MAF-Does car run if it breaks ?
Old May 27, 2007 | 06:17 PM
vtkahns's Avatar
If I break the MAF, does the car still run or am I stranded ? Sure it will throw a code at me.. but will I be calling the wife to come rescue me (never a good thing) ?
Old May 27, 2007 | 06:20 PM
ethnic6's Avatar
it'll pretty much be in the Sh!tter if its broke, get it replaced...
Old May 27, 2007 | 06:25 PM
vtkahns's Avatar
I removed the 4 screws in the side of it to "remove " the sensor...tugged on it a bit.. and out came the connector with 3 unsoldered leads that I presume I broke the connections to inside.. I did not look inside much to see how I might repair it.. put it back in place.. put the screws back in.. and so far, idling in the driveway, no check engine light.
Does that mean they are making contact right now inside ? Does it need to be driven to prove its failing ? Anyone ever look inside these things to see if there is room to solder it back together ? Figure I might have to add some wire to each contact so I can solder it while I can see it.. and then tuck it into place... Getting a new one is not a good option.. I see some for sale here.. just worried about getting a 10 year old part.. could be doing it again soon.
feeling dumb
Old May 27, 2007 | 06:29 PM
Maxima9499's Avatar
Nope, no worky worky, no runny runny
Old May 27, 2007 | 06:32 PM
the_3d_man's Avatar
first off... didn't you already make a post about this?
second... if you broke the MAF it would run, but really crappy (like not reving above 2000 rpm or something like that)
third... (again) if you in fact did break the solder ... just resolder it and it will be fine
Old May 27, 2007 | 06:57 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
The car will run but it wont rev past 2000, or 2500. Ive moved my car around before without a maf.
Old May 27, 2007 | 07:51 PM
MorpheusZero's Avatar
It'll run but you'll hit fuel cut at 2400rpm and it won't run particularly well. I've started mine up without a MAF (straight TB) but haven't actually put it in gear.
Old May 27, 2007 | 08:10 PM
Tatanko's Avatar
Bacon Lover
Mine also just barely idled on it's own with a dead MAF (while it was connected, disconnected it idled more or less ok).
Old May 27, 2007 | 11:16 PM
gunny11218's Avatar
feeling dumb
the same exact thing happened to me hahaha oh my god. thats funny.
Old May 28, 2007 | 04:29 AM
vtkahns's Avatar
You (The-3rd_man) are correct.. i had started a post on the a/c condensor that has sprung a leak and then found my check engine light on.. and was thinking no one would look at that post if I didn't make one specifically on the MAF itself..which is my bigger problem now.
I am having trouble getting it out of the downstream side of it..where it appears in a rubber surrounding gasket.. I am thinking I might rip that rubber if I keep tugging..Is that an easy , cheap part to find if I should do so ? I can't really see what damage I have done to the MAF itself until I get it out of there.
I hope I can solder it easily and button it back up ...
S
Old May 28, 2007 | 04:33 AM
jordandalley's Avatar
yep.. if u dont fix it, or get another one, you aint goin nowhere.... very fast..
Old May 28, 2007 | 06:07 AM
triggz's Avatar
Does the car use the MAF signal while its still cold? My '95 starts to act crazy and stall out after it warms up- and it wont rev very high while trying to accelerate. The car will often refuse to crank back up at all while hot.
Old May 28, 2007 | 06:21 AM
domlcardio's Avatar
guys...yesterday i was cleaning the throttle body....i disconnected some sensors, including the maf sensor, and when i connected everything back again, my car started putting....the exhause smells like rotten eggs...it wont go past a certain rpm...my check engine soon light came on...is it my maf sensor?
Old May 28, 2007 | 07:14 AM
triggz's Avatar
Did it have any codes? Mine spat out these:
11 03 / Improper Shifting to First Gear (A/T)
01 02 / Mass Air Flow Sensor
03 04 / Knock Sensor
And it wont rev past 2.5-3k range or shift out half the time.. I also noticed if I bang the MAF, the rpms will change- suggesting bad connections.
Old May 28, 2007 | 07:24 AM
domlcardio's Avatar
actually i have to check that now...i was stupid not to give that information...i ll be back
Old May 28, 2007 | 08:32 AM
domlcardio's Avatar
ok my codes were 03 04 07 01 01 02
which i think are misfire, knock sensor, and maf sensor.
so what do you think
Old May 28, 2007 | 08:36 AM
domlcardio's Avatar
also i look at the maf sensor and it seems that everything in there is intact
Old May 28, 2007 | 09:24 AM
domlcardio's Avatar
if anybody has any suggestions.....i need my car to go to work tomorrow....
Old May 28, 2007 | 09:32 AM
domlcardio's Avatar
anybody?...
Old May 28, 2007 | 12:44 PM
domlcardio's Avatar
bump........
Old May 28, 2007 | 03:18 PM
domlcardio's Avatar
anybody guys....
Old May 28, 2007 | 06:11 PM
the_3d_man's Avatar
Bad MAF could probably cause all those codes. Don't worry about the KS until you address the other two.
Old May 28, 2007 | 06:22 PM
NmexMAX's Avatar
dot dot dot ...
I've driven 30+ miles home with my MAF unplugged. Keep it @ about 60MPH and you'll be fine.
Old May 29, 2007 | 04:54 AM
domlcardio's Avatar
wel l i reset the ecu...and i only get the knock sensor code 0304. what happened was that i disconnected the maf thinking that had something to do with it and thats y the ecu said 0102 and 0701. so what do you think...knock sensor?
Old May 29, 2007 | 06:14 AM
NmexMAX's Avatar
dot dot dot ...
Seems logical doesn't it? Replace the KS and be done w/it.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Ray229Harris
Sep 16, 2015 08:16 PM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
