Mods vs. Tuning
Old Jun 19, 2007 | 06:58 PM
Neo Raven456's Avatar
Mods vs. Tuning
My only mods to date are a PRCAI, and new 2.5" exhaust, CE Y all the way to the greddy cat back. Since the engine is n/a, would purchasing a unit to tune be worth it? would I really be able to pull out any extra from the bolt ons?
Also, which direction should I head in next in terms of performance, aside from a 3.5 swap. I was thinking a UDP, flywheel, or nitrous. comments welcome
(On a complete side note, when abbreviating would it be "an UDP" since the phrase is actually "an Under Drive Pulley" or would it be "a UDP" since its abbreviated? Anyone know?)
Old Jun 19, 2007 | 07:10 PM
NmexMAX's Avatar
dot dot dot ...
Depends on what 'worth it' means to you. Of course you would gain from said 'tuning' IMO, a word used very loosely around here.
Old Jun 19, 2007 | 07:13 PM
Tatanko's Avatar
Bacon Lover
I would say "an UDP" because when I read "UDP" in my mind I'm saying "Under Drive Pulley" not "U...D...P"
Old Jun 19, 2007 | 08:18 PM
goldtooth's Avatar
I thought that you use "an" before any word that starts with a vowel and you use "a" for a word that starts with a consonant.?
Old Jun 19, 2007 | 08:23 PM
Tatanko's Avatar
Bacon Lover
You do, but does an acronym count as a word?
Old Jun 19, 2007 | 08:55 PM
goldtooth's Avatar
touche!....
Old Jun 19, 2007 | 09:09 PM
haha I like how the bulk of the thread turned into the grammar side note.
If I can pick up an Apex'i SAFC/VAFC/NEO for a few hundred, and be able to tune and correct my, I think its the fuel curve? and a/f ratio to be more efficient, it would theoretically pay for itself over time, in the gained efficiency over money lost in gas on the less efficient system.
Or tune for performance, or in effect tuning against efficiency. I think I remember seeing a beginner's guide to tuning on here in the tc/sc forum or maybe all motor. Idk, I've never tuned, don't pretend I know how to either, but it sounds like something that would be fun to learn
Figure I'd ask the guys that know what they're talking about if it'd be worth it or if I would be wasting my time
Old Jun 19, 2007 | 09:24 PM
Tatanko's Avatar
Bacon Lover
They do not necessarily have to be opposites. If you're running rich in a lot of places and remove fuel via an AFC to lean it out a bit, you'd actually be increasing fuel mileage and power.
Old Jun 20, 2007 | 08:31 AM
Good point, I should have actually known that because I just dealt with and fixed a dying MAF that was causing me to run rich, slow, and with about 15mpg.
So anyway, would I really be able to see any improvements, noticeable improvements by using a Fuel correction unit with the little bolt ons I have?
Old Jun 20, 2007 | 01:01 PM
Cdg2125's Avatar
Yes with an AFC you will be able to tune the car to your likeness and will gain from it. Even tho you don't have a lot of mods, tuning the car different from stock specs can give you more power and better fuel economy. For the prices you can get a VAFC or SAFC it's worth it IMO. I still kick myself I havn't bought one yet. A WBo2 would be helpful as well if you think you're going to tune yourself.
Old Jun 20, 2007 | 01:05 PM
I'd ask what exactly a Wideband O2 sensor does, but I'll do a little reading first then come back to this thread. Thank you cdg, I'll look into a vafc/neo, heh also because I'm a big fan of ICE, even if it wasn't completely necessary XD. It's trying to weight that "cool look" vs. "usefulness"
Old Jun 20, 2007 | 01:14 PM
speed racer's Avatar
Try to get a JWT or TS if I was planning to stay NA. It would be better for your application since it comes with a relatively descent fuel map and timing advance.
Old Jun 20, 2007 | 02:03 PM
But wouldn't one of those ECU's be more expensive than an AFC and wouldn't an AFC allow me to do the same thing only to my own specifications?
Old Jun 20, 2007 | 02:52 PM
Ok now that I understand the difference between narrowband and wideband 02 sensors, will say an Apex'i VAFC or NEO be able to give a lambda reading through the sensors already built in?
