EVAP problems fixed for free??
Old May 24, 2007 | 10:15 AM
psu2fan's Avatar
So I have the 0111/p1447 code and no others. I've been searching through the old threads on this code and the advice is to basically replace everything. That's a lil expensive. Well I googled evap canister maxima and this was the first link:
http://lyberty.com/car/Maxima_A32_do...NTB98-073a.pdf
Can anyone confirm if this is legitimate? Also is there a 'statute of limitations' on this? I'm a '96 owner and this seems too good/lucky to be true.
Any thoughts..?
Old May 24, 2007 | 10:58 AM
VIP Maxima
is urs leaking? cuz i have had this code for leaking canister for 2 months now. its expensive to fix
Old May 24, 2007 | 11:18 AM
psu2fan's Avatar
I haven't actually checked yet. I'm waiting for the heat to break and I'm going to investigate this evening. But if this document is still valid I think it'd be worth taking to the dealer. It doesn't list any real limitations but it was issued in Feb '99 so I don't know if the dealer would take an 11 year old car with 180k on it and do the service for free
Old May 24, 2007 | 11:20 AM
95turbo gxe's Avatar
what does the EVAP do?
Old May 24, 2007 | 11:32 AM
psu2fan's Avatar
The emission control system that prevents the escape of fuel vapors from a vehicle's fuel system. Fuel vapors are routed by hoses to a charcoal canister for storage. Later, when the engine is running a purge control valve opens allowing intake vacuum to siphon the fuel vapors into the engine.
Old May 24, 2007 | 11:37 AM
ok yeah I see. Hey can we take that **** off its in my way!
Old May 24, 2007 | 12:02 PM
psu2fan's Avatar
Well that's a dead end:
A limitation pertains to the age of the vehicle. In order to be eligible for remedy at no cost, the vehicle cannot be more than 8 years old on the date the defect or non-compliance is determined. Under the law, the age of the vehicle is calculated from the date of sale to the first purchaser.
And that's for a recall, this was only a tsb. Back to square one. New question, since code 0111 (p1447) is a jackpot code is there like a ranking of what's most likely wrong. I read in an older thread something like 10-15 possible reasons this code is tripped.
What is most likely wrong -> least likely?
Old May 24, 2007 | 12:11 PM
Mxrider52's Avatar
I support for what?
I recieved this code and I still have it after couple thousand miles. When it first showed up I cleared the code and then it came back and I kept driving on it for a couple hundred miles and eventually it threw another code which gave me a sensor code for the evap. I replaced the sensor but yet the 0111 code is still there. Id wait and see if a new code showed up. I am thinking it may be the canister that bad. I havent taken it off yet but it is suppose to weigh in at a certain weight.
Do you by chance have a strut bar installed? If so it may have hit the black round thing I forgot what it called and broke it. It sits right on top of the intake manifold.
Old May 24, 2007 | 12:20 PM
psu2fan's Avatar
Yeah I do have a fstb, I bent the metal brace so there's no pressure on it; but the code popped up a couple weeks before I installed the fstb so that's not it. I'm installing (cross fingers) the passenger cv shaft this evening so I'll have to take a look at the canister then. I was hoping I'd get another/specific code but it's been a couple months now and June is inspection time for me
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
dcam0326
Sep 7, 2015 07:26 AM
minsbang
Sep 5, 2015 05:36 AM
coasterswim
Sep 2, 2015 07:43 AM
