NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
Old Mar 18, 2009 | 06:35 PM
  #3001
pmohr's Avatar
No more Maximas...
Originally Posted by (Cody McKown)
ya, well i'm lazy as hell. i guess my question was exactly what i'd need to install an aftermarket HU in place of my bose one. I found a good thread on what i'll need but i always like to cross check everything before destroying anything in my car. I guess i was also interested in what i would gain by getting a high flow cat, although both questions are completely random
If you want to be lazy, and you're going to proclaim such, people are going to be a lot less inclined to help you. You have to do some of the work yourself, can't rely on everyone else spoon feeding you.
You wouldn't gain any appreciable amount of power with a HFC.
For replacing the Bose, you either need the converter or you need to replace all of the speakers.
Old Mar 18, 2009 | 06:40 PM
  #3002
(Cody McKown)'s Avatar
and also where some people get those black maxima badges that are in the front that are like 2 circles surrounded by chrome. They look nice, right now my burger is just painted black and looks a little tacky
Old Mar 18, 2009 | 06:42 PM
  #3003
wai18's Avatar
Originally Posted by pmohr
Not at all, it's just a dozen bolts, take out the old gasket and insert a new one.
Front or rear? If it's the rear, it also requires removal of the UIM and associated parts.
both front and rear are leaking. how long does it take to replace both? is it better or easier to do the front first then do the rear the next day? about how much it cost to buy parts from dealer? its there any special tools i need to use? what's UIM? i'm noob so please help!!
Old Mar 18, 2009 | 06:43 PM
  #3004
pmohr's Avatar
No more Maximas...
Do you have a picture of what you're referring to?
Old Mar 18, 2009 | 06:52 PM
  #3005
pmohr's Avatar
No more Maximas...
UIM == Upper Iintake Manifold.
Your first time, depending on whether or not you're any good with mechanical work, could take from 2 hours to 2 days or more.
Why would you do them on separate days?
You don't need any special tools, a basic set of hand tools will do just fine.
It's about $63 for both VC gaskets and the 6 plug tube seals from Courtesy. Personally I would (and I did) just buy a full gasket kit from eBay, so you can replace the UIM-LIM, EGR guide tube, TB, and IACV gaskets. You'll probably want to clean the EGR tube, your TB, and IACV while the UIM is off.
Old Mar 18, 2009 | 07:02 PM
  #3006
ATTappman's Avatar
The front is easy, should take no more than an hour, depending on how long you spend scraping and cleaning. The rear is much more time consuming; I spent all day doing it, but half of that was cleaning the IACV, the throttle body, the EGR guide tube, and the upper intake manifold (UIM) itself. Removing the UIM is hard because the bolts on the back of it, and on the EGR guide tube, and very hard to get to. A 12mm offset wrench is useful for getting those bolts off. Also there's two coolant hoses attached to the back of the UIM that are hard to get off.
From a dealer the gaskets are around $18-$20 each. You should also replace the spark plug tube seals - about $5 each and there are six of them. Finally, it's a good idea to also replace the UIM gasket ($5), the IACV gasket ($5, not strictly necessary to remove the IACV but makes things easier) and the EGR guide tube top side gasket. You can get a Felpro or Carquest gasket set for $50-$60 that has the valve cover gaskets, tube seals, and valve cover bolt grommets, but I found the spark plug tube seals didn't fit, so I wasted my money.
I'd say this - if you consider yourself a "total noob" then you can do the front cover, but I wouldn't attempt the rear unless you can get somebody more experienced to help.
Old Mar 18, 2009 | 07:06 PM
  #3007
wai18's Avatar
i searched ebay can't find any gasket kit for my car. could you show me some links for the gasket kit? thank you
Old Mar 18, 2009 | 07:14 PM
  #3008
pmohr's Avatar
No more Maximas...
http://shop.ebay.com/items/_W0QQ_dmp...+set&_osacat=0
I bought this exact one here - http://cgi.ebay.com/ebaymotors/95-99...6504QQtcZphoto
As far as I remember, it was about $10 cheaper when I got it, like a year ago. Everything was perfect fit and OEM quality. Still got the head gaskets and valve stem seals sitting around here somewhere...
Old Mar 19, 2009 | 12:49 AM
  #3009
Leo_Koneval's Avatar
Hello I have another silly question. I tried googling this for a while but I always get some weird how-to.
But my question is that, can you apply clear coat on your car just for a shine just like the way you apply wax except you spray on clear coat instead?
