NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
Originally Posted by Cdg2125
How many times are you posting this? If you do the swap and have no problems with start up then it's fine.
Hi guys, new here, ive searched, and somewhat found what i was looking for, hear me out before deleting this thread. My check engine light came on, i came to these forums for the answer, and there is a great explanation and walkthrough for "4th gen" maximas, i have a 99 se 5 speed manual tranny. well under the walkthrough, someone posted with pictures, what to do for a 99, because it is slightly different, and yes it seems to be, BUT, the pictures are not working, and i cant tell exactly what i need to do, ive got the cover off, and i THINK im at the ECU, but it says for IDLE ADJUSTMENT on what i think is the ECU. so any help would be greatly appreciated, Thanks
MG
MG
i-30 hood on 4th gen?
Has anyone used the i-30 hood on their 4th Gen? What mod/fab was required? Was thinking about this the other day cause im not feeling the 99grille, but tryna avoid doing the same old 95-96 that everyone else does. Thanx for taking time to reply.
EVAP fault code
Hey guys, sorry if this is one of those topics that has been beaten to death already, but I've read the FAQs and stickies over and over and I can't find a definitive answer to my problem. I need to take my '97 GLE through emissions this month and I've had the SES light on for awhile. I checked the codes and got the dreaded 0705 EVAP Control System and 0903 EVAP Canister vent control valve codes. I cleared the codes once before only to have the light come on again a few days later. Is it possible to uh, "cheat" and clear the codes right before I have it tested, or will it still more than likely fail testing (in CT)? As far as doing the right thing and fixing the problem goes, can anyone point me in the right direction as far as what components to specifically check and/or replace? I ask because the FAQ mentions it could be any number of things.....is there a certain part or parts in the EVAP system that typically go bad?
Thanks in advance for any helpful replies and thanks to the thread starter for giving us noobs a break.
help please! i wanna make my 95 side mirrors heated.
i just picked up a pair of 3-gen max's side mirrors that are heated. my passengerside was broken when i bought the car a month ago, so i thought well if i m gonna replace the boken glass why not just make it heated. since i live in canada, (alberta) and heat is a very very good thing in those long winter days.
if anyone can help me out it will be great. thanks guys
Originally Posted by mge2790
if i get a new throttle body (probably from a pathfinder or 350z) will it just be bolt on, or will i need to alter anything in the engine bay?
Replace the EVAP canister vent control valve.
Really? Is it just that simple (assuming that it's a simple job)? Are they available at your local Autozone, or is this something that needs to be ordered from a dealer?
I have a 1995 Maxima GLE with 195k miles that I purchased last Monday. Its a great solid car but has very weak acceleration and throttle response.
I know it is older, high mileage car but it should definitely be more peppy than it is. If I were to 0-60 test it I would be lucky to get 10 seconds.
Is there a common problem that might cause it? I replaced all the spark plugs recently and did regular maintenance on it.
Thanks!
Thanks!
Thanks!
Thanks!
Yes, very common problem, the knock-sensor, read all about it in the 4th gen stickies. And seafoam that thing....
Yup I did the fuel filter and sea foamed it all. It did help a bit but still didnt help the acceleration issue.
Is there a way to fix a knock sensor or is it pretty much a buy a new one?
Originally Posted by PatD14
I own a '96 Max and I'm having trouble opening my trunk, the valet switch isn't turned on, the only way I can open it is if I have someone pull and hold the trunk lever on the floor on the drivers side while someone else pulls up on the trunk. Could my trunk be too heavy because of the spoiler? It's a stock spoiler.
Originally Posted by iyzmi
This may have already been answered in here but which year 4th gen was the most problematic and which was the most reliable? If I were buying one now, which year should I look for? I was thinking I wanted 99 because of traction control but then somebody said 99 was the most problematic so now that got me thinking.
hey i have a question. i've heard people say that you should only use premium gas on a maxima, with an octane rating of 91 or higher. i know premium gas is better than regular but does it make a big difference or is it really worth the extra 20 cents per gallon to go premium??
and also if people could please reply to this by telling me which type of gas they use (regular, midgrade, or premium) and how much mileage they get on a whole tank.
thnx in advance.
thnx in advance.
thnx in advance.
thnx in advance.
http://forums.maxima.org/showpost.ph...64&postcount=9
Hey,
Thanks for the above replies regarding my acceleration issue. ECU'd the sucker and of course knock sensor came up as well as random misfire and primary ignition fault.
Now heres a new question...
Will a 2001 Pathfinder HU fit in a 95' Max? Some say it does but id like to check here. Is it a direct fit? Any wiring issues? BTW its also a Bose deck.
Originally Posted by brucyy
My fuel indicator light will not turn on when the level is very low. Is there a fix for this? Is this an easy fix?
~ 2-2.5 g left in tank. It's a friendly reminder.
what types of gains can i expect from a ypipe alone, should i go with a short ram intake instead?
That's what it's supposed to do ~ 2-2.5 g left in tank. It's a friendly reminder.
Reading > me.
Maybe he & you just have not let it get that low.
Is it always on?
Originally Posted by black_maxed95
so it is suppose to stay on until you have low fuel then goes off? that is opposite of every car ive ever seen.
im wondering cause ive never seen my light go on in the year that ive had it until last week i swapped all my gage lighting for red leds and now the fuel light is always ___(i havent had a chance to get to low fuel since then)
Ive never ran out of gas but Im pretty sure Ive got real low where it should have turned on. I rarely fill up unless the needle is on the E. And ya now its always on, sorry. I was thinking since I changed a bulb with an led I might have the pos/neg backwards but that should make it so it never lights also, I dont know.
Im confused by what you said, so say you have a full tank for example, should the light be on or off?
Hey,
Hey,
did you fix the problems or are you ignoring them? Seems like you disregarded the problems haha. Anyways, yes the 01 PF hu fits. You need to drill new holes tho.
About the problems, no.. i havent yet done anything with them haha. Im gunna pick up a new knock sensor. That is fix obviously the knock sensor issue and I think the random misfire. As for the primary ignition fault... I have no clue, ill have to research the code and see what that tells me.
when I changed the spark plugs the front right (looking at the engine from outside) it obviously wasnt firing, corroded, oily and stuff.
I changed that plug, ran for about a week and re-checked it. It was clean and had been firing properly. So that may be the primary ignition fault? I havent rechecked or reset my ecu since.
*edit* Sorry, its a 00 - 01' MAXIMA and I30 Bose hu, not the Pathfinder, I dont know what I was thinking. But yeah, is it the same thing?
one quick question: On my Maxima, if I turned off the engine, pull the keys out, and still have the leadlights on, it doesn't warn me or make this warning sounds like most cars do. How can I make it possible? Is there anyone who has done it before?
Thanks, Will I need a new wiring harness? I have the Bose system btw.
For the firing problem, look into your coils.
id suggest fixing everything but the knock sensor, reseting the ecu light, and driving the car as usual for a while. i had the knock sensor code about a month ago along with some others and i fixed the rest and it still hasnt tripped it again. the knock sensors in max's almost always trip the light if anything else is making it go off.
ok so the other day like a retard i let off my clutch while i was still in 3rd gear when i was parkin my car n it stalled, now when i shift or let off the gas there is a slight clanking noise n it feels like its slammin into gear alittle bit espeiciallly in reverse, any ideas???
