Ok. Seriously. Getting the light off the plastic on the 95/96 ClearTAILS!!!!!HELP
Im SO damn sick of this!!!
I just sat out side for a good 10 minutes with a heatgun trying to open up the all clear tail lights so that i can paint the damn things. I CANT get it open. I tried the hotest setting and it started to melt the plastic and then the lower setting just makes it hot but i still can't pry the lens apart so i cant paint!! What the hell is up with this.
er?
It's really hard man, it'll take you a good 25 minutes to do it, and when you do it, you have to be CAREFUL!
Go around the edges a good 20-25 times with the heat gun, and every couple of times, pry it apart, maybe 1mm worth of distance .. keep repeating, and eventually you'll have it lifted apart 1/4" .. after that, it ain't too hard..
i was in the same position 2 weeks ago and found out a great and easy way to take them off in 5 mins.... put the taillight in the oven....yes the oven.... at 250 degrees for 2.5 mins. Then take it out and take a screwdriver to take the tabs off the four corners..... get your fingers int the side and gently pull..... once one corner starts to come undone.... go to the opposite corner... be real careful or they will crack. Then it will be loose enough to pull off.... you will have the is black goop everywhere. then all you have to do to put them back together once they are painted is put back in the oven and the glue will stick back together.
im dead serious..... it works... 2.5 mins in the oven at that low of a temp is no diffrent thana heat gun.... no melting at all.... i got the idea from ben AKA MZMTG.. he did this on his headlights..... if you do this and then are careful pulling them apart... you will not ruin them. Its better than pulling on them like i did for 2 hrs almost breaking them several times
also if you think this is scary...wait till you start to paint them red and find out how hard it is to make them match and that you might really ruin those 130 lights.....i wouldnt want to do it again
Hehe. Its that hard to paint them, eh? How many coats did you end up using? Can i see some pics?
i found it was kinda hard to make them match perfectly.... first i sprayed to first coat on them and it ran... so them i just kept spraying over it untill it wasnt that noticable. Then i put a total of like 5 coats on it... this is too much.. 4 would have been perfect.... my advice is each time you put a coat on hold the back up to it and take it out ot your car to make sure the color close..... my taillights are slightly darker and less transparent than the OEM ones... but unless you are REALLY looking you wont notice
wow that does seem to match up damn near perfect. But yeah, what about the turn signals? NOt having to take the damn things apart would be very nice!
I know you guys are just trying to do it your self but I dont think its worth the risk so the best thing you can do is order a pair from David Lau which I did or send your all clear and he will open it and paint them. Trust me got mines 3 weeks ago and they are beautiful he did a great job
What do you mean by "painting red" ?? Don't you have to paint the orange part white?
also if you think this is scary...wait till you start to paint them red and find out how hard it is to make them match and that you might really ruin those 130 lights.....i wouldnt want to do it again [/B][/QUOTE]
How do you figure painting the orange turn signal will give you that clear look? And what would you use on it? White paint? Only thing it will do is totally block the turn signal so you can no longer see it anymore...thus rendering them useless.
fastcarny
10-06-2015 10:42 AM
lowpost99
09-08-2015 05:06 AM
Maxima30
09-07-2015 06:13 PM