I tried spraying some clear coat onto a cloth and then wiped it on my brothers (old, old, and abused) work truck, and the color just instantly came to life. So, are there any negative effects? Should I sand the car down first? Or should I just avoid this whole thing in general and just wax it. THankyou!
Old Mar 19, 2009 | 07:38 AM
  #3010
allensteiner21's Avatar
if you wet sand too much your paint will look like crap - even worse after clear coating.
if your original clear is not peeling away - wash the area you'll be spraying, let dry, wipe with a lint free towel with paint thinner, let dry and apply clear coat ( if there's dust or any other contaminant in the air that can settle on the wet clear the job will be ruined).
paint is very easy to mess up so think twice before learning on your own car. you can try and learn on your brothers truck
Old Mar 19, 2009 | 07:41 AM
  #3011
Originally Posted by Rob_0126
It's just prestone ps fluid with added stop leak, not like a lucas gob I suppose.
Feels the same like before.
You think atf would work better?
^ nope. something must've been done wrong during installation or they gave you a bad or wrong ps pump. go back to the shop and have them fix it as many times as it'll take themto get it right.
Old Mar 19, 2009 | 06:01 PM
  #3012
Hahah, thankyou. I have had a lot of experience with messing with paint haha. But, now I know what you are saying, I need to remove the old clear coat first or at least some of it before I spray on a new layer.
But I looked back on my brothers truck and now I see that the place where I put the clear coat is peeling off. Guess it was too thin! Maybe I should just stick with wax LOL
Old Mar 19, 2009 | 06:29 PM
  #3013
Rob_0126's Avatar
new ps pump low groan
Any ideas on this folks?
Old Mar 19, 2009 | 06:37 PM
  #3014
One Post Wonder's Avatar
I have a few questions about the 6 speed swap. First, does the cps hole have to be enlarged if you use a FWD (Maxima) flywheel, or is that just for the RWD fidanza flywheel? Second, did anyone have to use a leveler when they were installing the 6 speed trans mount to make sure the engine/transmission assembly was level? Third, could someone elaborate on the starting problems people are having with this swap? I've read something about grinding noises, stalling on startup, or not starting at all.
Old Mar 19, 2009 | 07:15 PM
  #3015
Jeffp's Avatar
Know any good mechanics in Chester County PA?
Man, I can't wait 'til I get my 15 posts!
In any case, I'm going to need a new exhaust system soon on my '98. Probably won't make it past another PA inspection. Pretty rusty, including the catyl. converter, so I'm expecting the worst. It's original.
Two questions:
Anyone know what would be a fair price?
Anyone know a decent shop in Chester County? I'm in Downingtown.
Thanks.
Old Mar 19, 2009 | 07:18 PM
  #3016
pmohr's Avatar
No more Maximas...
Two questions:
Thanks.
Fair price for...what? Repair at a shop, a custom exhaust at a shop, OEM replacement pieces, or an aftermarket catback?
And for any sort of local information, you need to go here - http://forums.maxima.org/northeastern-u-s-11/
Old Mar 19, 2009 | 07:27 PM
  #3017
pmohr's Avatar
No more Maximas...
It wouldn't matter, the flywheels are the same except for the timing ring, which you wouldn't be using (you would use the VQ30 timing ring).
No real need to level everything out, the other 3 mounts hold it in about the right position. Besides, there's no real adjustment for moving the mount up/down, as it sits on the frame rail (for lack of a better term).
If you're having starting problems, you didn't do it correctly. If isn't starting properly, then there's a timing ring or CKPS POS alignment issue. If there's grinding, then something obviously wasn't installed correctly, as there are clearance issues.
Have you read this thread?
Old Mar 19, 2009 | 07:33 PM
  #3018
pmohr's Avatar
No more Maximas...
The system is designed for ATF, not PS fluid. Not a major difference, but just an FYI.
Old Mar 19, 2009 | 08:37 PM
  #3019
Thanks for the info. I did read that thread but I needed someone to elaborate on some of the things in there. I have not done the swap yet but I was reading about other members that have done the swap and apparently had some terrible starter noise at startup.
Old Mar 19, 2009 | 08:42 PM
  #3020
pmohr's Avatar
No more Maximas...
Grinding could've been from the wrong starter, or I believe the earlier Fidanzas had some problems with that.
Old Mar 20, 2009 | 11:50 AM
  #3021
Adalad's Avatar
Knock sensor pricing
I need to replace my Knock sensor in my '97 SE. Looking around online, most of them range from $125 to $170. Then I went to Checker's online and found that they had 4 different sensors available. The first 3 were $150s to $170s then the last one was $72. They all have "Limited 1 year warranty".
