Going to remove TB and IACV for cleaning, need to clarify some things
Old Jun 4, 2007 | 09:32 PM
andrei3333's Avatar
I know i need to replace the TB and IACV gaskets when i reinstall them, does anyone have part numbers ?
or should i just waltz in the dealership and ask for TB and IACV gaskets for my 97 ?
im only supposed to use TB cleaner on the TB and only Carb cleaner on the IACV is this correct ?
and i should not scrub the TB with anything but an old T-shirt cause i dont wanna scratch it up right ?
i will take pics as i do this hopefully with my dad this weekend if the KS (going to get that sucker done while the intake it out) comes on time going to order it today hopefully if i have time
Old Jun 5, 2007 | 12:58 AM
Batxel's Avatar
blah
Get tb cleaner, shop towels, and gasket paper at your local auto store cut it to size and call it day. They call it a stealership for a reason, stay away at all costs.
Old Jun 5, 2007 | 09:39 AM
andrei3333's Avatar
anyone else ? i need to buy this stuff today guys
Old Jun 5, 2007 | 09:50 AM
pmohr's Avatar
No more Maximas...
If you're gonna do the KS, you've gotta remove both upper and lower IM, which means the fuel rail as well, just to let you know.
TB cleaner for the TB, and really whatever for the IACV. If your old gaskets are okay, I'd just reuse them. Actually that is what I did when I painted my UIM/IACV, the metal gasket on the IACV was perfect and the paper TB gasket looked fine as well. No vacuum leaks or issues, and I've removed both the IACV and TB multiple times since then with no issues with leaks.
You can use a soft bristle brush on the TB, but scratching it won't be that big of a deal, just don't try to scratch it up to hell.
Old Jun 5, 2007 | 09:55 AM
MaximaSpd85's Avatar
If you're gonna need to buy it today you will probably have to go with the dealership parts unless you follow Batxel's advice. The one on the IACV may be reusable like pmohr said and try not to rip the one on the TB. thats my only advice...
Oh, and you dont have to take off the Upper and lower IM to do the ks.
Old Jun 5, 2007 | 09:56 AM
andrei3333's Avatar
no im actually planning to do what everyone else has done, stick my hand up the devil's hole to replace the KS
so the IAC valve has a metal gasket, and the TB is paper, i might then reuse the IAC gasket, but stil lwant the TB one replaced, any part numbers or the dealer should know if i ask for it ?
Old Jun 5, 2007 | 10:05 AM
pmohr's Avatar
No more Maximas...
True, but to do it properly you do. When he said 'with the intake off', I assumed UIM, not the intake plumbing.
Old Jun 5, 2007 | 11:53 AM
NmexMAX's Avatar
dot dot dot ...
With respect to the actual function of the knock sensor, replacing it in the proper manner is crucial in order ofr it to perform optimally.
This requires the removal of the UIM & LIM. The reason for this is so that you can use a torque wrench in order to properly torque it down to the engine block.
Having all this room also enables you to clean the surface to where it is going to make contact with the block.
If all these steps are taken, the sensor will be able to do its job much better. And given the metrics as to how the KS works, proper torquing should be considered of utmost importance.
I stopped, thought about it, and then went ahead and assumed he meant tubes/piping and other misc. items. Reason being, 98.97% of the members on here do not do it properly. I used to be one
Old Jun 5, 2007 | 12:33 PM
andrei3333's Avatar
well yeah thats what nissan recommends, but i dont feel like taking all that stuff apart. just gona hand tighten with slight force, if i can even get my hand in there, that little hole looks intimidating, but it should be easier with the intake, tb, hoses, and some connectors off.
any tips on all this iacv, tb cleaning and KS removal ? i have gathered info but anything else will help.
Old Jun 5, 2007 | 01:00 PM
heynow's Avatar
when my shop was doing the work, they removed both the UIM and LIM. They also fixed a valve cover leak and the knock sensor while they were @ it.
Old Jun 5, 2007 | 01:02 PM
heynow's Avatar
...oh and i got all the gaskets from courtecy nissan (but i know you don't wanna wait for the delivery) I'd rather spend some $$$ and make sure that i won't get any vacumm leaks after this cleaning.
Old Jun 5, 2007 | 01:28 PM
andrei3333's Avatar
ordered the gaskets for the TB and IACV just now from ALTA nissan richmond hill (local) got a can of carb cleaner and TB cleaner which was on sale, and placed an order for a KS earlier today
gaskets will arrive tomorrow, KS on Thursday, me and my dad will do this on Saturday...cant wait
PS: The parts manager was cool - i mentioned i am a member of the Toronto Maxima Enthusiasts Club (TMEC) and he gave me a discount on the gaskets, which were not expensive anyways, but still the more i save the more gas i can guy and drive more
Old Jun 5, 2007 | 01:35 PM
heynow's Avatar
awesome
Old Jun 6, 2007 | 08:52 PM
andrei3333's Avatar
Guess what i got today
the KS shipped a day earlier then i paid for, not bad, looks OEM made in Japan with nissan logo carved on it. carb and TB cleaner was both on sale, and i got a discount on the gaskets since i am a TMEC member, very very not bad, been trying to get the KS for a while now...
Old Jun 6, 2007 | 09:16 PM
heynow's Avatar
yay!!!
The Frye
Sep 2, 2021 11:03 AM
follyburr
Detailing
Jun 13, 2016 02:06 PM
6spd4dsc
Mar 4, 2016 05:19 PM
nbstriker10
Sep 4, 2015 04:26 PM
