rear wheel bearings
Old Jun 6, 2007 | 04:48 PM
ofgortens's Avatar
rear wheel bearings
So my passenger side rear wheel bearing is going bad and making some noise... I am going to replace it. When I have asked around, everyone has told me that you cannot buy the bearing itself but you have to buy the entire hub assembly.
I am wondering if you are able to buy the bearing separately and press it in (first pressing out the bad bearing).
If so, where would I be able to purchase just the bearing? Everywhere I look, you have to buy the entire hub assembly.
Thanks!
Old Jun 6, 2007 | 06:15 PM
pmohr's Avatar
No more Maximas...
AFAIK they aren't serviceable at all, you have to buy a new rear hub assy.
Old Jun 6, 2007 | 06:22 PM
raziq_afg's Avatar
i have the same problem, both of my rear bearings r shot. i couldnt get the bearing i had to buy the whole hub assembly. i just installed one in, i have to put the other one in. if you wanted any help which i doubt you would just ask. but just becareful with your ABS sensor if you have ABS cause i F***ed mine up. both of my hubs cost me 295.00$ which i bought from stealership cause noone else carried it.
Old Jun 6, 2007 | 06:35 PM
XJinCT's Avatar
<3's the all motor section
you can get them from autopart international or foreign autopart
EDIT: the hubs i mean.
Old Jun 7, 2007 | 11:25 AM
crsdsabers's Avatar
I bought mine from Advance Auto parts for around $90/each. They've worked great for 50K miles. Also, it's a lot easier to just swap out the hubs and the abs sensors (if equipped).
Hope this helps.
98 GLE
213K Miles and Still Going Strong
seesole
Aug 26, 2015 11:22 AM
twotonezed
Aug 16, 2015 11:41 AM
Flores94
Aug 11, 2015 12:53 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
