air box sensor...?
Old May 22, 2007 | 08:39 PM
lil_Jay22's Avatar
air box sensor...?
I have a 96 gxe.
I bought an intake wit a K&N cone filter an when I was going to install it I noticed the top half of the stock air box has a sensor that plugs into a connector next to the MAF sensor. I know the new filter will go after the MAF but what about that sensor that is on the air box? will that triger the CEL if its left unplugged?
Old May 22, 2007 | 08:52 PM
XJinCT's Avatar
<3's the all motor section
thats the ambient air temp sensor...just take it out of the airbox and lay it off to the sider plugged in and zip tie it to something. i think i used a a/c line for my girlfriends car.
Old May 22, 2007 | 08:55 PM
lil_Jay22's Avatar
thanks,
zip ties always come in handy
Old May 22, 2007 | 10:46 PM
slinky87's Avatar
no way man thats your intake air temp sensor which is very imoportant to have in the airstream at all times if your getting a intake you can tap a small hole and stick the IAT in and secure it whatever way possible heres a pic of my setup the pic is from under the intake
Old May 22, 2007 | 11:16 PM
MrDicks95SE's Avatar
Offset Is Everything.
youre taking air in from the engine bay area so it doesnt really matter with a cone filter.
Old May 22, 2007 | 11:34 PM
slinky87's Avatar
Yeaa But The Sensor Dosent Work Unless Air Is Flowing Over It Or Else It Gives False Readings About The Air Temps Thats How A Intake Air Temp Sensor Works
Old May 23, 2007 | 12:15 AM
maxgtr2000's Avatar
KH3 by popular demand
Air doesn't have to flow over it because that sensor is the same as the temp. sensor for nissan auto dimming mirrors that display outside temperature. I know because I have one and the sensors are the same but not interchangeable because the mirror one actually is on a plug, but basically the same style sensor. Mine has been hanging out for years and I have not noticed a difference, but for peace of mind just drill a hole and install it. You guys are making me paranoid about it now....
Old May 23, 2007 | 01:14 AM
slinky87's Avatar
right but think about it why would engineers put this sensor int the air stream if it didnt have to be there in the first place theres a reason why ALL intake air temp sensors no matter what brand of car have them IN the air path and not hanging out in the engine bay like a ambient temp sensor they work off of way diffrent principals even though they look similar
Old May 23, 2007 | 03:41 AM
Wassup2114's Avatar
It's just there for diagnostics and data logging, it doesn't have any effect on the car's performance.
Old May 23, 2007 | 06:19 AM
NmexMAX's Avatar
dot dot dot ...
Taken from the FSM.
Old May 23, 2007 | 10:21 AM
slinky87's Avatar
okay correct me then if im wrong but why would you need a IAT sensor forf diagnostic reasons? that makes absolutley no sense in the years ive been working on cars i have never ever seen a IAT sensor not have a function for the ECU and just for "diagnostic" purposes can you please explain that to me
Old May 23, 2007 | 07:08 PM
NmexMAX's Avatar
dot dot dot ...
Not sure what to make of this, but this is where this interpretation is coming from.
Originally Posted by 1995 Factory Service Manual
The intake air temperature sensor is built into the air cleaner, detects intake air temperature and transmits a signal to the ECM.
The temperature sensing unit employs a thermistor which is sensitive to the change in temperature.
Electrical resistance of the thermistor decrease in response to the temperature rise. This sensor is not directly used to control
the engine system. It is used only for the on-board diagnosis.
Old May 23, 2007 | 07:18 PM
99BlackMaxMS's Avatar
Why would they remove it on 97-99s then? It is not that important...
Old May 23, 2007 | 07:23 PM
NmexMAX's Avatar
dot dot dot ...
They didn't remove it, just relocated it.
Old May 23, 2007 | 07:41 PM
CaptainFill's Avatar
From what i know it is only for diagnostics....
If it makes you happy... zip tie it to the cone, or something. I dunno haha.
