NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
Old Nov 27, 2007 | 06:20 PM
  #1161
gen4maxima536's Avatar
Originally Posted by 94max_dub
can anyone tell me how to post pics of my car on here, im new to maxima.org and i am already a member?
if you are just going to post pics of your car make sure you post them in the members rides section.
Old Nov 28, 2007 | 07:29 AM
  #1162
Coolsaber57's Avatar
Originally Posted by KRRZ350
Lock yourself in the car, wait a full minute, try to open the door, if it 'sounds' (confusing when you use the words 'go off') than all is good and don't open your trunk until you unlock the doors, the dis-arm sensor on the trunk key might not be functioning, if they even have one, I've NEVER seen a 4th gen or I30 that the keyhole worked on!!
Sorry, by "going off" i meant sounding...like my horn blares, lights flash, all that stuff.
I'd rather not have to unlock the door, then open the trunk, is this a sensor that I can replace?
I will try to do the alarm test tonight. When I try to open the door, should I unlock it first? Or just pull the handle?
Thanks!
New question (I'm a complete noob at modding cars.)
Where is the Y-pipe located? I finally found out that a B-pipe is the mid-pipe, which connects the cat to the muffler, but is the Y-pipe the piece that connects the manifold to the cat? Or am I completely off here)
Old Nov 28, 2007 | 09:19 AM
  #1163
LJ2Blessed's Avatar
My taillights won't shine when I have my headlights on (i.e. at night). The bulbs aren't burnt out, they work as brake lights, hazards, turn signals...just not as tail lights in the dark. Is this common on 4th gen Maxima's? I'm not sure how long this has been like this (my husband just noticed it last night), but my SES light recently went off, maybe even the same day (I don't bother with it, it's just a pest). Help!
Old Nov 28, 2007 | 09:24 AM
  #1164
NmexMAX's Avatar
dot dot dot ...
You sure you using the correct bulbs?
Old Nov 28, 2007 | 09:29 AM
  #1165
LJ2Blessed's Avatar
These are the same bulbs, I've never changed them. Just all of a sudden they don't work as tail lights anymore, but still as brake, hazard, backup, etc.
Old Nov 28, 2007 | 09:57 AM
  #1166
NmexMAX's Avatar
dot dot dot ...
The brake lights are dual filament bulbs, so my guess is that one of the filaments is out. You might also want to check brake light fuses in the cabin.
Hazards are a different set of bulbs as well as back -up. Check the fuses.
Old Nov 28, 2007 | 10:47 AM
  #1167
the y pipe connects both of the exhaust manifolds together and then dumps into the Cat. if you're under the car and follow the exhaust forward from the cat you'll see it going under the engine to the front manifold, and up to the rear manifold
Old Nov 28, 2007 | 11:35 AM
  #1168
LJ2Blessed's Avatar
More info: I no longer get an indicator beep that I've left my lights on either. My boss was leaving and called to let me know my headlights were on. I thought "it didn't beep"...and I tested it to see if it would, and it did not. So, my symptoms are - when headlights are on, no tail lights and no indicator beep signal when key is removed.
Old Nov 28, 2007 | 11:44 AM
  #1169
Whew, good, i'm not completely clueless then, thank you!
How long does this typically take? I read that it doesn't produce much, if any sound difference.
Here's my plan as of right now:
1. Keep noise at a minimum (Highly policed area...no $$ for tickets)
2. Get a Y-pipe
3. Replace rusty B-pipe w/ a stainless steel one (Does replacing this with an aftermarket one produce a lot of noise?)
Does this sound ok?
Old Nov 28, 2007 | 03:07 PM
  #1170
the beeping device is on the back of the panel below the steering wheel. if you reach behind there you can check if it is unplugged or take it out and test it with a battery or something.
Old Nov 28, 2007 | 03:10 PM
  #1171
2. Get a Y-pipe
Does this sound ok?
look in the exhaust sticky at the top of the forum on how to do it. plan out a good chunk of time to do it, i'd say atleast 2 hours for your first time.
if you keep your stock muffler and b-pipe, no it will not make much of a difference, you can hear the difference a tiny bit but its not going to draw any attention at all.
if you get a resonated b-pipe it shouldn't increase the amount of noise your exhaust creates too much, i can't vouch for this part, but an aftermarket resonator probably wont be as quiet as stock but probably fairly close. along with the stock muffler it'll keep the noise down.
Old Nov 29, 2007 | 07:22 AM
  #1172
bcmaxima96's Avatar
ecu reset??
just did a few things to my car new y pipe, o2 sensors and i need to reset my ecu , the one how to i found the link didnt work , can anyone tell me how its done , thanks!!
Old Nov 29, 2007 | 07:30 AM
  #1173
NmexMAX's Avatar
dot dot dot ...
Why do you need to reset your ECU? Check the codes, (which automatically clears them) And you're good.
http://forums.maxima.org/showthread.php?t=76800
Old Nov 29, 2007 | 10:32 AM
  #1174
Thanks man.
New question: If I wanted to lower my car (Not a lot) but wanted to keep the same soft ride, how would this best be accomplished?
I've been reading up on it and it seems like if I keep to OEM struts/shocks but get H&R Sport Springs, it will accomplish my goal. Is this true? Or should I look at aftermarket struts?
Old Nov 29, 2007 | 10:54 AM
  #1175
Cdg2125's Avatar
Thanks man.
what have you been reading? Aftermarket springs destroy stock struts. If you want to lower your car you will not get stock feel. Coilovers are your best bet because they are adjustable for dampering as well.
