NOOBIES: "I AM NEW HERE BUT HAVE A QUESTION" thread. Read FIRST post BEFORE posting!
Old Jun 12, 2009 | 09:05 PM
  #3881
transaxle's Avatar
right at the bottom of the trans where the trans butts up to the engine there is that notch in the casting on the tranny side (im assuming its there so that fluids like water or whatever wont build up and sit there)
it happened while i was driving, i saw smoke pouring out out from my hood and it smelled like burning atf.. it was leaking from where i said and finding its way to my exhaust. soon after that it started slipping due to the little fluid that was left. what could be happening?
Old Jun 12, 2009 | 09:08 PM
  #3882
pmohr's Avatar
No more Maximas...
Could be a damaged converter or bellhousing, input shaft seal, etc. For fluid to pour out, it would have to be a fairly large breach, or in an area that's under pressure.
Either way, if your trans is pouring fluid out of somewhere that's inaccessible, you're going to have to pull the trans to find out exactly what it is.
Old Jun 12, 2009 | 09:14 PM
  #3883
transaxle's Avatar
okay< can you direct me to a site or give insite on how to remove the trans? i have a chiltons manual but it is so vague on certain steps.
Old Jun 12, 2009 | 09:18 PM
  #3884
pmohr's Avatar
No more Maximas...
The FSM is a good resource to have, just for overall information.
The 5 speed swap instructions have a quick rundown of dropping the trans - http://www.dynomagic.com/5spd_conversion.htm
The VQpower copy is easier to read: http://www.vqpower.com/v2/articles.php?article_id=44
Old Jun 13, 2009 | 12:04 AM
  #3885
J RO 9's Avatar
After changing plugs (preventative maintenance), my Max is misfiring. When I give it gas, the car vibrates. When I accelerate heavy from a stop, its even worse, and I can feel it especially around my feet.
Also, at a stop, when I let go of the brakes, the car does not inch forward; its like its in neutral. When I give it gas, it gets into gear.
I do NOT have a check engine light.
Is this a coil pack problem? My guess would be a rear coil pack.
Old Jun 13, 2009 | 03:08 PM
  #3886
pmohr's Avatar
No more Maximas...
Why do you assume a rear specifically?
What year are you? Have you checked all of your work again? Checked connectors, made sure none of the plugs were cracked, etc?
Old Jun 13, 2009 | 03:58 PM
  #3887
RUDDER's Avatar
Originally Posted by pmohr
Whichever it is, you still need to replace the solenoid if it isn't working properly. Again, check all of the fuses, as well as both circuit breakers.
Thanks for the tip, I checked all the fuses on the J/B and the Fusible Link box again and unfortunately they are ok. The only one I couldn´t check is the 120A. I couldn´t pull it out but looks fine. Is there any technique required or I just need a pair of pliers?.
I will play safe and I will change the starter ASAP.
Anyway, I think I have some electrical gremlins too, I do not understand why the power lock and windows don´t work now, couldn´t be a relay issue?.
And what about the Security Light, why is permanently off now?.
Thanks for any advice!
Old Jun 13, 2009 | 04:16 PM
  #3888
J RO 9's Avatar
i'm a 97
i assume it is a rear because the one in the middle was hard to get out. when my buddy pulled it out, only the main piece came out. the "stem" was still in there, and he had to fish around to get it. when he got it all out, he put the coil pack together
Old Jun 13, 2009 | 05:09 PM
  #3889
RUDDER's Avatar
I forgot to ask a silly question: where are the circuit breakers located?
Old Jun 13, 2009 | 06:59 PM
  #3890
bassmann's Avatar
Location of o2 sensor for code P0136
Hi,I have a 1997 maxima I scanned for code and got P0136. Which o2 sensor is for that code? One person told me it is on the front of exhaust manifold and the other said it is near the cat converter on driver side. I need help I would like to do the work myself. Do I need a professional?
Old Jun 13, 2009 | 07:02 PM
  #3891
pmohr's Avatar
No more Maximas...
It's neither.
Code: P0136 | Description: O2 sensor fault
It's the rear sensor, for your car it's in the S-pipe in between the converter and the B-pipe.
