NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
Old Apr 10, 2008 | 02:45 PM
  #1521
Originally Posted by PintosDad
Has anyone else noticed a significant difference in power after cleaning the egr tube?
I have not driven this car much, but it seems to me that it is MUCH quicker than it was before the cleaning.
I think that's the Placebo effect......
after my 12th post, do I get to post in areas that are read?
Huh?? You can post everywhere. You just can't start your own thread until you get past 15 worthy posts. Almost there.
Old Apr 10, 2008 | 03:51 PM
  #1522
MAXIMAK99's Avatar
No, 15, and sometimes they still dont get read.
Old Apr 10, 2008 | 04:11 PM
  #1523
MAXIMAK99's Avatar
Quote:
Originally Posted by MAXIMAK99
Service Engine Soon Light still on problem code 1320
I have a problem with my 99 Max. I have a 1320 code and I have changed all of the spark plugs with NGK platinums, I changed all of the ignition coils since I wasn't getting a code for a specific one. I had the crank shaft postion sensor replaced, and I even had the knock sensor replaced. After doing all of this the light stayed on and it read the same code. After all that I had all of the ignition coil harness tested and cleaned, and I still have the same problem. I had the wiring checked out and the only unusal thing that was found was a purple wire coming from the stereo head unit to the tach, which the mechanic said shouldn't affect the check engine light. Does anybody know of anything else I could possibly do?
Quote:
Originally Posted by NmexMAX
You have a 99, so I'd say coil packs are or should be on order.
Originally Posted by bigpulve
Noob
. The code calls out primary ignition signal, if that helps.
Yeah I already knew what the code calls for but none of the mechanics that have been working on it seem to find anything wrong with the primary ignition. And if I take it to the stealership they are wanting to change all the ignition coils and spark plugs and then diagnose from there. The car itself is running fine and nothing is technicaly wrong according to what the mechanic has told me. And the shop that I take it to is ASE certified so I think they are reputable. It's just that damn Service Engine Soon Light coming on for no apparent reason.
Old Apr 10, 2008 | 04:34 PM
  #1524
PintosDad's Avatar
How many warm up cycles does it take to get enough codes for emissions testing ?
I want to get it tested and registered asap but dont want to fail the test due to lacking codes.
Old Apr 15, 2008 | 12:01 PM
  #1525
NmexMAX's Avatar
dot dot dot ...
If everything is fine, you should not have a problem with SRT. Did you recently have a code / problem? If so, did / have you fix it?
Old Apr 15, 2008 | 01:29 PM
  #1526
PintosDad's Avatar
Well, Ive been driving it a few days with no check engine light so I guess its about time to go get it smog tested.
I have noticed that it doesnt want to idle when cold. Will this affect smog test results?
Old Apr 15, 2008 | 01:37 PM
  #1527
NmexMAX's Avatar
dot dot dot ...
It depends on your area. Some places just run a scan, some monitor emissions, some visually inspect the engine etc.
Old Apr 18, 2008 | 07:24 PM
  #1528
bigpulve+'s Avatar
Old Apr 19, 2008 | 11:03 AM
  #1529
minnow's Avatar
Hey guys, I'm new here but have been reading the forums extensively lately due to being the market for a used car. You'll be happy to know I settled on a 98 GLE with 210km on it. One of the deal breakers for me was the amount of information available on the car from this site and sites linked from here and I thank you all for that. Hopefully I can speak as highly of my Maxima as the rest of you.
My question, and the only minor gripe I have about the car, is that when I turn the car on the Bose tape deck tries to eject a tape that isn't there. The clicking lasts for maybe 10 seconds and it still occurs even if I put a tape in. The eject button doesn't seem to be stuck but wondering if anyone has run into this and has any tips I could try.
Old Apr 19, 2008 | 03:01 PM
  #1530
MAXIMAK99's Avatar
I would ditch the BOSE system all together, sooner or later you're going to have more problems with it. And just out of curiosity how much did you pay for your Max? And is it 210km or miles?
Old Apr 20, 2008 | 06:09 AM
  #1531
rvtech's Avatar
4th gen automatic transaxle
Hello, I have a stupid question I have not been able to find an answer for. Does the automatic transaxle use the ATF to lubricate the differential or does it use gear oil. If so where might I find the fill & drain plugs for the differential?
TIA for any help.
Bruce
Old Apr 20, 2008 | 08:34 AM
  #1532
minnow's Avatar
I hope to ditch the bose system in the future for a nav screen in the center panel or something but for now the focus of my budget will be on other mods first. The car has 210km and I paid 4400 Canadian for it.
Old Apr 21, 2008 | 04:33 PM
  #1533
MAXIMAK99's Avatar
Sounds like a good plan. The reason I asked about the pricing is because Im probably going to be selling my 99 Max with 173,000 miles on it. And I wanted to get an idea as to how to price it. Thanks for the info.