I'm presuming the 02 sensors we have already are narrowband
Old Jun 20, 2007 | 02:59 PM
TurTLe*'s Avatar
those ECU's are $400-600 pending on who is selling. Plus there is always a chance it might give you a CEL because of years and tranny differences in the 4th gens.
the VAFC/SAFC or w/e you want to get is $200-250 plus a tune might be $100-150, which is like 1 hour on the dyno done professionally. From what i have heard and read. So in the end you get a them for nearly the same price. The ECU is plug and play but only for that maxima. the VAFC can be put in on any car you might want in the future almost.
NmexMAX's Avatar
dot dot dot ...
IMO, the o2 input/outputs re: VAFC/NEO are as useless as our stock narrowbands.
Get a wb w/logging capabilities and am AFC of your choice.
Old Jun 20, 2007 | 03:14 PM
So would you suggest something like the Zietronix zt-2, with display ($400) and then an Apex'i SAFC to tune the ratio?
Old Jun 20, 2007 | 06:05 PM
96blkonblkse's Avatar
Heard good things about that..also on the supra end i always hear good things about the LM-1. Id get a VAFC2 too. More tuning points 24 vs the 12 of the safc2. Also if you plan on going with a variable intake (00vi or mevi) you can control the switchover with the VAFC2.
So I have roughly the same mod as he does. Would tuning do much to a car with basic bolt ons? I guess every car is different, but roughly what type of gains are we talking about?
Old Jun 20, 2007 | 09:13 PM
NmexMAX's Avatar
dot dot dot ...
I've heard bad things about the LC-1. Aside from that, all of them are in the ballpark of ~400$ if you get them with RPM logging capability. LC-1 is cheap w/o the converter, but logging vs time IMO, is inconvenient and not as efficient when working with a unit such as the SAFC/VAFC. BTW, you will want the VAFCII or NEO, as they both offer more correction points vs the SAFCII.
LM-1 is cheaper, but if you get the RPM converter, it comes out to about 400ish. The FJO is about the same(actually a little pricier) and the PLXR300(425$) is the nicest of the bunch for that price(not as nice as the JO IMO)
I have the PLX R300. You can log 2 speed inputs and 2 0-5v inputs. Speed is related to hertz(i.e. frequency) and 0-5v are sensors like MAF/TPS/ECT. reading through the FSM and you could develop curves re: the different voltages, plug in #'s and come out with usable data, i.e 0.9v re: ECT sensor = ~ 190*F ECT. Spend some intimate time w/ the FSM to see which signals that are important to you that are read in frequency. What comes to my mind is RPM and MPH. This will also data log using its own independent software (something that all the aforementioned wb's have). This is useful when tuning for the dyno, i.e street tune. Also, when adding mods you can log speed vs time (hopefully in the same or very near the same ambient conditions)
The zt2 w/o display is the cheapest/best bang for the buck. It logs vs RPM, w/o a converter. But, it does not come w/a display. Some dispute the display in that you cannot do anything fast enough to save an engine in an extreme situation. While I do agree that you cannot correct faster than a piston @ 7100RPM, but I can see what my car is doing, i.e. AFR. Also, for me it's almost a must with my larger MAF housing and PCV breather delete. You can see when it changes w/respect to throttle position, load, AC on/off, comparing to AFC correction% etc.
Old Jun 21, 2007 | 02:17 AM
PHAT6's Avatar
NMex - do you or anyone have a list of the settings that you use to tune an SAFC-II (acronym or not it's sound wrong with an 'a')?
Intake/Headers/Y/Resonators/Cat-Back + SAFC-II (currently using a map based on a 1994 VG30E Cefiro with similar mods that has Hi-Throttle starting 2,400rpm @ -5% and moving on up [or down] to -17% @ 5,600rpm).
I'm a little lost on how to do it and any help would really be appreciated.
Old Jun 21, 2007 | 02:21 AM
PHAT6's Avatar
Sorry for the OT post NeoRaven.
I like the idea of doing a 'burst' of performance mods then tuning what you've amassed, setting a benchmark whether it be dyno results, drag times or a top speed (only on a private road mind you) - then doing it all over again with another 'burst' of mods. Depends on whether you're staying automatic or not as well. Things like lumpy cams don't work too well (so I'm told) with autos.
