how do you take off the grill???
Old Jul 11, 2001 | 09:24 AM
fatmike's Avatar
ok well i am stuck i dont understand if you try to get off those impossible screwsbehind the grill or if you just take the whole black attachment off. If you do take the attachment off how? the more details the better....
thank you
Old Jul 11, 2001 | 10:12 AM
Daniel B. Martin's Avatar
Grille removal instructions
thank you
When you post a request for information it is helpful if you specify the model year of your Maxima.
Instructions for removing '97-'99 grille...
Raise the hood. Locate two plastic fasteners in the upper corners of the grille. They look like black square slotted screw heads. Insert a small flat-blade screwdriver into the slot and turn CCW 1/8 turn to release the clip. Gently tug the grille upward and outward. Elapsed time, 30 seconds.
Installation is almost as easy. The two plastic fasteners stayed in the car. Use a small pair of pliers to squeeze the legs together, and remove them. Insert the square heads into the hole in the grille, working from the back of the grille. Turn 1/8 turn to click into place. Place the grille into the vehicle body, taking care to line up the locating pins near the lower edge of the grille. Gently push those two plastic fasteners into their respective mounting holes. Snap! The job is done. Elapsed time, 60 seconds.
REDinLV
Aug 15, 2024 12:30 AM
adamgalazka
Feb 5, 2023 08:24 AM
The Frye
Feb 3, 2019 08:34 AM
05RLS2
Nov 7, 2016 05:52 PM
ricky7780
Sep 24, 2015 06:50 PM
