CAI question...
Old May 5, 2007 | 12:18 PM
lilaclucymaxima's Avatar
Team Ramrod
CAI question...
I am going to install my PR style CAI, and had a question regarding the intake temperature sensor. In the stock intake it was mounted to the box in which the filter was in. Because I am keeping the stock resonator that is between the TB and MAF, there is no place to mount the ITS, so my question is... where can I mount it? I thought maybe in the intake tubing, but am not sure.
Old May 5, 2007 | 12:47 PM
Tatanko's Avatar
Bacon Lover
You can drill a hole, but remember it will be on a curved piece of metal, so you'll have to find a good way to seal it up.
Old May 5, 2007 | 12:49 PM
x91max
autozone, pepboys, checkers. etc... sells adapters for just the thing
Old May 5, 2007 | 12:52 PM
MaximaSpd85's Avatar
how much, if at all, does that sensor affect performance? cuz mine is just dangling, so im assuming what it does is.....read intake temperatures...and mine is reading engine bay temps??
Old May 5, 2007 | 12:53 PM
x91max
you mean the car runs with the sensor out of the intake tube? mine wouldnt go past 2500 like that
Old May 5, 2007 | 12:56 PM
yeh, its plugged in, but its just chillin there, runs fine
Old May 5, 2007 | 12:58 PM
x91max
you can just bypass it if u dont wanna use it. could have motor temp prblems if you choose to do that tho.
Old May 5, 2007 | 01:02 PM
well, i mean i guess im using it, its just not in the correct place so im wondering if im hindering performance any
NmexMAX's Avatar
dot dot dot ...
Old May 5, 2007 | 01:06 PM
x91max
if you disconnect the temp sensor the motor will draw the same amount of air in. there for wont know the temp of it so it could be sucking in hot air
Old May 5, 2007 | 01:15 PM
NmexMAX's Avatar
dot dot dot ...
It's not used to directly control engine parameters, just as a diagnostic tool.
Old May 5, 2007 | 01:17 PM
x91max
then why when you put different temp air in it does it change the way the car runs.
Old May 5, 2007 | 01:23 PM
NmexMAX's Avatar
dot dot dot ...
MAF sensor is in charge there
Old May 5, 2007 | 02:41 PM
Team Ramrod
Alright, thanks guys... upon doing more research I have solved my problem. I already knew that it does not affect anything other than tripping the CEL, I just didn't want that to happen. I'm going to fabricate a hole somewhere in the intake so that I can securely mount the IATC. /thread
Old May 6, 2007 | 07:33 PM
PHAT6's Avatar
Advance apologies for a possible hijack.
I've been toying with the idea of modifying my radiator mounts to lower it down may be 4 inches (100mm) to accommodate cold air intake piping to sit behind the front grille beside the front left headlight.
Hidden unlike a hood scoop and with better air flow than the PRCAI-style intake in the wheel well.
Anyone done this?
Old May 7, 2007 | 03:25 AM
Team Ramrod
Anyone done this?
Quite a few have done it. Custom fabrication will be needed. Here's a thread I found...
http://forums.maxima.org/showthread....=cai+fog+light
Old May 7, 2007 | 06:44 AM
Neo Raven456's Avatar
Like others have said, I just made a hole and fabricated a mount.
Old May 7, 2007 | 07:54 AM
Team Ramrod
Looks good. Yeah, I'm going to drill a hole in the stock resonator between the TB and the MAF sensor. That way it's a nice flat surface. I'll take pics when I'm done.
Old May 7, 2007 | 08:39 AM
Yeah that'll probably be easier, as you can see mine I did on the rounded tube and it took a bit of sanding to get it flush
Old May 7, 2007 | 02:34 PM
PHAT6's Avatar
It does look lucy but does it go through the wheel well like the PR intakes or have you modified it to sit behind the front grille...?
