TIRES !....and a lil lowering question
Old Jul 14, 2001 | 05:06 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Whats up everyone. I just purchased Konig Wheels (17x7) and was wondering the exact fit for them. Would it be
225/45/17 ?
OR
225/40/17 ?
BTW, The wheels are Konig Caffeines, if this helps any.
And about the lowering...if I got the coil-overs, would that be ALL I needed ? Or would I be better off buying the shocks, springs, ect. seperately ? Thanks
Old Jul 14, 2001 | 05:49 PM
Weasel's Avatar
40 profile is too small, go with 45 or 50 (225/50/17 is the stock size on the 5th gen SE 17s).
Old Jul 14, 2001 | 08:10 PM
Toolrocks's Avatar
I went w/ Falken GRB's at 225/45ZR17 - I was told that this was the correct plus 2 sizing. After reading the other post and noting how hard my car hits bumps now, I would probably recommend the 225/50's also. Good luck! Either way, you wont believe the difference, everything is better than stock.
Old Jul 14, 2001 | 09:06 PM
Craig Mack's Avatar
Hey, are your wheels 17x7 ? Your car hits bumps hard and you recommend your tires ?
Ya, I'm looking forward to the new styling and handling im going to get, but don't know jack-**** about tires and am hesitant which ones will fit/perform the best !
Old Jul 14, 2001 | 10:53 PM
1/3There2/3ToGo's Avatar
For the best performance go with 225/40/17 tires. Using these tires will make your speedomiter a little off. You will be going faster than what the speedomiter will read. If you have coilovers you will also need to get new shocks. The stock ones will work for about 3,000 miles.
K
Old Jul 19, 2001 | 06:16 PM
Toolrocks's Avatar
Yeah, my wheels are 17X7 and I do recommend the tires. I love my Falkens, the only thing I ment to point out was that getting a tire w/ a taller profile may lessen some of the bumps. I've had the Tokico/Intrax set up for about 3Kmiles and don't have any probs. If you're sole purpose is handling go w/ the lower profile. If you want a big improvement over stock and a little cushier ride go w/ the slightly taller profile. All I'm sayin' is the smaller the profile the harder your car hits Hope this helps.
Old Jul 20, 2001 | 03:29 AM
bobl's Avatar
Originals were 215/55R16's. My new rims are 18x7 and tires are 225/40ZR18. Handling is much better, you can feel the bumps but it rides pretty nice.
Old Jul 20, 2001 | 08:46 AM
Maxima48177's Avatar
I'm assuming you have a 4th gen. The correct size tire for 17x7 rims is 215/50/17 if you want to maintain correct speedometer readings. You can also use 235/45/17 to maintain correct readings, but this size is usually for 17x7.5 rims because it's wider. The correct size tire for the 5th gen is 225/50/17.
Old Jul 20, 2001 | 03:03 PM
Sonic's Avatar
225/50-17 is a rare tire size however.
Old Oct 29, 2001 | 08:58 PM
voltman's Avatar
As is 215/50/17
Old Oct 29, 2001 | 09:30 PM
RedMax95's Avatar
im using 235/45/17 on mine, wide enough, not too much sidewall, but enough to prevent rims from bending, about perfect if i say so, nt-555
Old Oct 29, 2001 | 11:27 PM
Thread revival at its best...3 months and 9 days after the previous post this thread comes to life again
Old Oct 30, 2001 | 08:38 AM
voltman's Avatar
At least no one can say I didn't use search.
Old Oct 30, 2001 | 09:57 AM
Good point
Old Oct 30, 2001 | 01:01 PM
Craig Mack's Avatar
What the!! Damn I was SUCH a newbie back then Please don't reply to this thread, it is imbarrasing
Old Oct 30, 2001 | 03:59 PM
nixima's Avatar
You must also be embarrassed that your signature actually says you have 17x8 wheels when your message says that you have 17x7 wheels.
Old Oct 30, 2001 | 04:08 PM
Old Oct 30, 2001 | 04:33 PM
Craig Mack's Avatar
Hey foo's, I purchased 17x7 in the WRONG lug pattern, therefore bought 17x8's in the RIGHT lug pattern.
Old Oct 30, 2001 | 05:06 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
homeyclaus
Sep 3, 2015 06:15 PM
carlosvq30
Aug 17, 2015 11:32 AM
twotonezed
Aug 16, 2015 11:41 AM
