advanced timing
advanced timing
I know this has been over and is stickied but when I looked it said that if I advance my timing that the computer would override it and set it back to normal. Is there anyway I could possibly advance it without the computer overriding it?
If you get the consult to do it, it will go away when you turn off your car. Plus that is only the BASE timing, not open loop timing. You want an SAFC+ bigger injectors or an Emanage Ultimate to have better control of your ecu.
Alright thanks I just looked those up and it doesn't look worth the hassle. I'm just looking to keep it simple with this car with a couple of aftermarket parts like full exhaust, lowering, and maybe a underdrive pulley.
Originally Posted by Whitemax
Or just buy a 5th gen. Then you can take it to the dealship and they'll do it for you
And you wont feel the 2 degree advance because it only works under 2500 rpm
Starrider
Sep 17, 2015 07:26 AM
rbaker100
Aug 31, 2015 11:09 AM
