NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
got new fan assembly at a junkyard for only 100 bucks and they work just fine now. Now onto the next problem. When my car hasn't been on for over an hour it will die right after it starts...i have to press the gas for it to start then it hesitates at low rpm's before leveling off. I have changed the fuel filter.
98 gxe
98 gxe
i have this same issue after putting a bunch of aftermarket parts on my car. i started a thread in the 4th gen section called "4th gen GURUS - still have warm cranking issues"
Fuel requirement difference between 96/7 and 98/9?
Hi guys!
So I'm out looking for Accords to replace my 3/4 ton Suburban (12mpg), ran across a 99 Max, and quite simply, fell in love.
Went to http://fueleconomy.gov to check out the mileage, and noticed something rather strange. While the site lists 96s and 97s as needing premium fuel, it has the 98s and 9s using regular.
Aren't all 4th gen engines the same?
Is this an error, or did the minor emission tweaks made during the 4th gen's cylce allow lower octane gas?
Not a deal breaker, but if there is a difference, I'd probably go with the later years.
Thanks,
Chris
Thanks,
Chris
Hi guys!
Thanks,
Chris
Thanks,
Chris
I dont remember the number, but my friend pull codes with his little computer and he said it was the rear o2 sensor. Theres not really any power in 2nd and 3rd gears when I give it gas, sort of laggy.
the rear o2 sensor (as i have been dealing with this problem for the past few weeks) is code P0136.
it will NOT affect performance in any way - it is purely an emissions requesite to measure the efficacy of the catalytic converter.
sluggish response, for most noob vehicles is the KNOCK SENSOR, which is a ghost code- meaning it wont trip the CEL but still will be telling the ECU it is faulty. start there.
Im sure im gonna catch hell for this but I am not new to cars just new to maxima's so....can some one list out the specific differences between the 95/96 max and the 97/99 versions and how big of a difference does it make when ordering parts for a 95...if it specifies for 97-99 yrs?
JB, 95 SE
JB, 95 SE
JB, 95 SE
JB, 95 SE
Anyone know if there is a tranny cooler install write up on here? Ive been searching all day since im messed up on lortabs from gettn the wisdom teeth taken out today. I dont want to try guess and check on the lines in my car. Also, any reccomendations on the best rear sway bar? I graduated from H.S. sunday and have some extra cash to spend.
Thanks in advance
Thanks in advance
Thanks in advance
Thanks in advance
try flipping the auxillery cables around that always my problem. also make sure you have the speaker to amp connections in correctly.
ok i have a quick question ok i got a free used amp with a set of 15inch subs i bought from a friend and it doesn't work the power light comes one with i have it wired up but no sound comes out when i have a speaker wired up to it and i know the wires from the head unit are wired correctly so is there any way i can fix it
i know the subs work i tested them with a 500watt bazuka amp
So, I'm shopping for a high mileage 4gen, and have noticed a pattern of oil leakage on the top of the passenger side.Seems to be emenating from the cam sensor(????), and either migrating towards the rear, and downward.Is this typical, and if so, how much of a PITA is it to fix? If it is indeed just the sensor, it looks pretty simple.Is there another common leak which pops up frequently on the front/top of these?
99 SE 5 speed: suspension overhaul
Hey folks,
I'm new the forum and just started looking around. I've happily owned my 99 Maxima SE 5-speed manual, loaded with black on black leather for almost two years now. It's got about 260k and it's still going strong. The only things I've done to it since I bought it is a tune-up, brakes, battery, regular synthetic oil changes and a K&N air filter install. It's completely stock
But the suspension is starting to go, it's making the car feel like a Crown Victoria and I'm lookign to overhaul it.
I want to get new springs, shocks, a rear sway bar and a front strut tower brace.
So I’m wondering what advice you have for a newbie like me who likes his maxima, wants it handle much better, but doesn't know much about mods and aftermarket parts?
I looked on the forums and Cattman U.S.A. is selling the following:
Progress springs/KYB Full Suspension Package with KYB AGX adjustable struts, including sway bar for $699.99
Other people also seem to like Tokico Illumina shocks with eibach springs.
I don’t really know anything about suspensions, so I’m wondering what you think? Also, are their places in Toronto that are good to buy these parts…instead of ordering from the U..S.A.?
Thanks for the info in advance.
99 Maxima SE, 5-speed black on black
uhm if i hit a curb and bent the driver side inner tie rod can i just replace that or should i be doing more or looking for more damage? cause ebay has this package that seems good, item number: 290231874191. sorry i dont know how to post link, plz dont chew me out guys.
235/45R17 or 225/45R17 will probably be your best bet. depends on the offset of the wheels too
yea, it is a good deal, but look around for a while a number of people have picked up kits like that, and the quality is poor, and doesn't last long
Sry not new to the car game but new to the terminology and modding my own lol
What is a MEVI and what are the gains???
Also what is a y-pipe and b-pipe??? I mean I know what they are but what do they profit your ride???
So, how common are tranny leaks on these?
Damn near every one I've crawled under, has a little fluid accumulating on the big-*** bolts located between the wishbones on the driver side. They all seemed to shift fine, but fluid leaks scare me.
http://forums.maxima.org/showthread.php?t=53828
Pop the hood, and look at the brake fluid reservoir area. If there is an ABS module (metal box w/ metal lines going everywhere) then you have ABS.
well when shopping parts a lot of the time i see them listed for 95-99 but quite often they're listed for 97-99 instead....ive seen it on suspension, brake, internal engine mods and turbo kits. I know its the same motor, so Im a little confused why they wouldnt include 95-96 models in their part spec
I did the same thing and ended up replacing the right lower control arm, and the tie rod, as well as getting a new strut, and a new wheel...so just check the damage...if your wheel is almost touching the back of the wheel well your looking at a control arm at the least
that people who are selling these parts know
they're talking about. Do you have links, etc to these places that are calling out different P/N's for internal engine parts & turbos, etc?
"Depends on the brand. Typically, they will mount to the MAF sensor housing with a bracket / adapter."
Do the short rams generally just come with that, with everything you will need?
If anyone has gotten a short ram from somewhere for their 96, could you please link me?
Or anyone, please link me to some good ones...Thanks
Well, then, there's your answer. eBay = not the place you want to be building a quality turbo kit or internal engine parts, unless there is proven documentation (a la VQ35 cams)
http://forums.maxima.org/forumdisplay.php?f=17
http://forums.maxima.org/forumdisplay.php?f=43
http://www.courtesyparts.com/betasit...utton=Go&cat=1
