you asked! 95 Nissan Maxima A32 (I am hoping the model sold in Australia is the same as the A32 in US?). Problem now for 8 months with stalling at traffic lights or while braking to eg. go over a speed hump, round a round-a-bout etc, strange idle going up and down on without acceleration. Very random, can not play up for 2 weeks and then (as it is this week) is really bad. Have had it to Nissan and a host of mechanics, no codes thrown, they replaced knock sensor, throttle body sensor, even the whole throttle body and the obvious things like fuel and air filters but so far the only thing it has done is send me broke ($2500 so far). Now think it is the Idle Control Valve which is a $700 part here in Oz + labour and second hand Maxima parts are a rarity here and no aftermarkets sold here. Any suggestions? Being a girl, anything mechanical has to be done by someone else who I have to pay!
Old Nov 6, 2007 | 03:55 PM
  #1051
For starters, have a mechanic clean the IACV for sure. A clogged IACV would definitely cause the symptoms you describe. No need to replace it, it's not a part that typically wears out. Nissan shouldn't charge you more than 1 hours rate to do the job (although it can be done in 30 minutes...)
Also have a mechanic/Nissan check for a vacuum leak. Fairly simple.
Possibly your MAF is dying too, but I'm not sure about that one so don't go buy a new MAF, as they are expensive! If it turns out to be the MAF.......used Maf's here on the org are typically around $40. Changing it is a 10 minute job with simple tools.
Also, if Nissan worked on your car, take it back!! Why pay for parts/labor that didn't solve your problem? It's there job to figure it out, period. Raise some hell! Hope you paid with a credit card, that way you can dispute it. (provided not too much time has gone by)
Hopefully others will chime in with other possible causes of your stalling issue.
Old Nov 6, 2007 | 05:15 PM
  #1052
nessad's Avatar
What is a MAF?
Sorry, as I said I am a girl and have no idea what a MAF is?
Old Nov 6, 2007 | 05:21 PM
  #1053
MAF=M*** Air Flow Sensor.
Old Nov 6, 2007 | 05:37 PM
  #1054
nessad's Avatar
MAF failure should throw a code right?
Would that not throw a code and what other symptoms would that show? Is that the same as an Oxygen Sensor? i think they replaced that as well already?
And yes you are right I have been ripped off completely especially as the Dealer I went to (more than an hours drive away) is associated with my company and were supposed to look after me. I complained but they refused to do anything further. Won't be going back there - found a great Racing Engine Performance specialist just down the road who is very helpful and won't charge until he knows for sure what the problem is but as it has been so random it is very difficult to diagnose. He even drove the car around for 2 weeks himself but it must have been 2 weeks it was behaving.
Old Nov 6, 2007 | 05:49 PM
  #1055
A bad MAF usually throws a code, but not always. A MAF and an oxygen sensor are two very very different things. Your problem is related to air in my opinion, hence my suggestions for the MAF, vacuum leak, and IACV.
Have your mechanic check the resistance on the MAF, the specs are listed in the Factory Service Manual for your car.
You can also try cleaning the MAF with a spray cleaner specifically made for MAF's. Some have reported good luck and there stalling issues went away, others had no luck and had to replace the MAF.
Old Nov 7, 2007 | 05:18 PM
  #1056
nessad's Avatar
Not the MAF or Idle Control?????
Hi again, took car to mechanic yesterday arvo and it is finally throwing a code that says it is a Water Temperature Sensor??? not sure of exact code number but could this have been causing the problems all along and why has the code not come up in the 8 months the problem has been present?
Old Nov 7, 2007 | 07:58 PM
  #1057
Coolsaber57's Avatar
Ok, quick question:
If I take the amber lens out of my taillight, will it pass inspection?
Old Nov 8, 2007 | 06:49 AM
  #1058
NmexMAX's Avatar
dot dot dot ...
Originally Posted by Coolsaber57
Ok, quick question:
Depends on the state, but if you replace the clear bulb with an amber bulb, it should.
Old Nov 8, 2007 | 08:41 AM
  #1059
Yes, most definitely. I forgot about this one. You may have a bad Engine Coolant Temperature Sensor (ECTS) or a problem with the ECTS harness/connector.
Try wiggling the ECTS wire and harness while the engine is idling. If this prevents the car from stalling, then you may have found the source of the problem. Then, have the mechanic test your ECTS with an ohmmeter.
The ECTS is located in the water outlet tube close to the engine end of the upper radiator hose. There are two sensors in that area. The one nearest the hose is for the dashboard temperature gauge. The ECTS is right next to the the gauge sending unit. Check out the Haynes repair manual for a picture of these sensors.
With the engine cold, disconnect the ECTS and measure its resistance. Reconnect the ECTS, start the engine, run it until fully warmed up. Stop the engine, and repeat the resistance measurement. The "warm" reading should be a much lower value than the "cold" reading.