I don't know, do you need a professional? We can't answer that question, only you can.
If you've got a wrench and a floor jack, that's all you need.
Old Jun 13, 2009 | 07:06 PM
  #3892
pmohr's Avatar
No more Maximas...
i'm a 97
So have you checked everything?
The alternator fuse should be held on by a nut underneath.
Power locks and windows both run through the circuit breakers, IIRC.
As far as the security light, It could be a damaged BCM, or a blown fuse, or a blown LED, wiring, etc. Really just need to start tracing it back.
Old Jun 13, 2009 | 07:15 PM
  #3893
v_i_pimp's Avatar
I'm pretty sure that's your acc belt, but if you ask me if you are replacing one belt might as well replace both so 1500 miles down the road you don't have a similar problem...
Old Jun 13, 2009 | 07:19 PM
  #3894
pmohr's Avatar
No more Maximas...
...do what? Who are you responding to?
These random responses are exactly why the very first post of this very thread says this:
Originally Posted by phenryiv1
ALL RESPONSES MUST BE A QUOTE OF THE ORIGINAL QUESTION!
Old Jun 13, 2009 | 07:22 PM
  #3895
bassmann's Avatar
Thanks,do you have a diagram for the location?
Old Jun 13, 2009 | 07:25 PM
  #3896
pmohr's Avatar
No more Maximas...
See my above post about quoting.
You can't really miss it, it's the only electrical part in the exhaust stream back there; nothing else has wires hanging out.
In that small section of pipe directly after the converter in that picture.
Old Jun 13, 2009 | 07:33 PM
  #3897
bassmann's Avatar
Thanks so its the sensor right after the converter with the wire going what looks like up into the floor
Old Jun 13, 2009 | 07:35 PM
  #3898
pmohr's Avatar
No more Maximas...
Again, see my post about quoting.
Yes, it goes into the floor underneath the LF seat.
Old Jun 13, 2009 | 07:42 PM
  #3899
bassmann's Avatar
Thanks your the man. What post?
Old Jun 13, 2009 | 07:43 PM
  #3900
pmohr's Avatar
No more Maximas...
Again, for the third time...
The only post that has to do with quotations. Hard to miss, it has big red text.
  #3901
bassmann's Avatar
When I order the sensor just say o2 sensor?
Old Jun 13, 2009 | 07:44 PM
  #3902
pmohr's Avatar
No more Maximas...
Learn to quote, or you'll have to find your info elsewhere.
It's an O2 sensor, yes.
Old Jun 13, 2009 | 07:55 PM
  #3903
bassmann's Avatar
So the same sensor can go in front and rear? I think I have two o2 sensors.
Old Jun 13, 2009 | 08:18 PM
  #3904
pmohr's Avatar
No more Maximas...
You have 3, not two.
No, the rear is a different type.
Old Jun 13, 2009 | 09:01 PM
  #3905
wai18's Avatar
my water pump looks like its leaking and my rear and front valves too. if i replace the rear valve gasket first then do the water pump later does it matter? do i have to take the engine apart again?
Old Jun 13, 2009 | 09:02 PM
  #3906
pmohr's Avatar
No more Maximas...
So it's leaking from the weep hole location by the alternator, then?
It doesn't matter in what order you choose to do it. You don't have to take anything off the top of the engine in order to do the water pump.
Old Jun 13, 2009 | 09:27 PM
  #3907
wai18's Avatar
is leaking from the passenger side of the engine at the rear belt behind the pully. i think that should be the water pump
Old Jun 13, 2009 | 09:29 PM
  #3908
pmohr's Avatar
No more Maximas...
Towards the rear of the car?
If it's actually leaking from there, and not just being blown back then no, that's not the water pump.
You are aware that our water pump is chain driven, not belt driven, right? You can't see it just by looking into the engine bay, you've got to remove the access covers.
Old Jun 13, 2009 | 09:48 PM
  #3909
wai18's Avatar
yea is toward the rear of the car. is a cover kind of looks like triangle shape. i wish i have pic to show you now.
