clutch opinions
4th Gen Parts King
![](https://maxima.org/forums/images/smilies/support.gif)
clutch opinions
I have a parts car that has a good trans and supposedly a newer clutch that i will be using in another car which has a bad trans. The car will be sold after all the work is done.
I'm having second thoughts about using the same clutch though.
I ovously can't tell the buyers it has a newer clutch.THe clutch looks and drove fine though. I know that its important (especially for higher mileage cars) to buyers that the car has a new clutch and will either make or break a deal.
So should i go for this clutch kit
http://cgi.ebay.com/ebaymotors/EXEDY...spagenameZWDVW
Or spend another $100 and buy the 5th gen clutch, pp and throwout bearing?
I would also have to buy an alignment tool if i went with the 5th gen setup.
Or is there another clutch alternative?
That exedy one is a OEM replacement. I don't have any experience with it personally, but a close friend of mine used the same one (exedy stage 0) in his 92 SE-R and it worked great.
4th Gen Parts King
http://cgi.ebay.com/ebaymotors/86-01...spagenameZWDVW
From what iv'e heard is that the stage 1 disk is the same things as the 5th gen disk.
I am looking for the plug for a 95 Maxima fog light. The part where the bulb sits in is missing for some strange reason. Also the clip that holds the button in for the trunk release switch, if you have that in a tan color I would appreciate it. let me know.
Originally Posted by fanaticrockford
Dam i didn't realize that. This would be the correct one i would use.
EDIT: I just realized that isn't an Exedy. Exedy Racing Clutch Stage 1 is the good one to get.
help! i cant start my own thread!
my clutch just recently went out, wondering what a good replacement one would be, i also had this strange power chug at about 2300-3000 rpm, possibly the clutch slipping?
i also believe my engine could use some tuning, shes got 160k, and i havent done much engine work. any suggestions?
ive got a y pipe back exhaust, ecu was upgraded before i installed it, should i have her rechipped?
Thanks.
Thanks.
Thanks.
Thanks.
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
![Blah blah](https://maxima.org/forums/images/smilies/blahblah.gif)
ignition wires? replace the coils? how about my injectors? possibly swap em out for something better?
i had a code come up, but then it went away a week later..ill see if i can get someone with a scan tool.
also, where would i get just the k&n filter? i have the intake. or what should i clean it with?
thanks.
thanks.
![santa2](https://maxima.org/forums/images/smilies/santa2.gif)
![leap frog](https://maxima.org/forums/images/smilies/leapfrog.gif)
k&n filter you can get from any auto store like auto zone or pep boys or jsut get a filter from ebay and k& n cleaning kits come with the filter package i belive
REDinLV
10-18-2015 05:31 AM
carlosvq30
09-26-2015 09:44 AM
dvcamp
09-18-2015 10:17 AM
