Help With exhaust noise
Old Apr 19, 2007 | 09:43 AM
olivas's Avatar
I have a Stillen full exhaust and ever since i put the y-pipe in
i get alot of interior noise in the car. i thought about putting a res. on
but i did want to cut the pipe. I was thinking about putting dynamat in the trunk. What do you guy's think?
Old Apr 19, 2007 | 09:58 AM
96blkonblkse's Avatar
what type of y-pipe? Got a sound clip..im interested in what it sounds like.
To answer your question, the stillen muffler is a straight thru design so naturally it will be loud..makes sense though, the y-pipe does increase noise, which is why it has gotten louder, one solution would be to get a new muffler.
Old Apr 19, 2007 | 02:05 PM
olivas's Avatar
i have a sound clip but can't find a place to put it on. It a Stillen y-pipe.
I just want to het the interior nosie level down.
Old Apr 19, 2007 | 02:19 PM
NmexMAX's Avatar
dot dot dot ...
You're going to need to cut into the pipe to make the noise come down, that's the only way. You need a resonator in there.
Old Apr 19, 2007 | 02:30 PM
olivas's Avatar
Do you think dynamatt would work. I've been told if the res. on an exhaust that didn't come with one, and you put one in you'll lose some hp. Plus doens't some of the noise come from the trunk?
Old Apr 19, 2007 | 02:48 PM
hectorc's Avatar
Upper Midwest Wheel Whore
Do the dynamt first, it will probablu reduce the sound, but not enough. Putting a resonator on our cars will not make you loose any significant power. The resonator along with dynamat should reduce sound greatly.
Old Apr 19, 2007 | 03:07 PM
olivas's Avatar
Should i just do the trunk?
Old Apr 19, 2007 | 03:11 PM
hectorc's Avatar
Frankly I also doubt it will help, but it will ease your mind go ahead and do it. It might help reduce cabin noise, but not reduce thwe noise I think you're hearing. I used to have my car weithout a resonator, and it was real loud, bassy, and dronie. When the resonator was put on it reduced the sound greatly to point when I'm cruising I don't really hear it much.
Old Apr 23, 2007 | 08:00 AM
olivas's Avatar
All i want is to reduce the cabin noise. The exterior noise isn't that
bad one of the shops like the was it sounded.
user 11122324
42
Jul 18, 2022 03:35 PM
D Mason
Jun 21, 2016 04:43 AM
Justin Kroll
Oct 1, 2015 07:03 PM
uttadms31
Sep 30, 2015 05:24 AM