Old Jun 13, 2009 | 09:55 PM
  #3910
pmohr's Avatar
No more Maximas...
Is it one of the access plates on the timing cover, or what?
Old Jun 13, 2009 | 10:21 PM
  #3911
wai18's Avatar
yea is the rear access plates leaking. is it the water pump inside that cover?
Old Jun 13, 2009 | 10:57 PM
  #3912
pmohr's Avatar
No more Maximas...
You need to start quoting replies, so there's context. See the big bold red letters in my post above.
No, the water pump is not behind the right side access cover. The only thing that can leak out of there is oil.
Old Jun 14, 2009 | 06:20 AM
  #3913
bassmann's Avatar
abs light
Hi,I have a 1997 maxima my abs light is on. Do you use a diagnostic tool to scan for a code?
Old Jun 14, 2009 | 10:18 AM
  #3914
bassmann's Avatar
battery cable
Do I have to disconnect the battery to change a rear o2 sensor?
Old Jun 14, 2009 | 10:41 AM
  #3915
RUDDER's Avatar
Yes, I think it might be a circuit breaker issue. I have tried the power seats and they don´t work either so this could be the Circuit Breaker #1, right?.
I have tried to gather some more info from other threads but I am still not sure about the shape of the circuit breakers:
Quote from another post from pmohr:
There are two circuit breakers underneath the dash
IIRC you just have to drop the fuse box to get at them.
I pulled out the big cover under the steering wheel and only saw wires and some connectors.
My problem is that I don´t know what I am looking for, is a circuit breaker something that "pops up" and then you have to push it to make it work again, like in a plane dashboard?. Please see the picture):
http://pics.livejournal.com/rudder1976/pic/000032qp
Does anybody have a picture of the area where the circuit breakers are located or just one of a circuit breaker?.
The Circuit breaker #2 should be in Yellow tape (according to the FMS), right?, but I cannot see anything yellow there.
What do I need to do when I will find them, push the stems IN again?
Thanks!
P.S. I just wanted to say that I am very thankful to the forum!. You are doing a great job here helping people like me!, this is great!.
I have to admit that although it is not nice to have the car unserviceable (just for now!) I am enjoying and learning a lot with you guys and although I am new here, I know I am gonna follow you for long time!.
I love my car and although I don´t know anything about she..., today I now a lot more than a week ago!.
I am really happy to have discovered this forum and I will be even happier when I will ride my Max again, and I am sure it will be soon!.
Thank you guys for all your help!.
Old Jun 14, 2009 | 04:07 PM
  #3916
pmohr's Avatar
No more Maximas...
Thanks!
They're not a simple on/off type breaker, they trip and reset automatically. If you lay on your back and look up underneath the dash, look up towards the clutch pedal bracket (or where it would be if you were a 5 speed). To your right you'll see a large grey connector with two grey wires right above the kickpanel, look directly above that. You'll see a white block with a gold bolt going through it, directly above that are two cylindrical objects, black caps with (IIRC) white plastic housings that clip in to that block back there.
Those are your circuit breakers.
Old Jun 14, 2009 | 04:16 PM
  #3917
pmohr's Avatar
No more Maximas...
No.
You can (if you've got access to a CONSULT-II), but not with a regular OBD-II code reader.
Old Jun 14, 2009 | 05:03 PM
  #3918
bassmann's Avatar
Transmission fluid
Where can I find a diagram for changing transmission fluid for a 97 maxima? I did not see anything on the site.
Old Jun 14, 2009 | 05:06 PM
  #3919
pmohr's Avatar
No more Maximas...
Auto or 5MT? By 'transmission fluid', I'll assume automatic.
http://forums.maxima.org/fluids-lubr...eck-level.html
Long story short: remove drain bolt. Wait. Replace drain bolt. Fill trans.
Same as you would with engine oil.
Unless of course you want to change out the filter, but even then it's only a handful of bolts.
Old Jun 14, 2009 | 05:10 PM
  #3920
bassmann's Avatar
Yes filter and gasket. I havent changed it. The last time was at 50k Im at 125k now. Dealer is to expensive.