So, what is the difference in quality? The $72 one is made by Master Pro. Here is the link:
http://shop.oreillyauto.com/ProductL...pe=412&PTSet=A
Old Mar 20, 2009 | 04:26 PM
  #3022
cvsmaxima's Avatar
As far as OReilly goes... the $72 one is not stocked and is of lower quality etc. They stock and can get faster the larger name company's parts bcause they are more expencive and most people are not patient when it comes to parts. They just buy what they can get to get the Check Engine light to shut off so their cars will pass smog.
Personaly, if you have the time to look, I think youd be better off looking for people online here that have them available. A lot of people here will strip these types of pieces off the junk yards, test em, and sell what they have come across. I know that I just sold one for $40+shipping. But that was my last one.
Old Mar 20, 2009 | 07:48 PM
  #3023
pmohr's Avatar
No more Maximas...
Just get one off of eBay. It's an OEM part in an OEM box for ~$60 shipped.
Old Mar 21, 2009 | 11:05 AM
  #3024
abhirud07's Avatar
A couple of days ago I decided to change my valve cover gaskets, both the upper and lower manifold gaskets, and spark plugs. In the process, I also cleaned the EGR (which was completely clogged with carbon deposits), the throttle body, the IACV, and the intake manifold. After I put everything together my car is now idling at 1500rpms, and after I took it for a 5 minute drive the idles shot up to almost 3k rpms. My idling was just fine before I did all this, and I also doubt that there are any vacuum leaks anywhere. I did a lot of research on this forum and got lots of good info, but I also have a few noobie questions which I couldn't really find answers to.
1) How much is the plastic screw supposed to turn on the IACV? Mine only seems to turn about 3/4 of a turn each way, so I don't know if it's doing anything. (I disconnected the TPS before adjusting this with the engine on and it didn't seem to do anything to the idling)
2) My high idle cam on my TB needs to be adjusted greatly. The marks are completely off, so how do I adjust it? Which bolt do i turn?
3) Is it possible that the increased idling speed is because the EGR isn't clogged anymore and exhaust gas is being recirculated?
4) If anyone has gone through this before, is there anything specific that I need to do to solve this?
TIA
Old Mar 21, 2009 | 11:06 AM
  #3025
Rob_0126's Avatar
transmission filter change
Few questions:
Could i use rtv on the tranny pan bolts to seal it, instead of buying new self
sealing bolts?
Once the pan is off, do I just undo the bolts on the filter to remove it, or is there any specific bolts to remove?
Can I clean the filter thats in the tranny instead of buying a new one?
Old Mar 21, 2009 | 11:11 AM
  #3026
Rob_0126's Avatar
Originally Posted by abhirud07
A couple of days ago I decided to change my valve cover gaskets, both the upper and lower manifold gaskets, and spark plugs. In the process, I also cleaned the EGR (which was completely clogged with carbon deposits), the throttle body, the IACV, and the intake manifold. After I put everything together my car is now idling at 1500rpms, and after I took it for a 5 minute drive the idles shot up to almost 3k rpms. My idling was just fine before I did all this, and I also doubt that there are any vacuum leaks anywhere. I did a lot of research on this forum and got lots of good info, but I also have a few noobie questions which I couldn't really find answers to....
I did the valve cover job on my 95. The only issue I had afterwards was an erratic idle, that would come and go every 30 sec. Turns out I forgot to plug the EGR solenoid back in. lol
Runs fine. Maybe you forgot to plug something back in?
And also, their are many vacuum lines that could easily be missed. Do you have a pic of your engine bay in the area of the IACV and bottom of the tb?
  #3027
pmohr's Avatar
No more Maximas...
TIA
  1. Should turn more than that.
  2. See below.
  3. EGR does nothing at idle speeds.
FIC adjustment:
Why do you doubt that there are any vacuum leaks? Just a guess?
It's a relatively common experience to get a higher idle after cleaning out the TB/IACV. Sometimes it'll adjust itself down after a bit.
Old Mar 21, 2009 | 11:23 AM
  #3028
pmohr's Avatar
No more Maximas...
Few questions:
sealing bolts?
It's not a filter, it's a screen. All you need to do is clean it.
No real need to RTV up the bolts, IME. It won't leak.
There are specific bolts to remove, but they're all rather obvious. They would be the ones holding the screen in place.
The bolts you need to remove are in black:
Old Mar 21, 2009 | 12:55 PM
  #3029
abhirud07's Avatar
  2. See below.
I think I know what happened. Here are a few pics of what I discovered. I believe that in all the cleaning the TB high idle cam adjustment might have been thrown off by accident. My TB is not closing all the way like it should during idling. I know that there weren't any vacuum leaks because I meticulously made sure that I knew which vacuum hoses went where before taking everything apart.