Old Apr 21, 2008 | 07:51 PM
  #1534
Maxie40's Avatar
Max40
Burnt on rear suspension
How long does it take two mechanics to put on struts and springs on the rear of a '95 Maxima SE and can an improperly placed spring cause the strut seal to fail?
Old Apr 22, 2008 | 07:01 AM
  #1535
NmexMAX's Avatar
dot dot dot ...
www.kbb.com
www.nada.com
It typically costs about 1hr / wheel(corner). That is what I remember the std rate for it was. But if you have 2 dudes, it will take them 1/2 the time, but I'm sure that's not how they billed you.
What is the problem, seems as if you think you have a bad strut as an effect of a bad installation ?
Old Apr 22, 2008 | 02:19 PM
  #1536
Maxie40's Avatar
Max40
They billed me 2 guys for four hours. I got hosed. I went to the mechanic today to replace the bad strut and one guy whipped off the strut and spring, compressed the spring took out the strut in about 20 minutes. Seeing that I got hosed. The mechanic felt guilty about not seeing the situation with the bad strut so he is not charging me labor. I have a busy job and I couldn't stick around before as this would never have happened to me.
Old Apr 22, 2008 | 08:10 PM
  #1537
Product_Of_Korea's Avatar
so i recently had a kinked hose on the return side of my fuel rail. im sure that it caused my fuel pressure to go off the charts. what my question is would a kinked return hose cause my injectors to go static?? and also if they go static does it mean i pretty much need new ones?
Old Apr 22, 2008 | 09:51 PM
  #1538
gen4maxima536's Avatar
TIA for any help.
Bruce
just ATF, it is all linked together, the only drain plug i know of is in the bottom of the pan.
Old Apr 23, 2008 | 01:57 PM
  #1539
john66ny's Avatar
'98 Maxima non-Bose HU
My kid put coins down the tape slot of my head unit - '98 Maxima - non-Bose - model # CN-585, and according to my favourite shop, it's pooched! For some strange reason I'm feeling like replacing with an OEM unit instead of aftermarket... I know, I know, there's no logic to that decision!
Anyhow, other than eBay and posting here, can anyone recommend a source for this unit (new or used?)....
John (johnsk8 at cogeco dot ca)
Old Apr 23, 2008 | 07:43 PM
  #1540
Nismozx720's Avatar
In dash phone
I've heard of an in dash phone factory. Has anyone else seen or heard of this. I have searched for more info and found it was an option but can't find any pics or write-ups. Can anyone give me more info. Thank you!
Old Apr 24, 2008 | 08:28 AM
  #1541
Kilo15's Avatar
I'm a total nubcake and I have a quick question. I recently got a 99 Max SE and its having a delayed response when I gas it. I pulled codes and it said i need to replace an o2 sensor. But the previous owner said he took it to a mechanic and said it needed a new ks. But its not showing up in as a Trouble code. Should I go ahead and replace the KS anyway? Thanks
Old Apr 24, 2008 | 11:30 AM
  #1542
start with the O2, you may need to replace the KS in the end anyway, but o find O2s to be easier to replace
Old Apr 24, 2008 | 11:31 AM
  #1543
i've never heard of this, the only car phones i've seen in maximas were the old built in car phones. i think most people just use their cell phone now days.
Old Apr 24, 2008 | 11:33 AM
  #1544
Originally Posted by john66ny
My kid put coins down the tape slot of my head unit - '98 Maxima - non-Bose - model # CN-585, and according to my favorite shop, it's pooched! For some strange reason I'm feeling like replacing with an OEM unit instead of aftermarket... I know, I know, there's no logic to that decision!
those are about the only ways. waiting till you get 15 posts to post a wanted int he FS section, go to the junkyard or look on ebay
i don't see change sitting in the tape deck to kill the deck. i would think you could just pull it out, dump out the change, and keep on truckin. unless it actually did fry it.
Old Apr 24, 2008 | 11:41 AM
  #1545
ROCKART's Avatar
wants an I35
lol @ coins in the tape slot.
what did he think was going to come out? candy?
Old Apr 24, 2008 | 01:59 PM
  #1546
Kilo15's Avatar
Does anyone know a good brand for o2 sensors? Advance has Bosch, Niehoff, BWD, and Beck/Arnley.
Old Apr 24, 2008 | 02:07 PM
  #1547
bigpulve+'s Avatar
Bosch is just fine.
Old Apr 25, 2008 | 06:37 PM
  #1548
austinh3's Avatar
Originally Posted by ROCKART
well, like i said the emissions thing only pertains to when your car is warming up. after like 20 minutes, it would be the same as stock.
no, removing the forward cats will not trip the CEL
and the perk to removing them is increased horsepower, becuase the car can breath that much better. ive heard numbers ranging from 8hp to 20hp, simply by putting on an aftermarket Y.
and no youre not going to be able to find an OEM y pipe unless its from a member here. you can go to the dealership, but it will cost and arm and a leg.
