Headers, do i need a new clutch???
Old May 20, 2007 | 03:27 PM
Keatz's Avatar
Hey guys, i was thinking about getting headers but i was wondering if i will need a performance clutch to handle the extra hp????? or will stock clutch be fine?
I got a y-pipe, high flow cat, and custom exhaust.
Old May 20, 2007 | 04:53 PM
Fr33way™'s Avatar
Wild for Width
Your clutch is probably fine. You are anywhere between 170-180whp.
Old May 20, 2007 | 05:11 PM
MDeezy's Avatar
stock clutch will be able to handle any headers put on your car. You'd be suprised at the gains you'll get from headers... not as impressive as desired
Old May 20, 2007 | 06:21 PM
Keatz's Avatar
thanks guys, thats all i needed to here, im gonna go ahead and order some.
Does anyone know if the ebay stuff is any good???? or shud i stick with name brand OBX
Old May 20, 2007 | 09:34 PM
moogotzskillz2's Avatar
Your stock clutch will handle but..
If you have HIgh miles and plan on keeping ur car for a while i'd Replace the clutch wit a (5thgen clutch or any excedy stage1) adn while 'm down there replace the headers (alot easier).
Old May 21, 2007 | 06:30 AM
stephenlc's Avatar
stock clutch should be fine.
Old May 21, 2007 | 07:20 AM
Flava_24/7's Avatar
Boosted Panda
If you already have the Y pipe then you wont even notice much of a gain if any with the headers.
Why would you think the power would be so great as to kill your clutch? It doesnt add 100+hp.
Old May 21, 2007 | 07:27 AM
nexgenmax's Avatar
R34
If you read some more, you might save some bucks and do some other mods rather than headers. imo.
Old May 21, 2007 | 08:11 AM
going from ypipe to headers will yield 6-8hp more at best, IIRC.
Old May 21, 2007 | 08:29 AM
Keatz's Avatar
Do you have any suggestions????? because i want to get some more power out of my max.
anyone have any suggestions on other mods that would give me some decent power gains??????
Old May 21, 2007 | 08:37 AM
EteRnity059's Avatar
Boosted?....
MEVI and you stock clutch will be fine. If you really want to, I am running and Exedy Stage 1 clutch with my v2 supercharger and it's holding fine.
Old May 21, 2007 | 01:58 PM
KRRZ350's Avatar
mevi or oovi, and an aluminum flywheel, all would yeild much much more than headers.
Old May 21, 2007 | 02:24 PM
Flava_24/7's Avatar
Boosted Panda
Flywheel wont do much for power. It will free up some power but nothing real noticable.RPMS will climb faster though, as well as drop faster too.
MEVI really needs the ECU with raised limiter to see its true gain, 00vi would be the better setup for no ECU upgrade.
Old May 21, 2007 | 02:33 PM
Keatz's Avatar
thanks for the suggestions, i think im going to look into 00vi setup but it is pretty expensive so lets see wut happens.....any other suggestions?
Old May 21, 2007 | 03:06 PM
KRRZ350's Avatar
I'm really going to have to disagree with the flywheel not doing much for power, with a lighter flywheel playing around in 1st gear your car will be a neck snapping beast. Makes me wish I could get alumunim axle's and even lighter rims.
Old May 21, 2007 | 03:07 PM
bigpulve+'s Avatar
Weight reduction.
Old May 21, 2007 | 06:53 PM
Flava_24/7's Avatar
Boosted Panda
BS, I have a 5lb Stillen flywheel and when I put it in it didnt yeild a "neck snapping beast" and its lighter then a Fidanza flywheel. The rpms do climb a lot quicker but that doesnt mean its building that much more power. Its just accelerating a bit quicker just as weight reduction would cause you to accelerate quicker.
I had it paired with a UR UDP, and by your theory it should have been making even more power?
I think the Y pipe would give better power gains the the light weight flywheel.
user 11122324
42
Jul 18, 2022 03:35 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
Socalstillen
Sep 26, 2015 12:01 PM
carlosvq30
Sep 26, 2015 09:44 AM