Old May 7, 2007 | 02:47 PM
10charssss
Old May 7, 2007 | 03:41 PM
Majestic's Avatar
Yahhhhhhh
only problem I see with this is that the actual sensor is not really located inside the tube. I did pretty much the same thing when i installed my PRCAI but once I got rid of the midpipe and put the stock one back on I noticed that it really didn't matter. I also noticed a dramatic increase in overall power and feel just by putting the stock midpipe back on. Anyways....good luck
Old May 7, 2007 | 07:26 PM
XeroX's Avatar
Hella internets
I just shoved it in one of the couplers holding the pipe to the maf, it sits in the proper direction to get air temp, and i didnt have to modify anything...takes like 2 seconds....just put it infront of the pipe, and push the coupler over the wire so it the wire gets sandwitched between the pipe and the coupler...then just tug on the wire a bit so the sensor is snug up against the pipe on the inside...that way its not just hanging in there...
Old May 7, 2007 | 08:33 PM
Actually, the actual sensor is inside the tube:
But thank you for the insightful post, I might throw on the stock midpipe and see how it feels
Old May 7, 2007 | 08:35 PM
That's kind of defeating the purpose. Part of the reason the CAI creates the top-end power it does is due to the long straight tubing and smoothness of the airflow. I'm no expert, but from what I understand that's how it works, aside from the cooler air. Shoving the sensor and having the whole bracket and all sit in the, while still flush against the pipe is a bit obstructive and a bit unprofessional. Just my .02
Old May 7, 2007 | 09:04 PM
Majestic's Avatar
Yahhhhhhh
o i c....i take my last statement back. Good job. Looks just like how I had mine.
Old May 7, 2007 | 09:05 PM
Majestic's Avatar
Yahhhhhhh
I personally don't think it would make that big a difference...only slightly at the most.
Old May 7, 2007 | 09:47 PM
Team Ramrod
It was already answered in post #21, but it goes through the wheel well like the PR intakes.
Old May 8, 2007 | 11:16 AM
XeroX's Avatar
Hella internets
honestly its not much different than the designe that the starter of the thread created...the sensor just sits up in the pipe about a 1/4 of an inch more...i really doubt thats going to effect performance that much....If your going to be worried about the power your going to loose with doing it the way i did it...ur better off keeping your stock intake on anyways...
Old May 8, 2007 | 11:19 AM
XeroX's Avatar
Hella internets
Personally i would have dont this on a section of the pipe before the maf...this way if there was a small air leak, it wouldnt be that big of a deal...but just make sure you seal it up reallly good..
Old May 8, 2007 | 01:49 PM
You mean place the sensor in the Long pipe that drops into the fender? That picture is with the sensor mounted into the mid-pipe, I just happened to have it all connected when I took the pic so you can see the MAF
Old May 8, 2007 | 02:08 PM
XeroX's Avatar
Hella internets
yes, basically in any section before the MAF, The stock placement of the sensor is before the MAF anyways...probly for the same reason i mentioned before (easy location for an air leak) either that or in case the sensor were to fall apart or something the screen on the maf would prevent it from going into the motor....but that is HIGHLY unlikely....probly does not matter, im just throwing in ideas incase anyone wants to do the same thing...There is always room for improvement on things like this hehe, and i would do this to my PR CAI if i ever wanted to spend that much time on my intake, props for the install, im just too lazy to spend that much time on something like this
I pretty much just got my CAI for the sound honestly...
Old May 8, 2007 | 03:28 PM
Thanks, and we also have to remember what this sensor does. We're just talking about a temperature sensor lol
Old May 12, 2007 | 12:07 PM
Team Ramrod
Not to bring this thing back from the dead, just posting the pictures I promised... along with a writeup, in case anybody else wants to do this in the future.
First, take the stock resonator out. Next step is to use the bronze bracket that the sensor screws into as a template and mark the holes. The larger hole in the center, which is where the sensor goes through is 7/16", and the two holes for the bolts are 1/4"... these are the measurements so it sits flushed with the flat surface. Next step is to drill the holes. Most important part... clean up ALL OF THE PLASTIC SHAVINGS you may leave behind, as I'm sure nobody wants that going into your engine. And re-install. That's pretty much it, not very hard. Here are the pics...
Made the template using the bronze bracket.
Drilled the holes.
This is a picture of the inside of it when finished.
Ready to put back in the car.
The finished product and a peak of my dirty a$$ engine bay.
Maxima_Joe
Nov 25, 2015 08:19 AM
Sep 27, 2015 08:37 AM
A32goldylocks
Sep 16, 2015 01:33 PM
lowpost99
22
Sep 2, 2015 04:38 PM
BGTONIO1991
Aug 11, 2015 07:38 AM