First, here is a pic of the area round the IACV/TB and the bottom of the TB as requested. All of the vacuum lines seem to be in place:
This is a picture of the high idle cam marks, they clearly are way off:
This is a picture of the adjustment screw that sits on the thermal piston thing, it is not sitting properly at all.
And finally, here is a picture of the inside flap of the throttle body (I think it's called a butterfly if I'm not mistaken). There is a substantial amount of opening here, even with the throttle valve down.
If you guys have any other thoughts it would greatly be appreciated.
TIA
Old Mar 21, 2009 | 02:24 PM
  #3030
Rob_0126's Avatar
Look right underneath the tb. See that black plug that just blocks off the vacuum?
Now, the hole next to it on the left. Where is the stem? On my 95, their is a stem there, that a vacuum hose goes over. Maybe the picture is fooling me?
The tb butterfly does look like it is too far open.
idk, what do you think pmohr?
Old Mar 21, 2009 | 02:25 PM
  #3031
pmohr's Avatar
No more Maximas...
Now, the hole next to it. Where is the stem? On my 95, their is a stem their, that a vacuum hose goes over. Maybe the picture is fooling me?
Best I've seen, some have it, some don't.
Old Mar 21, 2009 | 02:47 PM
  #3032
abhirud07's Avatar
Sorry, forgot to mention that I have a 1998 SE. I don't think there is anything that goes there on my year Maxima. I had a 1995 GLE, which I gave to a friend (started having tranny problems), and I was surprised to see how different both engines were. There seem to be many more electrical components to the 1998 models. But anyway, I adjusted the high idle cams and there still seems to be a gap around the butterfly. I will put everything back together tomorrow or so and get back to you guys. Thanks a lot for the help!!
And also, after I put everything back together I also started hearing a whining noise in the engine bay like this guy: http://forums.maxima.org/4th-generat...now-p0105.html
Old Mar 21, 2009 | 02:48 PM
  #3033
Rob_0126's Avatar
wheel torque and different rims
2 questions:
-Whats the torque specs on steel and aluminum wheels on the 95's?
-Was curious if I could put the 15's on my 92 camry v6 xle onto the 95 max gle?
I dont know if the offsets match, but I wonder if the wheels do on lug pattern?
It's the aluminum rims on a 92 camry v6 xle.
I have the OEM steel rims on the 95 max.
The rim says 15x6JJ and in between the other spoke, '45'
Old Mar 21, 2009 | 03:11 PM
  #3034
pmohr's Avatar
No more Maximas...
2 questions:
You'll have to measure the diameter of the center hub, IIRC the Camry's is larger.
Is that a coupe or a sedan? I would love to get a 1MZ 5MT coupe...
Old Mar 21, 2009 | 03:22 PM
  #3035
Rob_0126's Avatar
Sedan, and it's an auto and 3VZ. Blown head gasket, so Im selling it.
btw, do you have those torque specs on steel and aluminum rims?
Old Mar 21, 2009 | 03:28 PM
  #3036
pmohr's Avatar
No more Maximas...
Lugnut torque specs are right around 85 ft/lbs, IIRC.
Old Mar 21, 2009 | 03:46 PM
  #3037
Rob_0126's Avatar
would it be bad to set them at 72-74? The ratchet torque wrench i have only goes to 74. :/
Old Mar 21, 2009 | 03:48 PM
  #3038
pmohr's Avatar
No more Maximas...
Why would you?
Just follow factory spec...
Old Mar 22, 2009 | 08:46 PM
  #3039
abhirud07's Avatar
I got a chance to put everything back together today and idling is still high. As far as the EGR whining noise or whatever, it is gone now. As it turned out I forgot to put the EGR gasket in (not sure if that specifically solved the whining noise). There is no CEL, just high idling even after adjusting the high idle cam. Is it possible the IACV is stuck completely open? And I tried turning that plastic screw on top of the IACV while it was out, but the thing wouldn't turn that much at all for some reason.
Old Mar 24, 2009 | 04:27 AM
  #3040
Rob_0126's Avatar
Lucus for powersteering
A few posts back, Ive explained a noise, a low groan coming from my new powersteering. It is a cardone and prolly reman'd.
I talked to a mechanic, he said it's probably the way the rebuilder did the valves and is common. As long as the noise doesn't get louder, it should be ok.
But he said you could use some Lucus for ps's and it would quiet it up some.
Any experiences about doing this?