1997 Maxima:
Will a high performance y pipe will still pass emisions (in Massachusetts) with front cats removed and attach to the rear cat also not set of a code?
Old Apr 25, 2008 | 06:39 PM
  #1549
austinh3's Avatar
1997 Maxima:
Will a high performance y pipe still pass emissions (in Massachusetts) with front cats removed and attach to the rear cat also not set of any code? Is a 20 minute warm up all that is needed to pass emission test?
Old Apr 25, 2008 | 08:02 PM
  #1550
jxhopper's Avatar
A coworker has a problem with his 1995 Maxima. The car stalled on him today and it will not start. The problem is not the alternator, the battery is charged fine. When I try to start the car I hear the relay click. From some research and him telling me he sometimes has difficulty getting the car to start, I thought it was the ignition switch. I thought this because this is the only reason I would think the car would stall and not restart. When I say restart, I mean it will not crank at all. I hear the fuel pump spool up and a click I believe is the relay, but that's it. All electronics, lights, radio and lights work.
I replaced the ignition switch but no joy...I still get a click. I checked the engine codes and get a 0100 and a 0325. I don't think these would prevent the starter from turning over would they? (MAF malfunction and Knock sensor malfunction).
I thought maybe a bad starter, but this would not cause the car to die while driving. I'm thoroughly stumped but I have no experience with this type of car.
This coworker is in dire straights and any help you could give me to help him fix his car would be greatly appreciated.
Thanks,
Jason
Old Apr 25, 2008 | 08:28 PM
  #1551
shyheim07's Avatar
Not a noob, but curious...
can i run the maxima without the air conditioning compressor on the belt? You know,
instad of the belt being on the idler pully, alt, compressor, and crankshaft....
make it idler pully, alt and crankshaft?
Old Apr 25, 2008 | 08:41 PM
  #1552
NmexMAX's Avatar
dot dot dot ...
Thanks,
Jason
I believe the starter is bad. When the IGN switch goes, you cannot hear the click. When the starter goes, you can hear the click, bot nothing happens. It could also be bad grounds.
1.) Remove the starter and take it to your local AutoZone or any other part store and have them test it for free. Search on here as there are many threads on changing it. If you remove the airbox, it is in lain sight and straight forward to remove. Spend time under the hood, it doesn't take much.
2.) The stalling is caused by the MAF sensor, which you already have code for. Go to www.car-part.com and search under Air Flow Meter, they are cheap (less than 50$)
Perhaps send him to this site?
Been doing it for years. Search : Bypass AC
Originally Posted by austinh3
1997 Maxima:
Yes, it will pass if the main cat is left on and the car is allowed to reach operating temperature prior to emissions testing.
Old Apr 26, 2008 | 07:23 AM
  #1553
jxhopper's Avatar
Many thanks for the info. I will get the starter out and check it.
Old Apr 26, 2008 | 03:08 PM
  #1554
ZX9RBART's Avatar
Adding keyless
I've searched and searched but never found a definitive answer. I have a 98 se that did not come with keyless, however, behind the antenna is a cable taped up that has a white plug with 4 wires in it. My question is...do I just need to buy a keyless module and keyfob?
Old Apr 26, 2008 | 05:23 PM
  #1555
astrikrace's Avatar
Avic-d3 and dash
I have searched and found some information on removing the dash but have another question about installing the navigation from pioneer. I have heard problems about watching dvds when u travel above 10-15 mph.
Is this becuase of the speed sensor wire? Where is that located and should i not connect it?
Also
Old Apr 26, 2008 | 05:24 PM
  #1556
astrikrace's Avatar
Avic-d3 and dash
I know how to do the bypass. But...
Also any more indepth information on removing the dash where the radio is?
Old Apr 28, 2008 | 06:24 AM
  #1557
NmexMAX's Avatar
dot dot dot ...
Probably not a good idea to watch DVD's @ an speed.
Since the VSS is frequency driven, that might cause some noise, but
Old Apr 28, 2008 | 03:33 PM
  #1558
prekoshus's Avatar
i have a tape/cd unit non-bose from my '97 max gle. im willing to sell it. what u want to pay for it? boodah.nayshun@gmail.com
Old Apr 29, 2008 | 03:56 PM
  #1559
97maximany's Avatar
I wish I could start a thread on this subject . I search for hours but unable to find a answer.....SPlash Guard / mud flaps will this effect handling in the rain.....I would image that they provent the rain from properly exits off the tire.......? Don't know if I should take them off for safety reasons
Old Apr 29, 2008 | 06:37 PM
  #1560
dgeesaman's Avatar
Maintenance Monster
No effect. Use them without issue.
If rain performance is a concern, get a good tire and replace it *before* it wears down to the limit bars. The primary determinants of good rain performance are well-design tread and good deep grooves.
Dave
