How do you take entire headlight out?
Does anyone have a link that will tell me how to get my headlight out so i can put my R34's in? don't make fun of me, i suck at this stuff but i'm trying!
or if anyone can just tell me real quick that would also be appreciated! thanks!
www.phatg20.net -> download FSM.
Crucial to us do-it-yourselfers. Its pretty easy-> 1. marker light phillips screw on top and pop out gently w/flat screwdriver between light and head lamp. 2. Couple 10mm bolts hold on behind headlamp on engine side of core support and where marker lamp was. 3. Undo bulb harnesses, should come out.
The grill does have to come out too. Sorry, I have had Cefiros for about 6 months now and its been awhile since I had to take OEM lamps out. Be careful with the grill, that you do not snap any retaining tabs.
The black piece comes out with the headlights as one piece. There should be 2 10mm nuts on the back of each light closest to the grille and another near each corner light (I think).
As stated the grille needs to come out too, but it is actually easier to take everything (both headlights and grille) out as one piece, and then seperate the grille. At least for me it was.
wow, i don't know how exactly i did this but i just finished and managed to change both headlights out without taking the grille off! i didn;t break anything either! lol go figure. thanks for the responses though guys! i'll post pics soon but they look sweeeeeeeeet!
whats the problem with taking the grille off ? there are two clips on each end at top and two matching pins / holes on both sides at the bottom, Thats it !!
too care of a hose leak in the PS fluid cooler so i took mine out today like 3 times
Originally Posted by monkeyinmyhead
Does the headlights are JDM Black style? Because I've just bought me the headlights and the bumperlights and I really don't know if they are that good about the weather. Please tell me that my New set is water proof!?!
doctorpullit
10-28-2019 10:58 PM
trsandrew
04-08-2016 06:45 PM
trsandrew
10-25-2015 02:47 PM
