Whining sound in engine bay when AC on.
Old Jul 10, 2001 | 09:35 PM
teejnut's Avatar
hey the pass two days when i first start my car and turn on my ac at low rpms i get a whining sound coming from my engine bay for a short period of time. is this normal? can someone tell me whats wrong? and how to fix it?
Old Jul 10, 2001 | 11:51 PM
Eric L.'s Avatar
Well you should hear a click when the AC clutch engages, and there may be some noise, but it shouldn't be loud or obtrusive. If it is a high pitched whining it may be a problem with your alternator bearings.
Old Jul 11, 2001 | 12:16 AM
vmok's Avatar
If you blip the throttle, do you hear a squeal? If so, it could the AC belt could be slipping.
-V
teejnut's Avatar
yeah i know what you're saying about the AC clutch engaging.. its not that sound.. its like a high pitched whine...
Old Jul 11, 2001 | 12:32 AM
teejnut's Avatar
-V
hmmm where's the ac belt at? the squeal happens only at the beginning when i drive my car. after that it seems fine.
Old Jul 11, 2001 | 12:56 AM
teejnut's Avatar
i check my belts i don't think thats the problem... i'm also getting this what i think is unsual sound coming from the right side of my engine bay... its either air being sucked in or out... i might be from the intake... i don't ever recall hearing this sound before my problem w/ the ac whining at the beginning
Old Jul 11, 2001 | 01:18 AM
max808's Avatar
air sound at startup
I have the same sound at startup. It sounds like air being released. It goes away once you start moving. any ideas?
Old Jul 11, 2001 | 01:44 AM
vmok's Avatar
Though it might not be the cause of the hum, belt squeal might mean that the belts are worn and/or the tension/deflection needs to be adjusted. You may also want to check for contamination on the belt from fluids leaking into that area, which would also cause the belt to slip.
-V
Old Jul 11, 2001 | 03:26 AM
party_boy's Avatar
i've had the same sound i think
its like a gurgling...its been there since new for me. dunno *shrug*
Old Jul 11, 2001 | 07:15 AM
humaras's Avatar
whine
It is perhaps good to know that I am not the only one with this whining noise too.
I noticed mine last winter, whenever the belts would get wet (even now after a night when there is a lot of precipitation), when I start the car the next morning, there is a loud whine. It goes away after a few minutes when the moisture has been dried.
I was wondering--is this a "bearing/tension" issue or is this just simply a wet belt issue--which is not much for concern. How many miles do you guys have on your car? mine has about 34K as of last week.
Old Jul 11, 2001 | 09:12 AM
teejnut's Avatar
Re: whine
mine has about 64k miles on it... hmm... does anyone know how to solve this problem?
Old Jul 11, 2001 | 01:22 PM
teejnut's Avatar
bump
markevans999
Sep 10, 2015 04:29 PM
jfl330
Sep 4, 2015 01:44 PM
TheMafia
Sep 4, 2015 08:26 AM
A32goldylocks
Sep 2, 2015 06:39 AM
