Tokico Illumina guys...
Originally Posted by Dooley
2.5 F, 3.5 R. May try 3F, 4R in summer?
BTW..Eibach/Illuminas here..settings are
2F & 2R...thinking of dropping the rear to 1 for comfort. The recommendation is a harder setting on the rear to conter the inherent understeer of the car. My experience is that the rear is lighter, so for rear passenger comfort, a softer setting is good.
Originally Posted by 95bluse
I have to ask...how did you get the decimal settings?
Think 1 and 2 would be good? Isn't 1 wayyyy soft? I've never messed around with it since I don't wanna screw them up by having them either too stiff or too soft for a prolonged period of time if it does indeed cause damage...
I have H&R springs with mine. If I have the rear set to anything less than 4, I bottom out very easily from a bump or a dip in the road. I have 235/45/17 tires and the fender will rub the sidewall of the tires. I rarely have anyone in the back seat, but if I do it bottoms out with only the slightest of road surface irregularities. Anyone else have this issue or is it just me?
Originally Posted by ComradeJew
I rarely ever have any passengers in the back... aside from my gf and I...
Remember all the weight is in front, so I think it's best to keep it at 3.
BTW:I have the rear at 5 occasionally, when I'm in back with your gf... J/K
Originally Posted by Gismo-T
I tried 1 & 2 F, settings are too soft for the front (besides winter at 2)
So 3 on the front huh... I'll give it a shot when I head out to school today; make it 3 and 3...
Before I got my 18" wheels my settings were 2F 3R, sometimes 3F 4R (with S-Techs). I find those settings way too jarring now. Everytime I ran over a little pothole it would feel like I had done some damage to my suspension or bent my rim. I've had to adjust them down to 1F 1R. The handling is obviously not the same anymore but I don't mind, I just don't drive as crazy.
I think matching the Illumina's to the springs is the best. I have them set at 1-2f and 2r with stock SE springs. I had the H&R setup and needed to run them as high as 4F and 5R. It's all about the springs. Experiment for the best fit for your springs.
Thanks for your input.
The roads in the Atlanta area generally suck or I would have stayed with the H&R/Illumina combo. On mountain roads the Max handled 100% better than stock. Potholes shook my cd player and my teeth. The Illumina are as soft as stock on 1F. But about 20% harder than stock struts on 2F. You never loose the comfort, because the SE springs are soft. Great combo for ME! Since you are local we could meet up and you can see first hand!!
Interestingly, my dearly-departed '86 626 turbo had the electronically adjustable suspension. There were 3 settings (I think..it's been awhile)
- Normal
- Sport
- Auto
Normal was the softest, while sport had both front & rear at hard settings. The auto setting would "automatically " set the fronts to hard at h/way speeds, leaving the rear at normal stiffness. The manual said this enabled better directional stability at highway speed. I miss some of the features on that car...
- Normal
- Sport
- Auto
Eibach pro-kit
If I had those springs, I'd start at 3F,3R and adjust stiffer. Those springs are pretty stiff and the ride is stiff. But with the stiff ride you get exceptional handling. Enjoy!
This is what I found out about Eibach Pro-Kit:
Eibach Pro-kit Springs
Description: The Eibach Pro-kit has a 1.5" front 1.3" rear drop and are known to be fairly stiff. Probably one of the top performing springs (next to race coilovers) due to the stiffness and ride height. These springs are known to be stiff and should be paired with Koni Yellows, KYB AGX, or Tokico Illuminas. Spring rates = Front 166~257 / Rear 166~343.
Originally Posted by 90stanza
first link doesnt work
http://maxmods.dyndns.org/index.php?MaximaSprings
MaxLvr21
10-17-2015 12:11 PM
Stagnet04
10-11-2015 08:16 PM