How about equal-length headers (Cattman) and either a Nissan VLSD or a Phantom Grip LSD to ensure you get the most possible (without tinkering with your auto...I assume you're an automatic) fwhp as you can. Hard engine mounts wouldn't go amiss either (Cattman sell some).
Old Jun 21, 2007 | 06:14 AM
NmexMAX's Avatar
dot dot dot ...
I wish you would not use a cookie cutter setting. You need a wbo2 w/logging capability in order to properly use these things. Without it is not a smart thing to do. It's simple. Get wbo2 w/logging. log a run. Examine, make changes via AFC as necessary. Log again and repeat the steps until you're happy with the results. results may be either a very flat/smooth curve, or at a dyno where whichever AFR gives the most torque/power.
Old Jun 21, 2007 | 09:53 AM
Its all on preference. But the ECU will give you more power b/c it increases timing where as the Apexi only corrects your a/f ratio. You can however increase timing by increasing fuel pressure or bigger injectors, but I haven't heard of timing increases that are more than an upgraded ecu.
Dyno tuning at a shop will require you to get a tail pipe so that they can place a WB02 sensor in. Other wise they will use a tail sniffer and those produce very lean A/F ratios.
A really really good tuning shop can tune your car looking at your torque curve but you need to find some one who you can trust.
This is why people end up getting WB02 sensor to tune there cars with an Apexi. Gives them all the tools to adjust a/f. Just remember that you can either install a test pipe for the sensor or put a O2 bung at the y-pipe collector.
Old Jun 21, 2007 | 10:42 AM
a tail sniffer will only produce a very lean a/f ratio at low rpm's when the exhaust velocity is not enough to fill the air at the end of the tail pipe and the ambient oxygen fools it. At higher RPM's though it should be fairly accurate. Also, I would just put it in the beginning of the b-pipe. My cat and B-pipe both came with 02 bungs, and the greddy b-pipe had a filler screw, so I can just pop that off and put it there. Would that be an alright place?
Old Jun 21, 2007 | 11:20 AM
4x4Max's Avatar
Only problem with that plan is that the wideband bungs aren't the same size as normal bungs, i found out the hard way with my LC-1. Good thing my friend welded up a new bung!
Old Jun 21, 2007 | 12:49 PM
NmexMAX's Avatar
dot dot dot ...
I also read that, and believed it, but I have dyno data that suggests otherwise.
Here's a thread for you.
Old Jun 21, 2007 | 12:59 PM
Kevlo911's Avatar
Kevlo for President
You sure? I've used a wideband o2 in my stock bung and the new one I welded looks like the same thread pitch as stock.
Old Jun 21, 2007 | 01:02 PM
NmexMAX's Avatar
dot dot dot ...
I didn't want to post because mine is on my 5th gen(even though there really shouldn't be a difference), but I'll add to this post also. Worked fine on mine.
Old Jun 21, 2007 | 01:57 PM
its 18mm x 1.5 pitch. I think there all the same
Old Jun 21, 2007 | 02:47 PM
PHAT6's Avatar
Cheers for this NMex...but what's a wb02 - something to do with an oxygen sensor...?
Old Jun 21, 2007 | 03:39 PM
WB02 = Wideband O2 Sensor, senses the level of oxygen in the air with a corresponding voltage of 0 ~ 5v.
NB02 = Stock O2 Sensor, senses the level of oxygen in the air with a corresponding voltage of 0 ~ 1v.
The advantage of WB02 is that the accuracy and resolution of your parameters is much better.
Old Jun 21, 2007 | 04:00 PM
PHAT6's Avatar
Cool...thanks Raven.
Old Jun 21, 2007 | 05:16 PM
NmexMAX's Avatar
dot dot dot ...
Just FYI: NB = Narrowband
Old Jun 21, 2007 | 06:24 PM
PHAT, you should check the all motor and tc/sc stickies for some good reading, specifically the bristol ones
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
REDinLV
Sep 28, 2015 12:31 AM
Socalstillen
Sep 26, 2015 12:01 PM
