rpm's
Old Apr 23, 2007 | 07:22 PM
95jr6708's Avatar
rpm's
it started earlier today when i apply brake pressure for a light for instance, when i am about to come to a complete stop my rpms drop unusally low (around 300-450) and the car shakes a little bit. It accelerates fine and starts well when its warm...anyone have any ideas?
thanks for your help.
Old Apr 23, 2007 | 07:28 PM
NmexMAX's Avatar
dot dot dot ...
Need background.
CEL's? How's the intake tubing looking, any leaks? How's the IAT sensor?
Old Apr 23, 2007 | 07:37 PM
killerVQ30DE's Avatar
This should surely be a sticky.
1. clean tb
2. clean iacv
3. check engine coolant temp sensor
4. clean pcv
Old Apr 23, 2007 | 10:14 PM
Dan_E_Boi84's Avatar
yeah... definitely sounds like the idle air control valve... part of normal maintanance...
Old Apr 23, 2007 | 10:22 PM
andrei3333's Avatar
1. clean tb
2. clean iacv
4. clean pcv
^^ i second that, but fix #4 from clean to replace, its like a few dollars for a new one
Old Apr 23, 2007 | 10:44 PM
95jr6708's Avatar
Well thanks for the help, but here's some more problems...i have already replaced the pcv valve and tubing, the coolant temp sensor, the iat sensor, and cleaned the throttle body and idle air control valve due to an earlier problem that never got solved. (hard cold starting) which is why this is somewhat puzzling. check engine light i currently have is 0302 (high/low flow egr) which i tried fixing a year ago, but didn't. keep it comming if you can think of anything else.
thanks.
Old Apr 23, 2007 | 11:02 PM
andrei3333's Avatar
wow man thats a car with a lot of problems, get rid of it
Old Apr 23, 2007 | 11:28 PM
what he said^^^^^
just sell it to me for a grand...
otherwise... replace the EGR valve...clean out the ports and you should be good...
The reason why it's stalling is because the EGR valve is sticking open causing the same problem as a vaccum leak...
The CEL is a very helpfull source for diagnoses of a problem... if you fix it you'll be running beautifully...it's probally running real LEAN... bad for the motor...
Old May 3, 2007 | 10:22 PM
gatorsteeler's Avatar
when ses light is on for a max ignition or emission wise...what does the ecu make the car run like? lean, rich on gas what? i idle@ 700rpm with light on..just bought this thing..pissed off 700 is too low aint it?
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
slowlifer
Sep 8, 2015 05:53 AM