Old May 23, 2007 | 07:43 PM
NmexMAX's Avatar
dot dot dot ...
x3
Old May 23, 2007 | 07:53 PM
Originally Posted by NmexMAX
x3
sorry... I read the problem, and answered to the best of my ability. My post... does however further back up the other 3.... who are right
Old May 23, 2007 | 07:54 PM
hollywood27409's Avatar
HEEEELLLLPPPPPPPPP!!!!!!!My engine light is on. I am getting 03 02 code. I have been told this is an egr valve issue. Since the light has come on, my car has cut off while I have been driving 3 times in the last 3 days. I let it sit and I will crank it up and it runs to cut off the next day. Can the issue be pinpointed? I have seen a number of posts on this EGR issue, but have never read where the car was cutting off. Can someone please help? 8 days untill inspection!
Old May 23, 2007 | 08:06 PM
NmexMAX's Avatar
dot dot dot ...
Nice post, no flaming,
I vote of the day.
Old May 23, 2007 | 09:04 PM
XJinCT's Avatar
no...its ambient...as in ....unmetered air by the mass air meter.
XJinCT's Avatar
its intergrated into the 97+ MAF'S
Old May 26, 2007 | 08:01 AM
NevadaJack_9's Avatar
Yeh I wouldnt even bother with the cone filter. Did u buy it off eBay? I did the same thing, I just tied the sensor off to the brake line and my CEL went on. Big waste of money, just go the distance with the CAI.
Old May 26, 2007 | 09:37 AM
PhatboyNYC's Avatar
If you remove the air intake temp sensor, it'll trigger your CEL. I know because when the CEL on my car (98 SE) came on, I checked the code and it was 110 for air intake temp sensor. Once I replaced it, the light went off.
Old May 26, 2007 | 12:41 PM
NmexMAX's Avatar
dot dot dot ...
That's all it will do, set off the CEL. It wont affect performance.
Old May 26, 2007 | 12:48 PM
RA030726's Avatar
I'm nutty for Nissans
yet another piece of false info in this thread.
Note to idiots, if you dont know WTF you are talking about dont say a god damn thing.
Old May 26, 2007 | 01:01 PM
NmexMAX's Avatar
dot dot dot ...
If you're referring to 02+ MAFS, then yes, you're correct. But you're not referring to those cars, so, no I with JSutter.
Old May 29, 2007 | 05:42 PM
Benzmcs's Avatar
so whats the verdict on this if it does set off the cel then how could a person avoid this if at all with an aftermarket k&n filter hooked up to the maf would it be possible to install the sensor into the stock midpipe somewhere? also if the sensor is just sitting in the engine bay zipped tied to something will the cel come on our is it just if you unplug the connector on the sensor? thanks for the help appreciate it
Old May 29, 2007 | 06:20 PM
NmexMAX's Avatar
dot dot dot ...
I zip tied it like the other millions of members on here that have done this before.
No CEL.
Old May 29, 2007 | 07:04 PM
KRRZ350's Avatar
Just wanted to elaborate what little I know on to the 'only used for diagnosis' thing..... Readiness checks won't pass for o2's, o2 heaters, & cat's if you have an iat code.
Old May 30, 2007 | 06:35 AM
NmexMAX's Avatar
dot dot dot ...
Good point & food for though for people that get inspected.
Old May 30, 2007 | 09:47 AM
RA030726's Avatar
Stillens filter has a spot to intall the sensor. There are 2 different part numbers since the 95/96 and 97-99 are different sensors. If you buy a cheap filter at the store it would take 5 minutes with a drill to install the sensor in the end.
Old May 30, 2007 | 10:21 AM
mge2790's Avatar
this is the wrong thread to post that, if you dont have enough posts to start a new thread post it on the newbie forum, you generally get good help from there
Old May 30, 2007 | 10:26 AM
mge2790's Avatar
if you have a stillen intake, and it will give you peace of mind then go ahead and drill the hole and install the air temp sensor there, other wise just make sure it is plugged in and not rubbing against anything and you will be fine.
Old May 30, 2007 | 12:47 PM
Benzmcs's Avatar
thanks for the help guys appreciate it
Old May 30, 2007 | 01:03 PM
lilaclucymaxima's Avatar
Team Ramrod
http://forums.maxima.org/showthread....&highlight=cai
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
MichMaxFan
Sep 30, 2015 09:18 AM
Sep 27, 2015 08:37 AM