The manual gives these specs:
Engine coolant temperature 68F, ECTS resistance 2.1 - 2.9 Kohms
Engine coolant temperature 194F, ECTS resistance 0.24 - 0.26 Kohms
I think you're finally getting somewhere and getting closer to figuring out your problem.
Old Nov 8, 2007 | 09:41 AM
  #1060
Cdg2125's Avatar
Ok, quick question:
some states you need an orange reflector in front. Check your laws. We can't tell you your own laws.
Old Nov 8, 2007 | 03:51 PM
  #1061
Eh..what I meant was that even if state law say that it does, is this something that is normally a cause for failure?
I mean are they sticklers for it? Can anyone who has done this within a state that says you have to have amber turn signals say whether or not they passed inspection?
Old Nov 8, 2007 | 04:34 PM
  #1062
bigpulve+'s Avatar
The day before inspection put the stockers back on...it takes a whole 5 mins.
Old Nov 9, 2007 | 12:07 AM
  #1063
psychomofo's Avatar
Is there a difference between a SS y-pipe and aluminum besides being rust resistent?
I live in california, but might move to the beach sometime next year and want to know if i should drop the extra 40 or so dollars for SS? Does it reduce the noise?
Thankkee
Old Nov 9, 2007 | 11:07 AM
  #1064
Good call, although that means getting an extra pair...
Cars cost way too much money, why is it so addicting to have them!!
Another question:
My exhaust looks rusty and I may have to replace it in the next year. I don't want a ricer exhaust, is it difficult to replace the stock exhaust with another stock?
Thanks!
Old Nov 9, 2007 | 11:15 AM
  #1065
Another question:
Thanks!
Yes, with basic tools (wrenches, ratchets, sockets) you should be able to do it yourself assuming it's not all rusted together.
Old Nov 9, 2007 | 11:39 AM
  #1066
smasson05's Avatar
Is the heat shield for the cat converter necessary on a 4th gen? (some bushes got mine)
Old Nov 9, 2007 | 11:40 AM
  #1067
smasson05's Avatar
Also does anyone have a favorite place to (cheaply but not cheap parts) get body panels/drivers side mirror in CT or online? (can't even find a junk yard with what I need).
Old Nov 9, 2007 | 11:51 AM
  #1068
Double E's Avatar
I guess necessary depends on what comes into contact with it.
You might get even with the bushes by parking on top of them while it warms up from a cold start but you might also lose the car.
Many junk yards will use a clearing house type of network to get you the part you need. Unless the owner is still in the dark ages that is... You might also try the f/s sections here.
Old Nov 9, 2007 | 11:56 AM
  #1069
IMO, no. I wouldn't worry about it.
The for sale section here on the org!
Old Nov 10, 2007 | 02:40 PM
  #1070
Sinturion's Avatar
N00blargh
Does anyone know if the VQ30DE engine uses torque to yield (TTY) head bolts?
Old Nov 11, 2007 | 11:23 AM
  #1071
AndrewR2442's Avatar
{img}http://www.flickr.com/photos/20138835@N07/1970478350/{/img}
  #1072
Old Nov 11, 2007 | 11:26 AM
  #1073
Old Nov 11, 2007 | 12:50 PM
  #1074
picture.....
Andrew, there is test post forum for stuff like this........
Old Nov 11, 2007 | 04:55 PM
  #1075
Thanks!
But I thought that you needed a blowtorch type thing in the process? (I could be completely wrong, it's just something I was told some time ago)
Are there any good guides for this?
Thanks!
Old Nov 11, 2007 | 04:58 PM
  #1076
gen4maxima536's Avatar
Thanks!
Thanks!
if its really rusted you can use a torch to heat up the bolts to get them to break loose, sometimes it'll work.
if you just go at it with some pb breaker and a breaker bar you'll probably do just fine.
you don't really need a guide, just take stuff out and put corresponding new piece back in.
Old Nov 11, 2007 | 05:53 PM
  #1077
dr2's Avatar
dr2
i would like to know what K&N part number for a cone filter should i use, this is for a popcharger
ive been searching for a while on the forum before i post and those are the one saw most of the time, they are all 3 inch i think
RU-2820
RU-3580
RU-3570
RC-3870
RR-3002
RR-3003
Old Nov 11, 2007 | 11:57 PM
  #1078
RU-2820
RU-3580
RU-3570
RC-3870
RR-3002
RR-3003
well measure the pipe dia. that your going to be using ( or the adapter dia.) and how much room you have to work with, then go here: http://www.knfilters.com/search/univcone.aspx and figure out which one you'll need, not everyone has the exact same setup.
hopefully someone can chime in with common dimensions of popcharger filters
Old Nov 12, 2007 | 09:52 AM
  #1079
bcmaxima96's Avatar
o2 sensor question
i have a 96 max n it needs an o2 sensore , bank 1 sensor 2 , i jus wanna make sure where that sensor is .
Old Nov 12, 2007 | 11:45 AM
  #1080
Zeppelin's Avatar
Can anybody tell me the part number for the gear select sensor out of the 4th gen manual transmission?
Thanks!