Old Nov 29, 2007 | 05:03 PM
  #1176
psychomofo's Avatar
Hey... I got a 96 max and was wondering if i could just get the front and rear bumpers(97+) and change it? I dig the longer sportier look
edit : how much would that cost? also how much to convert steering wheel to 97
Old Nov 29, 2007 | 05:18 PM
  #1177
Fr33way™'s Avatar
Wild for Width
Yes - covered in exterior sticky at top of 4th gen.
Whatever the parts cost +labor +paint if you need those...
Old Dec 1, 2007 | 03:37 PM
  #1178
Hi guys, it's me again...
My CEL came on and I did a self-diagnosis and here's what I got:
05 04 Automatic Transmission Control Unit Signal to ECU
02 10 Fuel INJ sys left bank:lean
01 15 Fuel INJ Sys Right bank:lean
What does this mean? Any help would much appreciated!! Thanks!
Old Dec 1, 2007 | 03:40 PM
  #1179
NmexMAX's Avatar
dot dot dot ...
Sounds like you might need a MAF. The MAF code will probably pop up pretty soon, I’m guessing.
Not sure about the tranny code. Do you have the DR mod or anything like that?
Old Dec 1, 2007 | 10:08 PM
  #1180
Actually no, no mods as of yet, I just got this car a little while ago (1.5months)
Any ideas?
Old Dec 4, 2007 | 06:47 AM
  #1181
Bumpity bump.. any help?
Old Dec 4, 2007 | 06:58 AM
  #1182
NmexMAX's Avatar
dot dot dot ...
Any ideas?
Check the code(s) again.
Old Dec 4, 2007 | 07:04 AM
  #1183
Should I drive it around first (I haven't driven it since I got the last codes)
Old Dec 4, 2007 | 07:05 AM
  #1184
NmexMAX's Avatar
dot dot dot ...
That's what I would so. Have you noticing any driveablilty issues?
Old Dec 4, 2007 | 07:32 AM
  #1185
Actually, the idle has been low, but it's been low since I bought it (400-500rpm)
Recently my gas mileage has gone down the crapper though...
What about the tran code? Any ideas on that?
Old Dec 4, 2007 | 10:19 AM
  #1186
duncanjimbo's Avatar
My car idles rough/shakes when stopped at lights or stop signs but only after the car has warmed up and reached operating temperature. One mechanic said it was the MAF but when I replaced that, the issue continued occuring. I know my rear engine mount is bad and I am planning on replacing that in a couple days but that shouldn't be the problem because if it were then the shaking would occur at all times regardless of temperature. Any ideas what this could be? I am also sitting on the MAF I bought from Oreilly so if anyone wants to take it off my hands for a price, let me know.
Old Dec 4, 2007 | 11:47 AM
  #1187
check for codes, clean your IACV then come back
Old Dec 5, 2007 | 02:00 PM
  #1188
Quick hypothetical:
Could I put the 5th gen muffler on my 4th gen? Would it be louder? I ask because I saw it and liked it much better. Would it bolt directly on?
Old Dec 5, 2007 | 03:50 PM
  #1189
Quick hypothetical:
you could it wont fit quite right in the cut out since there are two tips coming off it, no it wouldn't be louder, if so not much at all. i dont think it is a direct bolt on
Old Dec 5, 2007 | 05:20 PM
  #1190
Cdg2125's Avatar
Quick hypothetical:
yes you can. It isn't direct bolt up and the hangers are different. It doesn't fit well out the back and does add a tiny bit of sound but nothing you'll notice really. All experience btw. If you can get one cheap it's not a bad idea because it is a better muffler.
Old Dec 5, 2007 | 07:11 PM
  #1191
don544's Avatar
1996 Maxima GLE
Blower Motor stopped working:
I'm not getting any juice to the blower motor (I took it out and used a tester on the connection). Since I have the automatic climate control, there's no resistor. Is there a relay or something else that is accessible to check or is time to go to the shop? Thanks!
Old Dec 5, 2007 | 09:24 PM
  #1192
#1berettaman91gtz's Avatar
cel on after degressing engine
I degressed the engine in my 1995 maxima and now my engine light is on. I read the codes and I have a code 0103 Engine Coolant Temperature Sensor & 0304 Knock Sensor. I was wondering if it is a common problem .
Old Dec 5, 2007 | 10:12 PM
  #1193
problems showing up after washing the engine bay are common enough, just have to be careful.
ECTS and KS are pretty common things to go out at this age or our cars.
Old Dec 6, 2007 | 08:22 AM
  #1194
So if it's not a direct bolt-up, what kind of modification would I have to do?
Old Dec 6, 2007 | 09:28 AM
  #1195
Cdg2125's Avatar
just need the shop to bend the connecting pipe. The stock b-pipe doesn't line up with the 5th gen muffler pipe. Shop just needs to cut the pipe and reweld it on at a different angle. Least that was what mine was.
Old Dec 6, 2007 | 11:53 AM
  #1196
By "shop" do you mean a custom shop? or could I just take this down to Midas?
Old Dec 6, 2007 | 08:14 PM
  #1197
startazin's Avatar
my suspensions has really worn out..the handling is horrible now..I need to change the whole suspension. for struts = Kyb agx and spring i want a stiff one with avg drop. Tien S tech ?
what else i need to buy or know ? Im a Newb I admit
Old Dec 6, 2007 | 08:16 PM
  #1198
Hammy
Stech are really low and will blow your shocks in less than a year FYI.
Old Dec 6, 2007 | 08:19 PM
  #1199
khantalha+'s Avatar
theres ksport coilovers for $800 on ebay....definatley worth ur money
Old Dec 6, 2007 | 08:39 PM
  #1200
startazin's Avatar
ohh
im thinking of the progress spring with KYB GR2 that is on the GD by cattman..
Im not looking for any agressive drop just better handling..
also I will keep in mind about the Ksport coilover
edit: just checked the GD and theres one 795 shipped by Jinsu
